(#1076)
MarkMeyers MarkMeyers is offline
Car: BMW 430i
Default 02-12-2018, 05:20 AM
Is it possible to disable the gauge sweep on engine start?
It looks cheap on the new LCI black panel gauges, because the displays refresh rate is too low to make the sweep look nice.
Maybe in a future firmware, an option to disable it via the OBD menu?
Default 02-12-2018, 08:37 AM
Sure... But lets see a video of it so I can see if its working right.
Repo335i Repo335i is offline
Default 02-12-2018, 09:07 AM
Hi have 3 times ask. First question are the settings on page 1 still up to date or are there new ones? Second question I drive in Germany gasoline with 102 octane, I can thus map 2 and map 3 drive without further settings? Question three the Jb4 becomes active only when the engine is warm or?
Ando @ BMS's Avatar
Ando @ BMS Ando @ BMS is online now
BMS Customer Service
Car: bmw 335i
Default 02-12-2018, 09:13 AM
Yes the info on the first post is up to date.
Map 2-3 should be fine for you.
Car: BMW 430i
Default 02-13-2018, 11:26 AM
I donít have a YouTube account, so I uploaded a video here
https://ufile.io/k4gsu
Hope this works.
oldmanjoe oldmanjoe is offline
Car: BMW M140i
Default 02-15-2018, 02:26 AM
Gute Morgen,
1. Das JB4 system aktiv nur wenn das Motor warm ist.
2. 100 Benzine in der Schweiz oder Deutschland ist gleich 93 Octane vom USA, deshalb Map 2 is mŲglich.
Default 02-15-2018, 03:06 AM
Hi thanks for the answer .. Map 3 is not possible with 102 octane in Germany? Or can I drive map 3 without problems?
Car: BMW M140i
Default 02-15-2018, 03:23 AM
Mike says its possible. I am no expert. I just look at it in terms of performance vs risk and think your not getting much more at Map 3 than Map 2 and taking on a lot more risk of problems with a stock car.
Default 02-15-2018, 09:12 AM
OK, I do not understand that now. I thought map 3 is for stock cars. Why should that be risk now?
Car: BMW M140i
Default 02-15-2018, 09:55 AM
I thought from your profile you had an N55, ie different engine but I see a post where you declare ownership of an M240i.
Default 02-15-2018, 10:08 AM
Map3 is suitable for a stock car on good quality fuel like RON 102. Might even be OK with map5. Log it if you want us to double check.
Default 02-15-2018, 02:04 PM
Thanks for the answer .. Logging is currently difficult because of thin winter tires and minus grade outside .. But as soon as the summer tires are on it I will log
theresmy5 theresmy5 is offline
Car: 2017 540i xDrive MSport (B58)
Default 02-18-2018, 10:26 AM
Hey Terry, guys- experimented with Map 3 today. Car is totally stock otherwise; am I safe running Map 3 according to the log? Running Shell octane 93.
Default 02-18-2018, 11:22 AM
Log is too short to tell much.
Default 02-18-2018, 12:39 PM
Iíll post another. Do you need distance or speed?
I M inluv340 I M inluv340 is offline
Car: BMW 340i FBO WMI
Default 02-18-2018, 02:02 PM
More time at WOT.
Default Logs - 02-24-2018, 11:50 AM
Hi guys, can someone look at my logs and tell me if everything is alright?
Bullitt1841's Avatar
Default 02-24-2018, 11:56 AM
No. Post here: http://www.n54tech.com/forums/forumdisplay.php?f=35
2017 F36 440i Gran Coupe | PS2 | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
alfanatix alfanatix is offline
Car: f30
Default 02-24-2018, 08:36 PM
Log properly.
Default 03-10-2018, 07:00 AM
We don't have CANflap in the app yet. But it's on the to-do list!
Cool, looking forward to it. Does this make the exhaust louder only at cold start or throughout?
Default 03-10-2018, 01:57 PM
It lets you adjust the exhaust flap control via the BC button (and soon via the app directly).
Default 03-12-2018, 03:47 PM
Just posted a B58 update and could use a few logs to ensure its working as it should be.
BMW_B48_B58_OBDII_9:
1) Redesigned CANbus logging engine for faster sample speed and all available parameters including cyl1-6 timing, water, oil, and trans temp, full time.
2) Corrected speedo calibration issue when using in dash menu.
3) Added FutureUseD Bit4 option to disable startup sweep.
4) Added in dash timing and AFR gauges under menu 2/3 and 2/4 respectively.
Car: BMW 430i
Default 03-13-2018, 02:16 AM
Great to see, that you are continuously improving the JB4!
Just installed the update and here is my quick feedback:
1) Reading codes via the JB4 app is no longer working. It just says "Read failed"
2) disabling the startup sweep works
3) New firmware runs less smooth for me, with the same settings that were good on v8. A lot of throttle closures below 3500 rpms in Map1 and Map2 and boost is lower than in previous firmware version.
4) Attached some logs (v8 and v9) with the same setting that worked fine in v8 and also the default settings
5) went back to old firmware for now
2018 430i (B48), completely stock, 102 RON fuel, FF and EWG wires
Last edited by MarkMeyers; 03-13-2018 at 04:54 AM.. Reason: Added some information
Default 03-13-2018, 09:39 AM
There are no tuning differences between the firmware. Your logs seem normal to me.
On the code reading that could be a bug, I'll check it out!
Car: f30
Default 03-13-2018, 09:40 AM
Thank you Terry will give it a try after i do my dyno this weekend. For comparison before and after ewg and fp wires. And also map5 and 6.
