sheharyar_rr sheharyar_rr is offline
Car: 2014 335i M sport
Default 01-04-2018, 10:10 AM
Finally got a chance to do 1/4 Mile... 0-60 clocked in at 3.78. I was still getting wheel spin here in -15c on winter tires.
Car: 2010 535
Default 01-04-2018, 03:18 PM
Impressive!
Default 01-07-2018, 11:32 PM
Man this car is insane. I knew she had it in her, Just had to get a better launch. I can prolly pull off a better launch but will have to wait till spring for PS4S's to go back on.
(advance apologies on the different sizing of the pics attached)
** EDIT **
A lot of people think these are JB4 results but these are in fact just BMS Stage 1 numbers, on +3 psi, the default setting.
Car: 2010 535
Default 01-08-2018, 03:49 PM
WOW!
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 01-08-2018, 05:02 PM
Can you do a stock run ?
- 16' X4 M40i Tweaked CTS Turbo FMIC | Custom CTS Turbo D0wnP1pe | BM3 E30
- 17 F80 ZCP | BM3 E30 | CTS Turbo D0wnP1pe/CP/HeatExchanger & Mid-pipe
$ECA $XRP $XLM $TRX $ADA
Default 01-08-2018, 09:34 PM
My buddy has already ran it stock... 12.19 @ 117 on the drag strip
Default 01-09-2018, 09:45 AM
Wow and up hill too! Moving!
Default 05-18-2018, 02:02 AM
Absolutely blown away by these numbers. Hit my new Personal best with Jb4 on map 2, although my 60-100 and 60-110 times haven't changed from BMS stage 1, so i don't think JB4 helped much.
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
Frikiton's Avatar
Default 05-31-2018, 05:04 PM
60-100 and 60-110 are important : (
Did u ever do 100-200 or 62-124
Default 05-31-2018, 08:46 PM
Car is super quick man! 11.3@121 wow
Default 05-31-2018, 11:25 PM
I retract my statement of saying JB4 didn't do much, 100-200km/h number's definitely improved from 9 seconds flat to 8.46. Half a second improvement :D
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
Frikiton's Avatar
Default 06-01-2018, 10:23 AM
That's a good improvement
Debating on getting M3 or M550
Default 06-17-2018, 12:51 PM
Interesting to see that Jb4 is requesting 19 psi on map 2. I only see it hit 16 psi, what does that mean? Need bcm or what
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
Default 06-17-2018, 02:20 PM
Let's see your log. Map2 is additive based, so might be wrong map guide posted for your firmware.
Default 06-17-2018, 03:31 PM
You gave me 1b firmware. Anyways i've attached the log below
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
Default 06-17-2018, 04:42 PM
Looks solid to me!
Default 07-25-2018, 08:16 AM
Hey guys, working on some firmware updates for the G series n63tu and could use a couple logs. Drop me an email if you have time to test it out.
Lifted07Duramax Lifted07Duramax is offline
Car: bmw 335i
Default 08-09-2018, 01:27 PM
What kind of dyno numbers are these M550 putting down?
And is 11.3 still the record for them with stock turbos?
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
Default 08-14-2018, 12:40 PM
Should be close to 500whp Iíd say. And yes 11.3 is the fastest Iíve seen and done. Iíll try out the new update terry has to offer which may help me slip into 11.2ís. All these runs are on pump gas. With E mix it should be well in 10ís
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
