(#251)
#dragon# #dragon# is offline
Car: mini gp2
Default 06-28-2016, 09:59 AM
Thanks for the reply terry i will have a look on nam to see if anyone is using yourjb4 with the chrono kit
sootyvrs sootyvrs is offline
Car: BMW M135i N55
Default 07-07-2016, 08:15 AM
Is possible to not connect the ODBII connector and to change maps (0,1,2) either via laptop or android device via the serial cable or the bluetooth connector with Android?
I ask as with RHD cars, it looks more of a pain to route the cable to the current OEM ODBII connector.
Does the ODBII connector have any other function apart from the ability to change settings via the on board computer stalk?
Default 07-07-2016, 08:41 AM
Without the OBDII cable the tuning will be limited to map1 power levels regardless of what map you're on.
Car: BMW M135i N55
Default 07-07-2016, 09:01 AM
Thanks Terry
EldiZee EldiZee is offline
Car: F55-CooperS
Default 07-14-2016, 08:37 AM
Terry,
I drive a F55/B48 MCS and plan to soon add the JB4.
Do you plan anymore changes to Map 1 (91) and Map 2 (93)? Or are you making them a final Release Version (not "Beta" any longer)?
In order to use the cable, would I have to slice it open in anyway and connect cables / solder them, or is it a simple Plug&Play to the OBD socket and to the JB4 on the engine-bay side?
Can you or anyone here post some typical FW-HP & Torque and W-HP & Torque for both of these pump-gas maps on a non-JCW engine?
I would like to better understand what kind of gains can be expected on a non-modified engine.
Default 07-14-2016, 10:34 AM
No changes are planned to map1 or map2. The OBDII is plug and play.
On the dynos I've seen many customer dynos posted. I'm sure if you poke around you can find them. When time permits I'll gather some in another thread here.
Car: F55-CooperS
Default 07-14-2016, 03:29 PM
Thanks Terry.
Let me look around and find some power
Figures. In case you come across some of
The typical results, please post them.
Thanks.
Tsouzaneto Tsouzaneto is offline
Car: Mini F56 Manual
Default 07-15-2016, 04:26 AM
Hi Terry,
I have a F56 14/15.
Do you know what's the FlexFuel wire style that I have to buy?
I am going to buy the JB4, but I am wondering what's the correct wire style that I should buy.
Default 07-15-2016, 04:25 PM
Send a photo of your sensor in to our sales department if you need help identifying it.
Default 07-17-2016, 09:47 AM
Thanks Terry! I just sent an e-mail with the picture to ando@burgertuning.com.
Fstep Fstep is offline
Car: Bmw 320i B48 F30
Default 07-18-2016, 06:06 AM
Hello, Terry.
I've noticed that JB4 has been released for BMW cars too. Some questions that I didn't find an answer.
I have 320I Xdrive B48 184 HP car. Fuel type - only 98 (RON). No tunes to exhaust or intake.
1. Do you have any map for it in current setup? (for N20 it was map 5 if I'm right) . Your webswite shows only 330i B48 supported. Will Map 2 work for 320 i 184 HP?
Please note, that now in our region (Russia) we have 320i B48 with 330i pistons. So basically, it shoudn't be any difference between 320i and 330i like it was in a past (different compression ratio between 320i and 328i N20) This option is called "S858A Low compression engine".
2. Any other recommendation for order ? Flex fuel cables?Or just get the chip+USB cable and that's all?
We don't have E85 here , but I've seen some people install cables to N20.
If you want to have a beta-tester in Russia - I'm OK to be that person =)
Default 07-18-2016, 02:03 PM
Terry,
Could you let me know, if the JB4 Connect Kit it's working fine with the F56?
Default 07-18-2016, 03:49 PM
Yes the JB4 Mobile works for all of our JB4 systems, including the MINI JB4.
SixtenBV SixtenBV is offline
Car: F56 JCW
Default 07-21-2016, 01:40 PM
Hello Terry
Could you make a statement when you guys plan to release new Maps for the B48. I just posted new Logs with Map 1 and Map2 pulls in the support section. Based on the data you guys received any plans to make some maps for higher octane fuels as we have it here in Europe with 98 Oct, Shell 100 Octane and the faboulus Aral Ultimate 102 Octane?
cheers
Car: BMW M135i N55
Default 07-21-2016, 01:50 PM
Originally Posted by SixtenBV
Hello Terry
cheers
I read that In europe we measure in RON so super unleaded is 98 RON which is equivelent to 93 octane in US hence map 2 is for use with 98 RON or 93 octane or above.
I'm sure Terry will correct me if I'm wrong though
Default 07-21-2016, 01:55 PM
Hello, Terry.
Do tou have any update on my post above(18 July)
The device is on my way to me , plan to get it next week, so need to know the answers.
Thank you in advance.
Car: F56 JCW
Default 07-21-2016, 02:06 PM
Great post. I checked that and you're 100 % correct.
So our 98 RON is equivalent to your 93 and the Aral Ultimate would be 95 for you.
Still I look for more power ��
Default 07-22-2016, 08:43 AM
Hello Terry,
I bought yesterday my JB4 Beta + Upgrade Kit + FF Wires.
Is it possible to send to me, everything already assembled?
My order is the BMS23469.
Default 07-22-2016, 12:21 PM
If you bought a JB4 you don't also need an upgrade kit. But we can plug the FF wires in for you. Just email in to the order department.
johntotah94 johntotah94 is offline
Car: B46 F56S
Default 07-24-2016, 01:22 AM
I'll be installing my JB4 on Monday with the FF wires. When running Map 2, do I need to change any settings to run an E85 mix? Or do I just mix 3 gal or so with pump and I'm good to go?
Default 07-24-2016, 08:42 PM
Just add in the fuel and go.
Default 07-25-2016, 09:49 AM
Thanks a lot for the support, Terry!
Pent's Avatar
Pent Pent is offline
Car: F56
Default B38 JB4 BETA - 07-25-2016, 11:30 AM
Hi Everybody,
Thank you all so far for the information as it helped me get to the point I'm at now.
Default 07-25-2016, 12:36 PM
Tech support requests are deleted from this thread, but you can make a post in the support forum, or email in to tech support, if you need help.
neilvosko neilvosko is offline
Car: 335i+JB4+FBO
Default 07-25-2016, 03:51 PM
can the JB4 (http://burgertuning.com/MINI_B38_B48_JB4.html) stacked (added) to the JCW tuning kit ?
