(#351)
dwells dwells is offline
Car: E92 335i
Default 01-03-2017, 02:07 PM
It varies by model, N54 is different than BX8 EWG, so you'll have to sell that and buy the correct one.
Figured as much, thanks for confirming for me.
Herc Herc is offline
Car: F20 125i
Default 01-14-2017, 05:28 AM
Would it work for the European BMW 1 series with the B38 engine?
Default 01-14-2017, 10:19 AM
Yes it's compatible with all B38 models.
Car: F20 125i
Default 01-14-2017, 10:33 AM
Good good, some of my friends will be happy. Thank you
racingstation racingstation is offline
Car: F30
Default 01-19-2017, 09:17 PM
Hello~
About MINI B48 use jb4 can plus FSB?
And have Methanol Injection map?
and can use EWG harness?
Car: B46 F56S
Default 02-02-2017, 11:39 PM
Anything new coming our way?
trentiles trentiles is offline
Car: 2016 Mini Cooper S
Default 02-10-2017, 06:24 AM
I feel like we are being forgotten about
I came over to Mini from VW. The Burger guy for VW is George and his support was absolutely the best I have ever experienced. While I love my JB4 on my mini the support definitely is lacking for the Mini. George from Burger for their VW offerings seemed to reply to any questions posed to him any time of the day or night in a matter of 30 minutes or less with great detail.
I asked a question back on 12/29/2016 that still hasn't been answered:
"When installing the Flex Fuel wires does anything need to be changed software side on the JB4? Any settings that need to be changed?"
Car: B46 F56S
Default 02-13-2017, 11:57 PM
Nothing yet with flex fuel wires.
I think there are issues getting to the EWG connector at the moment.
Unless anyone knows where you can get easy access.
Default 02-14-2017, 03:05 PM
Sorry we must have missed the question. Per the flex fuel install guide, open loop has to be set to 60.
Car: B46 F56S
Default 02-15-2017, 03:42 PM
If I adjust FOL should trims be close to 25?
Default 02-15-2017, 04:22 PM
At full throttle? They just need to be less than 50.
Car: B46 F56S
Default 02-15-2017, 04:34 PM
Ok. Thanks.
So if Trims >= 50.
Then Trims are considered maxed correct?
skyhawkcaptain skyhawkcaptain is offline
Car: Mini F56
Default 02-21-2017, 10:26 PM
Any updates on the map for water meth?
Default 02-22-2017, 04:17 PM
I'll have to work on that firmware, waiting for customers to email with a kit installed, so we can help them with it directly.
djtomy's Avatar
djtomy djtomy is offline
Car: JCW F56 B48
Default 02-23-2017, 05:49 PM
2016 JCW F56 4,600 miles
JB4 Map 2, codes
Fuel / Boost gauge active
Codes its showing:
Sorry, Ill post in the code section
Car: B46 F56S
Default 03-06-2017, 01:16 AM
Do we have a setting to reset adaptions on this JB4?
motrid motrid is offline
Car: 2015 Mini Cooper S
Default Switching maps - 03-06-2017, 09:43 AM
Does the engine need to be off to change maps?
Car: B46 F56S
Default 03-06-2017, 02:27 PM
No.. You can change on the fly
Car: B46 F56S
Default 03-08-2017, 01:25 AM
Anyone mess with Map 6 yet? Map 2 I'm roughly around 13psi while ECU tuners push this car around 18-20psi. Thinking of pushing boost up a bit and seeing how the car reacts.
Probably going to use the standard:
RPM Boost
1500 10
2000 11
2500 11
3000 11.5
3500 12
4000 13.5
4500 14.5
5000 15.5
5500 15.5
6000 14.5
6500 14
7000 12
Any advice, tips, or recommendations is appreciated.
tt_r1 tt_r1 is offline
Car: Mini F56 JCW
Default 03-08-2017, 06:04 AM
What does Map6 mean?
Usually I use Map1 or Map2.
Car: B46 F56S
Default 03-08-2017, 02:29 PM
User Adjustable Map
leozip leozip is offline
Brazil
Car: Mini F56s
Default 03-11-2017, 02:37 PM
Hey Terry,
Could you send me (leozip@hotmail.com) instructions on how to install the FF wires? I could only find info for the N20 motors but nothing on B48. Thanks
Brazil
Car: Mini F56s
Default 03-11-2017, 02:40 PM
So no one here running Meth yet on the B48? Any threads on Dyno graph and max gains from the JB4 on the Minis?
Brazil
Car: Mini F56s
Default 03-19-2017, 09:02 AM
Anyone here using WMI on the F56? If so where did you place the nozzle? How's the system working and how much Hp increase overall?
Terry:
Is it possible to use B58 Billet WMI Spacer on the B48 engine?
Default 03-20-2017, 11:17 AM
The BMW B58 spacer does not fit the MINI B48.
