zort zort is offline
Default Wastegate Rattle - how about loose wastegate - 09-11-2017, 09:58 AM
So everyone has this dreaded rattle. I have tried the following -
Tightening the rear rod
Using the JB4 settings
Both to no avail...
Only until I decided to change all vacuum lines did it find the culprit. My front turbos waste-gate was loose - no bolts. Seems an oil leak from the oil filter housing may have caused the bolts to back out.
I was able to get one bolt back in with out removing the turbos and the rattle is gone.
-B
ryaaan18 ryaaan18 is offline
Default 09-11-2017, 12:21 PM
do you know the size of the bolt needed for wastegate bracket?
Default 09-11-2017, 12:31 PM
I could not find that info but ended up using something from the tool box that worked. Let me see if I can get the spec.
