drifter's Avatar
drifter drifter is offline
Car: N54 135i
Exclamation Lambda sensor fault - 09-10-2017, 05:19 AM
Hi guys,
Installed a set of VRSF 2" inlets 2 weeks ago and while installing the rear one had to push/shove and squeeze quite a lot...
Anyway I had a misfire the next day with the typical misfire codes from bank 2.
Now I've had this code come up a few times
2C3E - DME: Oxygen sensor 2 before catalytic convertor: Line fault.
Google it but can't seem to find anything.
Any ideas anyone? Car is 08 135i FBO with inlets running MHD stage 2+ 93 Oct.
Thanks in advance!
N54 135i - MHD Stage 2+ - AR ******* **'s & custom 3" axle back - AMS Intercooler & BMS CP - VRSF DCI & 2" Inlets - Spec stage 2+ - Vogtland Club Suspension - E9x M3 cowl conversion
Car: All of 'em
Default 09-10-2017, 07:53 AM
Check your wiring. Be sure nothing is pinched. Log the activity of your sensor and see what it is doing.
drifter's Avatar
Car: N54 135i
Default 09-10-2017, 08:22 AM
I unplugged it last week and checked all the heat shield sheath and there was no visible damage to it, obviously can't see beneith the sheath. When I unplugged it under the engine cover it felt like I managed to push the cables back into the plug so that maybe the issue (may have pulled the cable when I was trying to get the inlet pipe down the back..).
I have a spare bank 1 sensor, can I use that in bank 2? Is it just a case of bank 2 having a shorter cable?
drifter's Avatar
Car: N54 135i
Default 09-10-2017, 08:25 AM
Also here's a log I took yesterday
http://www.***********/u/drifterr/3r...og=0&data=3-24
Car: All of 'em
Default 09-10-2017, 08:30 AM
Originally Posted by drifter
Upload the log, we cannot click that link.
The o2 should be the same, might have a different connector on it. You could probably just try reversing them since you have no exhaust filter. It shouldn't effect drivability any more that you already are experiencing.
drifter's Avatar
Car: N54 135i
Default 09-10-2017, 08:51 AM
Log attached, thanks!
Car: All of 'em
Default 09-10-2017, 09:04 AM
For some reason your csv won't graph on my phone, but that's okay. From the spreadsheet it looks like that o2 is acting up. I would go ahead and swap it.
I can't tell you how many times we've had o2 problems because the wiring inside the loom is fubard on untuned cars.
drifter's Avatar
Car: N54 135i
Default 09-10-2017, 09:09 AM
OK will do, so that is likely the cause of the misfire on bank 2 and the sometimes slightly hesitant cold start?
Does the rest of the log look OK?
Really appreciate the help!
Cynical Cynical is offline
Default 09-10-2017, 12:16 PM
Both pre *** sensors are identical. Wire length is different. Just swap ur spare in
Wow. Apparently C-A-T is censored on this patheitc forum now.
Car: All of 'em
Default 09-10-2017, 12:20 PM
That word has been sensored for a long time brother! If you think it's pathetic, whatcha doin over here?
Lot of good advice on here.
Default 09-10-2017, 12:21 PM
Ignorance is bliss. A lot of misinformation and censorship as always here
Car: All of 'em
Default 09-10-2017, 12:27 PM
Same can be said for bimmerboost, bimmerfest/forums, all these boards. The entire internet as a matter of fact. Any time a non trained non professional shade tree 'mechanic' tries to help another one, there will be a lot of speculation and misinformation.
It's just people trying to help people. I like your username!!
Sorry not trying to hijack! OP, a false signal oxygen sensor can absolutely lead to misfires, poor running in general. Switch the o2s as Cynical stated and see if you can move the fault to the opposite bank. If it moves, you're done, order a new o2 and hang tight. I can make you a decent deal on one if you PM me the best you can find it for shipped I'll let you know.
Default 09-10-2017, 12:36 PM
Tell me more about how you claim to be a performance shop and have to ask people about wheel fitment for his customers.
And sorry bud this forum is beyond censored, as you can see Ive populated this place a lot longer but continue to tell me 😂
Default 09-10-2017, 12:38 PM
You are a joke. Try reading before pushing your **** parts for a sale. He has a spare sensor. And oem sensors are gabage. We all change them to Ngk.
Goodluck with that performance shop. You are going to do well. I can tell
Car: All of 'em
Default 09-10-2017, 12:42 PM
Edited! Not going to argue with an amature tuner. He's right, I'm wrong, I'm an idiot! What do I know? I mean, 600rwhp n55 in my shop, 650 awhp x5m in my shop, rigging up meth and stage 2 turbos on an f01 targeting 700+, but I'm an idiot!
drifter's Avatar
Car: N54 135i
Default 09-10-2017, 01:21 PM
Thanks for the help, I'm in the UK so with shipping, customs and current exchange rates it will probably be cheaper for me to get one over here if the spare I have is no good!
xQx xQx is online now
Car: 2008 BMW 135i E88 N54 6AT
Default 09-10-2017, 10:06 PM
Just to hijack this thread, I keep getting a 2c77 "lambda probe behind catalytic converter signal" code.
How do I find out which one it is?
I loaded up real-time lambda readings in inpa, all look normal.
Car: All of 'em
Default 09-11-2017, 05:41 AM
Better off making your own post. Happy to help.
Need to know what engine you are diagnosing. N54 or n55.
Default 09-11-2017, 11:10 AM
Omg 700+
You must be a genius. Glad to see your so busy at your “shop”
