kutila kutila is offline
Car: BMW M6
Default N54 Loud Ttick from to injector line - 08-23-2017, 08:32 AM
Hi
So i ran out of options, and if u guys know what is tiking i would appreciate any help.
So bought this car from the auction with blown engine.
Replaced the engine and had ticking sound, tonns of missfires, car would not want to start, long story short, i bought another engine, changed the previous one, and have same ticking noise.
On the last engine i replaced Camshafts with vanos units, 24 lifters, checked boost solenoids, changed all 6 injectors. Removed the oil pan to check if thats spun rod bearing, but all 6 bearings are with in specs.
I ran out of options.
https://youtu.be/3TAwneArm6Y
K.Jameel K.Jameel is offline
Car: BMW E92 N54
Default 08-23-2017, 03:45 PM
Same sound to me, car run fine, now been two weeks the tickling noise still there some says it's vacuum pump....! Removed the calve cover every thing in place and fine, happened right away after installed new DME MSD81
Please keep me updated...
BMW 335i '08 E92 N54, JB4 G5 IOS, BMS DCI, VRSF ***, BMS-Tial BOV Kit with Chargepipe, VRSF FMIC, BMS Meth Kit, JB4 MHD BEF, BMS PCV valve, BMS OCC. TCU Alpina_B3 Flash, .
Car: BMW M6
Default 08-24-2017, 10:04 AM
well today i drove it at 3000 rpms for 15 mins, and the noise is gone.
problem is probably at cylinder head lubrication lines, will change the oil to a thinner one and will post the result later.
DME flash could cause detonation that can also do a tick, be carefull with remapping
tsaulsbu tsaulsbu is offline
Default 08-24-2017, 02:12 PM
I have the same exact sound. Curious to know the source, if you definitively narrow it down.
Default 09-08-2017, 10:46 AM
Any updates, kutila or K.Jameeel?
shoepac11's Avatar
shoepac11 shoepac11 is offline
Car: 2008 335i E90
Default 09-08-2017, 08:00 PM
Me too... sometimes...
2008 e90 6mt
FBO/BMS meth
RB turbos
RB inlets
G5 iso
back end flash
fuel-it stg 2
Car: BMW E92 N54
Default 09-09-2017, 05:22 AM
Took the valve cover off and check, everything was ok, i know it's fuel injectors but have to make sure. After several runs high speed for around two weeks the noise has gone.
Car: BMW M6
Default 09-09-2017, 09:12 AM
sold the car.
check pressure release valve on hpfp pump
Car: BMW E92 N54
Default 09-09-2017, 10:00 AM
Originally Posted by kutila
sold the car.
How I supposed to do that...?
Car: BMW M6
Default 10-05-2017, 12:16 PM
with stethoscope
so i sold that ticking car did not figure out what was wrong with it, and bought another project 335
Built engine from bottom to the top, and that tick appeared again, i guess it will chase me until i solve it LOL.
R.G. R.G. is offline
Default 10-05-2017, 12:38 PM
Lifters. Common issue with N52s. Goes away when the oil heats up and they're lubricated
