(#51)
Cchriswp Cchriswp is offline
Car: Bmw M4 ,BMW 135
Default 11-27-2016, 07:57 AM
Hi there ... Please can I get some advice on a lsd for my 2010 n55 dct . I'm currently running fbo and pure stage 2 .
Thanks in advance
Chris
MFactory MFactory is offline
Car: BMW E92 M3
Default 11-27-2016, 08:01 AM
What type of use/application?
seatte135i seatte135i is offline
Default 11-27-2016, 02:20 PM
I'm trying to decide between your metal plate lsd or the Helical LSD. I have a 135i manual, it's my dd would like to take it drifting every once in a while. Is the metal plate a 1.5 way or 2 way. What would the difference in drivability be between helical and your v2 metal plate?
2009 135i 6MT/ JB4 G5,TREBILA mhd tune, FBO w/ fuel-it dpmi.
Car: BMW E92 M3
Default 11-28-2016, 02:01 AM
With our plate LSD, you can adjust it anywhere between 1.0 - 2.0 way and in between, as we include various angles for you to choose from.
However, if this is mainly going to be a DD, I would suggest the Helical LSD as it is both noise and maintenance free. The Plate LSD will have some NVH at low cornering speeds, and the plates/springs are maintenance parts
the_panda_driver's Avatar
the_panda_driver the_panda_driver is offline
Car: 2007 BMW 335i
Default 12-07-2016, 11:13 AM
I have a question for you, i have and AT car now but i will be doing a MT conversion, I have your MFacotry full diff build, could i change that in for a MT one i bought it last christmas and still have the warranty card and everything. Thank you for your time!!
Car: BMW E92 M3
Default 12-07-2016, 11:37 PM
What month/year is your build date?
Car: 2007 BMW 335i
Default 12-09-2016, 09:35 AM
Nov 27 2015
Car: BMW E92 M3
Default 12-10-2016, 03:25 AM
If you're doing an MT conversion, and you modify your oem driveshaft length, you could get your current pumpkin to work/fit.
07tundra's Avatar
07tundra 07tundra is offline
Car: a slow one
Default 01-06-2017, 11:56 PM
I know this a bit old but if i'm correct i see that an 07 mt has a large bolted diff and 08 AT has a small bolted diff? yes? So whats the cost for LSD Mt diff? and will a 07 mt large diff fit in a 08 6at car
Car: BMW E92 M3
Default 01-07-2017, 04:39 AM
Upto 03/2007 MT is bolted
Upto 08/2007 AT is large diff. Thereafter is small diff
The diff itself will fit, yes, but you would also need to modify your driveshaft length.
datbimmer datbimmer is offline
Default 03-25-2017, 03:06 PM
Any way to know if an 03/07 car has bolted or welded ?
07tundra's Avatar
Car: a slow one
Default 03-25-2017, 06:42 PM
I swapped in the mt from the same car so then that same drive shaft will work? also do you guys sell lsd with different gearing I'm looking for a 3.15 instead of the 3.08
parksjm7 parksjm7 is offline
Car: 335i 2007 coupe sport
Default 10-30-2017, 01:25 PM
@Mfactory - can you comment on whether your products are affected by the Japanese Kobe Steel current events where they misstated steel strength? For the Helical LSD, would a rear alignment be required after install? Thanks.
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 10-31-2017, 01:21 PM
What kind of advantages would be for a highly modified ( approximately 700 awhp )2007 E90 335 xi, in the case of using a LSD ? Thanks in advance.
Full Bolt Ons, Forged Internals, Meth PI, JB4 PI contoller, Zage Turbos, TFT inlet system,xHP Stage 3 trans Flash.
Do more with less !
kilimanjarto kilimanjarto is offline
Default 01-08-2018, 04:06 AM
@MFactory
If I want to solve the welded differential problem with an aftermarket bolted final drive, but I have some questions...
how can I know the spected pinion shim?
What is the interval of possible measures of the pinion shim?
Have you got any handbook or specs?
It needs the same backlash than stock?
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 04-03-2018, 11:55 AM
I contacted David @ Synchrotech and he was great, answered my questions.
My situation:
I have a busted E60 diff (AT, 3.46, bolted) - think a tooth let go, it binds every ~3.5 turns of the axle and I hear it clunk. So, seems pointless to send in the busted diff on my car when I know it would force me to buy ($$$) a new ring/pinion set.
I planned to purchase a new E60 AT 3.46 bolted diff online somewhere, and have it shipped to David/Synchrotech to install the LSD in the carrier. I want to be sure I don't buy/send him a welded one, that will cost me more.
My problem:
I cannot figure out how to tell, when shopping for E60 diffs online, whether it is a welded or bolted diff? Is there a part # range for bolted vs welded ? does anyone know?
2009 535i Sport
Default 04-06-2018, 02:56 PM
You don't need to worry about e60 diff. Its same as is on 335s which are plentiful. Most are small bolted. I got one for as little as $80 off a salvage car with 29k on it.
You will love the LSD. Makes a huge difference on drivability in lower gears. That initial torque wave is not interrupted by nannies. Its really a must on cars with 450lbs plus torque.
David at Synchotech took great care of me when I had a recall issue. Great service.
LessIsMore's Avatar
Inner Circle Member
Default 04-09-2018, 12:25 PM
Thanks Ocean, yeah I found that out - at first was told it's hit or miss on which E60 diffs were bolted/welded, and they weren't sure if the E60's were the same as the E90's, etc. ... but then was later told a few days ago when I went back to them, what you said - that they're pretty much all bolted. Found one, bought it, and diff is on it's way to Synchrotech.
2009 535i Sport
335iE91's Avatar
335iE91 335iE91 is offline
Car: '08 e91 335i
Default 05-15-2018, 09:05 AM
I'm thinking about switching to a helical LSD, which in my case should be for the bolted 188 diff.
After reading serveral forum posts on various forums I was leaning towards the Mfactory LSD, until I read the following on another forum:
"commonly overlooked benefit of the Quaife over the Wavetrac - the Quaife retains the oil lubrication for the output shaft to prevent the output shafts from seizing".
I realise this post is really old but it made me wonder if the Mfactory diff also retains lubrication to the output shafts.. And if this is really necessary.
Hope someone can give me some info.
Thanks in advance
'08 e91 335i Auto
Jb4 G5, Mhd backend, Xhp stage 3, Vrsf **'s, Secondary *** delete, Occ and Dci, RB pcv, FTP oil thermostat, Billstein b14, M3 lower controle arms, Poly subframe bushings
SamJ SamJ is offline
Car: BMW 335i
Default 05-18-2018, 10:26 AM
I read something about a recall on these diffs due to bolt failures?
Was there a specific type and batch of diffs effected?
LessIsMore's Avatar
Inner Circle Member
Default 05-21-2018, 08:29 AM
+1 , would also be interested in hearing more on this - haven't heard this before.
Just following up on my prior post while I'm here ...
I had the MFactory Helical LSD installed last week. As a reminder, I bought a used junkyard 3.46 small bolted diff pumpkin and had it shipped to Synchrotech to install the LSD and new seals, etc.
First of all, the diff showed up very very clean, really amazing looking (the housing metal looked wet because it was so shiny/clean!), and probably better than new. It was also packaged extremely well, very secure and protected.
It's only been in the car for a few days, but so far it's amazing. MUCH better traction, particularly in turns. It takes much more effort to breaking the tires loose now. Car feels more stable. under WOT, it just hooks up and goes. And have experienced no noise/vibrations/etc. - you wouldn't know it's there.
I did notice a bit of wheelhop on a rough road at low speed WOT when breaking traction, but I think that's just a function of the improved traction and torque-biasing going on. My 04 GTO with an LSD - and I think any LSD-equipped RWD vehicle - would do that, but this is the first time with the E60 I've felt it. I think the OEM open diff just spun before any wheelhop had a chance to occur.
I'm very pleased overall. David @ Synchrotech was really great to work with, and they were very good on communication and timing of shipments, etc. Definitely recommend.
2009 535i Sport
