kpjo4's Avatar
kpjo4 kpjo4 is offline
Car: e92
Default 11-20-2015, 09:39 AM
I've never really enjoyed torsen or viscious type, from a racing point of view I suggest a locking clutch type 1.5 or 2 way; I've owned Nissans with different types of pumpkins.
Car: F06 N55 640i Gran Coupe
Default 12-05-2015, 09:03 AM
Originally Posted by MFactory
Max. 2l, but usually around 1.5l for most customers.
Hi, can u confirm on which part number I need for my 2009 N54 E89 Z4?
I suppose my stock gear ratio would be 2.56, my question will be what if I replace it with your 3.08 or maybe 2.81?
Not more about saving fuel Nor high speed above 155mph, I'm looking at good 60ft & 1/4mile result. Pls advice, thanks.
Andy
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS ** n FULL Custom Exhaust
Custom BC forge 18/17 set up
MFactory MFactory is offline
Car: BMW E92 M3
Default 12-06-2015, 01:35 AM
You have a DCT?
Default 12-07-2015, 08:27 AM
Yes I have a DCT, is a 2009 E89 Z4 RHD.
Pls advice, thanks.
Car: BMW E92 M3
Default 12-07-2015, 11:57 PM
I would stick with the 2.56 due to ecu/shifting issues after changing ratios.
You have a welded diff though, so have a few options:
1) LSD only. You will need to get machining work done
2) LSD + Install Kit. No machining required
3) Fully rebuilt pumpkin. Direct swap
Trickcruiser's Avatar
Default 12-08-2015, 07:22 AM
My LSD is on the way and looks to arrive tomorrow! So far the MFactory team has been an absolute pleasure to work with.
I will be putting together a DIY and review once done.
TBM TBM is offline
Car: 2007 E90 335i
Default 02-02-2016, 07:10 PM
In the market for an LSD and I'm down to a Wavetrac or MFactory.
MFactory seems about $200 cheaper, but does this translate to a "lesser" LSD?
2007 E90 335i 6AT - 580whp/550wtq
- Custom Trebila Tune (25psi) - Hexon RR600 turbos - JB4 G5 ISO - MMP Inlets & Outlets - VRSF *** - VRSF 7" IC - MFactory LSD - BMS Meth Kit (Dual CM7's @ 100% meth) - Fuel-It! Stage 1 LPFP - BMS OCC - RB PCV - Turbosmart Kompact DV's - 4bar TMAP - NGK 5992's @ .018" - VRSF 12mm Spacers (Rear) - Blacklines - Mtec V3 AE's -
Car: BMW E92 M3
Default 02-02-2016, 11:11 PM
Most certainly not
TBM TBM is offline
Car: 2007 E90 335i
Default 02-03-2016, 07:40 PM
I ordered the MFactory one today.
Default 02-04-2016, 05:58 AM
Hi, what's the cost for item 2 & item 3?
Any recommendation if I want to improve my 100-250kmh run timing? Any final ratio like 2.81 or 3.08 upgrade? There must be a reason why people change them right? I have Pure Stage 2 & almost all the FBO so top end power should be much better than stock so What's your Adv? Thanks
Car: BMW E92 M3
Default 02-04-2016, 11:11 AM
What model/fitment/transmission do you have?
Default 02-04-2016, 02:54 PM
Is a E89 Z4 Pure Stage 2 with almost all the bolt on & DCT.
Car: BMW E92 M3
Default 02-05-2016, 12:02 AM
If DCT, I would recommend sticking to the 2.56
LSD is $999.95. Install Kit (new ring & pinion, shim kit and bolts) is $799.95
Rebuilt Pumpkin is $2199.95 + $500 refundable core fee
Default 02-05-2016, 06:34 AM
What happen if I get yr 2.81 final drive? If I don't want to have any down time does it mean I need your rebuild pumpkin & once fix I can send my stock to you for a $500 refund? So all in all is $2199.95-$500=$1699.95+$799(2.81 final drive) $2498.95 right?
Car: BMW E92 M3
Default 02-05-2016, 09:48 AM
$2199.95 + $500 refundable core fee i.e $2699.95
If you send back your old core within 30days, we will refund the $500 to you i.e Total you pay is $2199.95
We have pre-machined 2.81's on the shelf. No need to purchase an install kit.
Default 02-05-2016, 03:29 PM
Sounds good, question: how will the car react to 2.81 final gear? Any changes I need to make on the dme side & if yes how do I do it? Can I change my overall tyres diameter bigger from 265/35/18 rear to 275/35/19 to compensate the quickly & earlier shift into higher gear? Or will the DCT go crazy with different set up on the final gear(2.81)?
Car: BMW E92 M3
Default 02-05-2016, 10:36 PM
That is something you would need to ask a DCT owner who has changed to a different ratio unfortunately
Default 02-06-2016, 05:00 AM
Any DCT owner running a different final drive mind to share your experience?
What are the pros and cons running a higher final drive? From a 2.56 to a 2.81 or even higher?
DarrylGarland DarrylGarland is offline
Car: 2009 535i
Default 04-15-2016, 11:45 AM
How much would much for a pre-built LSD for 2009 535i AT? I only saw $999 for the lsd itself on the site
2009 535i M-SPORT AT
JB4 G5 ISO, BMS DCI, E85 BEF ON 100% E85, VRSF **'S, 7" VRSF IC, VRSF CP W/ TIAL BOV, MMP Inlets & Outlets, TBI & Stage 2 LPFP,1792s in for 2nd cats, Potenza RE-11's
Car: BMW E92 M3
Default 04-15-2016, 12:14 PM
If you look under Carriers, you will find what you're looking for
Grimaldi Grimaldi is offline
Default 04-18-2016, 01:36 AM
Does anyone know any UK options and prices?
Trunks335i7's Avatar
Trunks335i7 Trunks335i7 is offline
Car: E90
Default 05-07-2016, 01:04 PM
So after reading I can see that Drexler is the only LSD manufactured in Germany?! I think I will go with that one unless people have had many bad experiences with that one?! For that price I hope it is the best around...
turboalb's Avatar
turboalb turboalb is offline
Car: 08' 535i
Default 08-14-2016, 07:45 AM
2008 535i auto, what else will I need other than the MF-TRS-05E46A lsd, thanks.
08' 535i sport auto, jb4/mdh/xhp
10' x5m 11.72 1/4 record jb4 only
00' hayabusa turbo street bike
440 rwhp 1/8 5.42 141mph
07 SS trailblazer tuned/flex fuel
mistawall mistawall is offline
Default 09-28-2016, 12:32 PM
how does mfactory stack up against an m3 lsd. i know m3 lsd is alot more work to install but performance wise are they pretty evenly matched?
TFT inlets, charge pipe TIAL BOV
RISS **, Exhaust
Walbro 450
335is CLutch
BMS short shifter
VRSF 7"
Apex EC7
KWv3 (not installed)
Devils own Meth kit (not installed)
Car: BMW E92 M3
Default 09-28-2016, 06:34 PM
Price is around 1900 all inclusive (inc. removing/installing pumpkin from your vehicle at our UK facility)
it is one of the best, yes.
we would also recommend shims, bearings and seals
the M3 LSD works/serves it's purpose, but it is not really performance orientated (wasn't designed to be)
