(#1176)
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 09-01-2017, 03:18 PM
Are you using a PR harness?
2007 AW 335i E-92 6AT MMP Stage 3 @ 24psi / JB4 G5 ISO / XHP STG3 / VRSF ** / MMP INLETS&OUTLETS / MHD E85 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / CYBA SCOOPS / BC STAGE2 LPFP 10.98 @ 131
BrazyN54 BrazyN54 is offline
Default 09-01-2017, 04:36 PM
Originally Posted by BeGooD69
Where does the esensor plug to in this pi controler/jb4 setup!! Db25 pin 2?
Also I think my st3 relay is confusing... orange on PI controler goes to + trigger on fuel pump relay? And - trigger now connect to ground right?
If using the PR harness do what I did. No running additional wires or anything.
On the relay connector
The connectors for spot 85 and 86 need to be swapped.
85 should be a green wire that goes to the hobbs switch
This allows us to use the long pre made wire straight to the jb4 controller instead of running a new wire from the signal
From that
Cut the hobbs switch off tape off the other colored wire and use the green wire to connect to the Jb4 controller orange wire
And then ground the other wire that was the signal + wire which is now a ground on spot 85
Been runing this setup and it seems to be working, after 15psi the jb4 pi controller seems to activate the second pump and lpfp pressure is steady around 75psi
Default 09-01-2017, 04:42 PM
Exactly what he said.
Russjonesr's Avatar
Russjonesr Russjonesr is offline
Car: Bmw e92 335i
Default 09-02-2017, 08:42 AM
Hi Guys,
I have purchased the anti-lag chip upgrade as I'm installing the jb4 PI Controller, my Jb4 is over 3 years old. However looking at the installed chip it already says PIC18F24K22? Only difference I can see from the newly purchased item is it says 1231YB8 after it...so do I actually need to swap this out?
Cheers Russ
VTT Stage 2+ turbos, BMS JB4, EOS PI with BMS controller, RB Inlets and Outlets, VRSF CP and Intercooler. Tial bov, miltek exhaust. Tuned by Trebila.
11.3@127 (https://www.shakespearecountyraceway.co.uk)
Stephtech's Avatar
Stephtech Stephtech is offline
Car: 335xi 2010 E90
Default 09-02-2017, 12:36 PM
Originally Posted by Russjonesr
Hi Guys,
Cheers Russ
acording to Terry,
1) For this to work the JB4 needs the latest 24k22 programming on the slave chip. Any G5 board shipped after 11/1/2015 will have this programming already. For older boards you can update it by adding the anti-lag chip on our upgrades page.
from this thead: (post #2)
http://www.n54tech.com/forums/showthread.php?t=28478
Basically, what I understand from this is that you may have the same type of chip but not the correct firmware programmed inside, that means yes you should swap the chip.
the code 1231YB8 is a manufacturer code indicating manufactured date and which plant made it. This chip is most likely from 2012.
2010 E90 335XI 6AT with XHP stage 3 | JB4 G5 W/Trebila Tune | RB Next Gen | RB hot side INLETs | Fuel-IT stage 1 LPFP | ETS FMIC | MODDED VRSF CP | FORGE DV | BMS METH KIT CM10+CM5 | AR DESIGN cer. downP | BMS OCC | RB external PCV w/plugged HEAD | Best 1/4: 11.47@123mph
Russjonesr's Avatar
Car: Bmw e92 335i
Default 09-04-2017, 03:54 AM
Originally Posted by Stephtech
acording to Terry,
Cheers Buddy, thanks for the info
Russjonesr's Avatar
Car: Bmw e92 335i
Default 09-06-2017, 01:26 PM
Hi Guys,
Would be grateful of some advice? I have installed the BMS PI Controller...as directed on the first page
Black connects to ground
Red connects to JB4 power on green connector
Yellow goes to the BMS data cable #9
White goes to JB4 DB25 harness spot #15 (where meth blue would normally go)
Purple goes in the JB4 small gray subconnector #21 as read from the female side
I have also updated the slave chip and was already running 32.8 firmware. I made the advised changes to my original meth set up..changed boost additive to 0 (guess as its not mentioned in the instructions) and Signal Scale to 100. Also left Meth safety at 2 and Meth Psi at 7, do these need to change?
Is there any other settings that require change as i don't see any flow? Does PI work on all maps? Is there a trigger to enable/ disable PI? Is it linked to Ethanol setup?
Default 09-06-2017, 08:34 PM
Other than meth scaling set to 100, the other meth settings have nothing to do with PI.
All fuel biases need to be set to 50 to start and you need to have sufficient injector duty cycle for it to show up in the logs.
Default 09-08-2017, 12:35 AM
Hi Guys,
Stuck on the same situation. Running Map 7 and seeing no flow on meth in the logs and both bank trims are above 40.
Russjonesr's Avatar
Car: Bmw e92 335i
Default 09-08-2017, 02:44 AM
Like me I see you were running meth prior to PI...I queried with Trebila and he advised me below, although I haven't tested yet as I have still have a small fuel leak on the T from the fuel line which needs resolving, but worth a shot!
set meth trigger = 1,
set meth safety = 3
set meth scale = 100
Terry/ Steve...when selling these products it maybe a good idea to include the D-Sub extractor or offer it for sale? Ten a penny in the US, but not so easy to get here in the UK and not item you'd consider to be part of a "standard" tool kit?
For anyone who is interested the only company that have seems to have actually produced a decent online document to install port injection is AD Engineering. Yes, if you know your way around a N54 engine its straight forward but so is putting together an Ikea table, but the table still comes with instructions. 1) because it helps the less knowledgeable 2) Because its usually a legal requirement to supply user / installation guides!
Also the JB4 controller install guide is somewhat cryptic "Purple goes in the JB4 small gray subconnector #21 as read from the female side" why not say #8 on the male side you are actually changing? After reading this thread I know I'm not the only person to question?
Default 09-08-2017, 04:45 AM
Do I need to set the external trigger settings in the WMI settings to get PI to work?
Default 09-08-2017, 04:56 AM
set meth safety = 3
Thanks. I already have all that stuff set. Still not working. Im wondering if I need the External Trigger stuff set.
Default 09-08-2017, 05:03 AM
set meth safety = 3
I think I need to check that out. That might be my problem right there. Didnt even notice that.
Default 09-08-2017, 06:56 PM
"Also the JB4 controller install guide is somewhat cryptic "Purple goes in the JB4 small gray subconnector #21 as read from the female side" why not say #8 on the male side you are actually changing? After reading this thread I know I'm not the only person to question?"
Because the stock connector is a female connector.
If you have installation questions and have purchased a port injection kit from us, you are more than welcome to email us for support.
If you've purchased another kit, then I'd suggest you contact them.
Default 09-08-2017, 06:59 PM
I purchased a BMS PI controller from you guys does that count? I think I found my issue though. Just gotta test it out.
Default 09-08-2017, 07:22 PM
We'll help you with installation of the controller but there are a lot of companies selling kits with little to know support or understanding. When you purchase one of those kits, especially for meth, you should contact them for support as we do not offer tuning support for them.
Default 09-08-2017, 07:37 PM
I know Steve. I was just being a smart ass. I think I figured out my issue. My yellow pin is on 8 instead of 9 on the DB9. All other connections are good. Would that prevent PI from firing? I figured it would still work and just not send a signal to my app screen for meth trace.
Default 09-08-2017, 07:39 PM
On the DB9 not the sub connector for clarification.
Default 09-08-2017, 07:46 PM
No...it would not still work. That pin is the JB4 signal to the controller. Fuelen signal will still show in logs whether it is connected properly or not.
Default 09-08-2017, 08:00 PM
Ok thank you bro. I'll have to get my pin extractor out tomorrow and move it to the correct spot in the morning.
Default 09-09-2017, 11:11 AM
Steve thanks again bro. It was def the pin position. Meth and Fuelen signals now show on app and trims react accordingly. Thank you
Russjonesr's Avatar
Car: Bmw e92 335i
Default 09-10-2017, 02:39 AM
Hi Steve,
Correct this is a EOS rail....but its the JB4 PI controller I seem to be having issues with?
I created a new thread, with pics of the setup to see if anyone can highlight something incorrect? I have taken it apart 2 or 3 times to check the wiring and it looks correct?
http://www.n54tech.com/forums/showthread.php?t=49293
Also rechecked the earth, but again this was located in the same place as the the FSB earth.
Default 09-10-2017, 09:17 AM
Hi Steve,
In your logs fuel-enrichment is the request from the JB4 to the controller, and "meth" is the reply back (when meth flow scaling set to 99). I see no request and no reply.
It seems you have fuel-bias all set to 0? That would disable PI all together. Default those to say 50 to start.
Russjonesr's Avatar
Car: Bmw e92 335i
Default 09-10-2017, 10:56 AM
Thanks Terry,
You were correct, see its idiots like me that can read! I was looking at Duty Bias not Fuel Bias!
the machine the machine is offline
Car: 08 bmw 335 coupe dps, jb4, fmic, afe intake
Default 11-14-2017, 08:57 PM
Hey I have 2008 bmw 335 with split second aic6 controller jb4/mhd what should my sittings be on the jb4?
