(#51)
frmtl2_335i's Avatar
frmtl2_335i frmtl2_335i is offline
Car: 07 e92 M/T
Default 09-16-2013, 06:24 PM
Is this update available yet? I know once I loaded the e85 map through open source last week the car felt just AMAZING, then I blew the front turbo lol.
FFTEC 6466 Gen2, MHD Flash Tuned by Wedge, BMS PI Kit, FUEL-IT Stg 3 pump, HALTECH PS-1000, MFactory LSD w/lock down brace, ECS Trailing Arms, M3 control arms, M3 brace, DGR Coilovers, N20 tmap sensor, BMS OCC, VRSF exhaust w/4" tips, VRSF CP, Tial BOV. BigTom FMIC, Msport front & rear, m3 sides skirts.
12.23 @ 118.9mph (RBs)
2.3 60' lol (single pass night, bog shifting)
Car: 07 e92 M/T
Default 09-16-2013, 06:44 PM
What was the additive? Pure meth? Single nozzle? Size?
GetSomeE92 GetSomeE92 is offline
Car: '09 E92
Default 09-16-2013, 08:24 PM
Reading this thread has me on the verge of going "add to cart" and going full bolt on.
Too many other bills... must resist...
335i Coupe: E85 BB flash, JB4 G5 ISO (map 7), DCI and 60% E85 blend: 11.7 @ 120 mph.
Former Best with JB4 (G4, map 5) DCI and 40% E85 blend: 2009 BMW 335i Coupe: 12.173 @ 109.490 MPH
Default 09-17-2013, 08:23 AM
No we've not posted these maps as I'm not 100% confident they are safe in the real world yet. But, I've had an MT customer put down ~470rw using map 7 and the new E85 flash. So you can get close with the published stuff.
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 09-17-2013, 10:34 AM
Just wrapped up some dyno testing on our E92 MT. Mods include the JB4, BB flash, BMS **, BMS DCI, CPE BOV, CPE IC, and BMS OCC. Factory catback system & midcats. $100 inline fuel pump. Spec clutch w/ steel flywheel.
Great work putting up those numbers!
Any comments on the Spec Clutch??
Default 09-17-2013, 10:36 AM
Some rattle at low idle but works great. I'm a fan.
Vroom's Avatar
Car: 335i 318ti
Default 09-17-2013, 10:44 AM
What stage?
Have you been to the dragstrip yet?
Car: 07 e92 M/T
Default 09-17-2013, 01:06 PM
These are dynojet numbers right? Not mustang dyno numbers...
How do you think this new e85 map will do with RB's????
Default 09-17-2013, 01:19 PM
For RBs I'd suggest the RACE maps which will do anywhere from 500-530rw depending on the boost curve used. The E85 maps are too lean and too highly advanced for RB turbos.
bnk bnk is offline
Default 09-17-2013, 09:27 PM
What happens with the too high advance with upgraded turbos?
Default 10-29-2014, 08:19 AM
This is the current stock turbo dyno record. Until someone does more than 481whp on a dynojet stock turbo it will stand...
Newguy123's Avatar
Newguy123 Newguy123 is online now
Car: 12' 135i
Default 10-29-2014, 09:38 AM
subscribed
12' DCT 135i
#PURETURBOS
#FUELIT
Spxxx's Avatar
Spxxx Spxxx is offline
Default 10-29-2014, 02:29 PM
how many miles were on these turbos at the date of this dyno run?
Also, how long were they run for?
I want to get an idea of how robust these turbos are after 50k+ at 17psi etc
I know the same frame turbos are used on older WRXs which are generally pretty reliable and are often tuned to run much higher boost than what we're running.
Default 10-29-2014, 04:29 PM
The factory turbos are very durable at higher boost levels. But at these power levels they are blowing a lot of hot air and operating under 2-3x back pressure and its the pistons you really need to worry about. There have been several blown motors with guys trying to push factory turbos too far. Much more so than large turbo blown motors from what I've seen. Which should tell you something.
Spxxx's Avatar
Default 10-29-2014, 04:51 PM
How much does running stock cats effect operating temps of turbos?
@ high boost levels ~ 17psi
m4xbmw7's Avatar
m4xbmw7 m4xbmw7 is offline
Car: F02/E82
Default 10-29-2014, 04:54 PM
Hey Terry what E85 flash is this you speak of ?
musc's Avatar
musc musc is offline
Car: 335is DCT
Default 10-29-2014, 05:54 PM
http://www.n54tech.com/forums/showthread.php?t=20563
Same E85 flash that has been out there for awhile. Runs a few degrees more timing compared to the RACE flash.
335is DCT
m4xbmw7's Avatar
Car: F02/E82
Default 10-29-2014, 06:15 PM
Ohh old thread lol that's the flash I run
BuraQ's Avatar
BuraQ BuraQ is offline
Car: 335is DCT
Default 11-13-2014, 02:20 PM
Bump
Hey Terry this record still stands right ? If so we got a suprise for you on a 6AT I will leave Ken to post it. To tired right now, need to go check my blood preasure
2011 E92 335is w/DCT
2007 E92 335i 6AT
techmaster05 techmaster05 is offline
Car: 07 335i
Default 12-26-2014, 08:14 PM
Hey terry can I get your email?? I want to talk to you about tuning. I've been trying to track you down an send you a pm on bimmerpost and bimmerboost but the pm option is not available for you.
m4xbmw7's Avatar
Car: F02/E82
Default 12-26-2014, 08:49 PM
terry@burgertuning.com
Puppydax's Avatar
Puppydax Puppydax is offline
Car: 07 E92
Default 03-07-2016, 08:31 AM
Thread revival to ask, which Spec clutch was used on this vehicle?
6MT / JB4 G5 ISO / BMS E85 Backend Flash / AR 3" Kittenless **'s / VRSF 5" Stepped FMIC / Stock CP (Lol) w/ ActiveAutowerke BOV / Godspeed Adjustable Toe Arms / Inline GSL392 pump / PE Mod w/ Magnaflow 4" Tips / BMS DCI's / H&R Sport Lowering Springs / BMW Sport Suspension / OEM Front Aero Lip / Mtech Rear Bumper with Performance Diffuser / 19" Gunmetal VMR v710
Default 03-07-2016, 08:39 AM
I wish we had put inlets on this car as it was...
Clutch was some spec single disk. I forget which one. Steel flywheel.
Puppydax's Avatar
Car: 07 E92
Default 03-07-2016, 08:50 AM
Inlets, drooool. I only ask because I will be making
Similar power and an questioning my decision on purchasing the 2+ and thinking if it'll be enough lol.
baskgto baskgto is offline
Car: z4 35i/e93 335i
Default 06-22-2017, 10:08 PM
Fuel for today was E85 mixed with 91 octane. Around E60. Although there is probably a few more HP in there with E70-E80. Dyno room temps were in the low 90s. Fans were pretty good.
The only changes since last time around (461rw) are on the tuning end. More advance, leaner air/fuel ratios, a slightly different VANOS curve, and some boost curve changes when the meth is flowing.
The E85 only runs were on map 7. You'll notice the timing curve was consistently a bit aggressive around 6000rpm. On the two best E85 runs the dyno tach pickup skipped a beat so be sure to look at the torque curve and not just the peak numbers.
With meth I decided to crank the boost up as much as I could. I also left the more aggressive timing curve in place. Basically, I was going for a max effort setup. And the car delivered with 481rw. On the advance to my surprise I found it was still aggressive up top even with meth flowing. This curve is going to need E70 up top + meth I suspect. I'll back it down up there for now.
Anyway, very happy to have the stock turbo dynojet record back in our corner.
how many psi?
