(#101)
PrzeChuj PrzeChuj is offline
Car: 08 335i
Default 08-05-2017, 07:02 AM
Terry this may be a stupid question. But does adjusting FF and duty bias only change it for current map or are the changes happening across the whole map selection? If I'm running map 2 with bef and decided to throw in a higher ethanol mixture and run map seven would I have to fine tune it also? And if so when I go back to map 2 are my changes saved?
e92 MT 08
FBO
450 lpfp
BEF
Default 08-05-2017, 09:00 AM
For twin turbo N54 firmware the dutybias settings are global for all maps. Once the curve is set properly it should scale properly across all plausible boost profiles.
Car: 08 335i
Default 08-05-2017, 09:36 AM
That makes life alot easier once the curve is set. Love the bms product line and support you guys are unmatched in the tuning world. Would u recommend me setting my curve and then finishing my meth system and set it up after words or before ?
e92 MT 08
FBO
450 lpfp
BEF
Default 08-05-2017, 12:35 PM
I'd dial it in close to what you expect to run for a boost profile most of the time.
zort zort is offline
Default 08-05-2017, 03:55 PM
This is good info.
orteeze orteeze is offline
Car: 08' 335i
Default 09-13-2017, 01:56 PM
In regards to the N55 DB Tuning on a PS2, if I disabled FF and my boost target is fairly close, but there is still some separation between FF and PWM; do I continue raising FF? Wouldn't that throw me over target?
E90 LCI M Sport
Default 09-13-2017, 03:38 PM
It's a pneumatic system so you just want FF in the ballpark. The PID will drive boost to target as long as its ranged closely. Once done FF learning should be on to account seasonal changes and WG wear and tear.
tho's Avatar
tho tho is offline
Car: 2011 335i Convertible
Default 09-15-2017, 11:27 AM
What are the risks of leaving FF learning off? I've found that if I am tuning with strictly 2500-6500 pulls, FF will optimize to that, but then if I'm driving around and decide to do drop 2 gears and blast off from 4K, the FF then starts to learn down (due to overboosting), if I do that enough, it makes going back to tuning 2500-6500 slow because it needs to learn back up. It makes my car feel inconsistent due to my most recent driving style.
At the moment, I've turned FF learning off and have found a decent setting for 2500-6500 tuning. This setting also has minimal overboost (that I've seen) when blasting off from 4K. I'm less worried about the overboost as my current setup doesn't seem to be affected by it. That being said, I'm pretty neurotic about my logs and evaluate almost every one.
Are there other risks that I may not be thinking about? Any suggestions on other solutions to this issue?
2011 335i - JB4 ISO | MHD E85 PI BEF | Exhaust Mods | CP | 5" stepped FMIC | BMS Meth Injection through Fuel It TBI | BMS Intake | Pure Stage 2 | Pure Inlet | FF wires | Fuel It Stage 2 | DV+ | N20 TMAP | Ethanol mix
inevitab1e's Avatar
Car: 2013 N55 135is
Default 10-29-2017, 05:28 PM
What is the maximum DB value that can be entered by RPM? 50-100 range?
2013 E82 135is N55 JB4 FBO e30
Default 10-29-2017, 05:36 PM
0-100 range.
Default 10-29-2017, 05:37 PM
The problem with leaving FF learning off is weather and barometric pressure changes can have larger differences than you'd think on required WGDC, so by locking it, you prevent the system from being able to slowly adapt. Think of the FF learning as a really flow I factor.
Constantine Constantine is offline
Car: 2010 335i xDrive
Default Help with FF & Duty Bias Tuning - 11-10-2017, 02:02 PM
Hi guys,
My N54 335i seems to be cutting power from time to time and the JB4 goes to map 4 with a too lean condition. Changed spark-plugs, coils, low fuel pressure sensor as well as one of the O2 sensors that was giving me trouble (bank2).
I am attaching a jb4 log. I would appreciate any knowledgeable forum member's help / comments on the following:
1. My boost is below target for while - turbos taking too long to spool?
2. My AFR and AFR2 go over 15 for a bit, and that's when the car cuts power.
3. E85 of 66? What does that mean? I am running pump gas, usually 94 octane without ethanol or 91 with 10% ethanol - that's all I can get in Vancouver, BC, our one E85 station closed down.
4. Does my WDGC dropp from 99 to 25 too early while boost is 4 psi below target? If so, how do I change that? Run map 6 with what kind of parameters?
PS. I have ******* ***, stock trubos with the dreaded wastegate rattle (unless I keep the Default Wastegate Position under 27).
I would appreciate any help.
Default 11-10-2017, 02:04 PM
Not a WGDC tuning issue. Your fuel trims show you're dropping to open loop mode. Probably need to target less boost OR add in a back end flash map.
Default 11-10-2017, 03:07 PM
Thanks Terry for the quick response!
I'll try to add a back end flash map - what would you recommend? I don't have easy access to e85, I can get 94 octane gas without ethanol or 91 with 10% ethanol. Which fuel and what back end flash map?
Also, what does a value of 66 for e85 in the log mean?
Default 11-10-2017, 03:23 PM
Load the PUMP BEF.
The E85 reading means nothing unless you've configured the virtual flex fuel sensor or have a hard wire sensor installed.
yellowfin's Avatar
yellowfin yellowfin is offline
Car: 335xi - jb4 - DCI
Default 11-11-2017, 10:40 PM
I have a similar experience. On the track, FF learning would probably be great, but under DD conditions, different story. I spend so much time in traffic in the low-load 1000-3000 rpm range, during which FF leaning can go anywhere. Then every once in a while, when I get to punch it, FF may not be where it should be. So, I have fixed FF and rely on the 30% PID gain (which is probably mostly P, maybe little bit of D, but no I)
Are there any details available on FF learning (if it's not proprietary information)? Length of time integral? Min load for learning? Does it learn in spool mode? (Should not, because it's underboost by definition)
2007 335xi -- VTT GC lites + inlets + outlets -- Fuel-it stg 2 lpfp -- CPE catted **, FMIC, CP -- Tial BOV -- BMS DCI + OCC -- RB PCV
JB4 + BMS bef (E50)
Wickedowesix's Avatar
Car: 540i G30
Default 12-04-2017, 09:43 AM
Good info
Default 12-04-2017, 09:49 AM
Generally only learns at full or very heavy throttle, post spool, etc. If you're having an issue just capture some logs of it "learning wrong" and we can work backwards from that to evaluate/correct.
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 12-04-2017, 12:21 PM
Great discussion and process of making things better and better!!! I love this community!!
Getting there: '07 E92 6mt, MMP stage3 hybrid, MMP Inlet/Outlet, MHD BMS PUMP BEF, 3.5 bar, E30, BMS JB4 G5 ISO, Fuel-it! Stage 2 LPFP, FBO, Synchrotech(MFactory), Bimmerlife R8 coils, N20 plugs(0.026")
spammer spammer is offline
Car: 435i
Default 12-06-2017, 09:40 AM
Woohoo - i finally understand this. Followed everything (after reading it about 20 times over 6 months) and got my ff/pwm readings near identical which incidentally keeps my boost/target lines damn near identical.
Thanks for the write up T!
Before
After
Performance: 2014 435i : F33 (convertible) : 8AT : BMS Intake : VSRF Charge Pipe : JB4 Stage 2 : FF Wires : EWG Wires : 30% E85 + 93 Octane
Bling: CF Lip, Rear Diffuser, Mirror covers | Burgers 18MM spacers back, 12MM front | Burgers chrome tips.
yellowfin's Avatar
Default FF learning details - 12-09-2017, 08:58 PM
Terry, thanks for the info.
Attached is a log. I was starting around 4000 rpm and was a bit surprised to see WGDC at 100% all the way up to 4500 rpm, whereas the max spool rpm in the bef is only 3500. Is this a jb4 function for "spool" emulation at higher rpm?
Does this "post-spool" count into FF learning? This would explain my impression that under DD (many brief 1-2s accelerations that never really get boost to target), FF learns up too high. Then, under prolonged WOT, trending back down (note how WGDC is first above, then below FF).
JB4 + BMS bef (E50)
