pysical pysical is offline
Car: 2009 335xi
Default Flex Fuel - 09-12-2017, 06:07 AM
Anyone know what the latest on Flex Fuel is? I am going with some GC turbos and want to take advantage of E85 on these but I don't want to go through the hassle of 50/50 mix and such. I know MHD was working on doing something that would take a 100% E85 tune and scale it according to the E content but wasn't sure. Does this exist for us yet?
And, if this does not exist and I have to get a tune specific to a E85 mix.. What sort of E85 blend can I run with PI, stage 2 LPFP, and running GC turbos.
Thank you.
Default 09-12-2017, 07:41 AM
With the JB4 you can run its internal virtual flex fuel sensor, or add on a Fuel-IT physical sensor, and the JB4 will use either to rescale port injection as needed for the specific mixture.
With a Stage2 low pressure pump probably starting with a 50% mix is good and then evaluate from there.
Car: 2009 335xi
Default 09-12-2017, 07:45 AM
Will JB4 modify timing, fuel, boost, etc to run higher HP based on the fuel-it physical sensor? I just want to run whatever fuel and let the car tune based on the E85 content. I don't want to have to mix 50/50, and do all sorts of different tunes.
Default 09-12-2017, 11:19 AM
We have not tied the E85 value to the boost/timing mapping yet on the normal maps, but you've got map5 there which does that using an auto-tuning technique. We'll be adding another flex fuel auto tuning map in the near future though that relies on the E85 value.
bnk bnk is online now
Default 09-12-2017, 12:47 PM
As far as I understand, this does not work in many N54 335i cars.
Default 09-12-2017, 02:06 PM
What does not work in many N54 cars?
erichale's Avatar
erichale erichale is offline
Car: 335i coupe
Default 09-14-2017, 02:15 PM
He probably is referring to the KLINE cars.
07 335i AT/CUSTOM 6870 GEN2 ST/VAC ENGINE AND STAGE 3 HEAD/FABFACTORY INTAKE W/PI/1000HP AD FMIC/FUEL IT STAGE 3 LPFP/HKS BOV/BL COILS/DUAL OIL COOLERS/RB EXTERNAL PCV/PD TRANY W COOLER/M3 FRONT N REAR SUSPENSION W/ROUGE BEARINGS/HOTCHKIS ADJUSTABLE END LINKS/ADUSTABLE REAR TOE ARMS AND CAMBER LINKS/EIBACH SWAYBARS/BC RACING BR COILOVERS AND CAMBER PLATES/AKG REAR SUBFRAME, DIFF, REAR SHOCK BUSHINGS/POWER FLEX BUSHINGS/WAVETRAC REAR DIFF WITH DEFIV BRACE AND VAC COVER/4IN EXHAUST
Default 09-20-2017, 12:08 PM
These flex fuel features that you talk about. I was about to buy JB4 for getting flex fuel, but I was told that it requires a specific D-CAN bus. I don't know anyone in my neck of the woods who would have that.
