(#101)
Default 06-26-2017, 07:13 PM
Fuel pressure is normal in the logs attached... Where is the log of it dropping?
afranke afranke is offline
Car: 2013 ActiveHybrid 3
Default 07-06-2017, 01:00 PM
Been running T6 for a few days now on map5 with the N20 TMAP and so far things seem to be running well overall (no codes, limps, or any crazyness). The one thing I'm currently wondering about is the IAT resistor mod. With a BEF, do I still need this? It seems as if AvgIgn actually increased overall when I added it back in. I'm not seeing quite as much boost as I'd like, and I'm wondering if this is the cause. Logs coming shortly, probably on the commute home today.
cnm135i cnm135i is offline
Car: m135i
Default 07-06-2017, 02:02 PM
Not needed with a BEF. Not really sure it was ever >needed< - more just a safety precaution at the expense of very few horses.
911Y4's Avatar
911Y4 911Y4 is offline
Car: 435
Default 07-07-2017, 11:21 AM
Hi Terry,
Today I test ISO7 T3 again with E45 and PI on 4th to 5th gear. I set all AFR bias to 50. However my fueling went to open loop right after gear shift and HPFP pressure was dropping. (Log attached)
*i have noticed to avoid open loop, my 4th gear trim must be above 25 before gear shift. If it is below 25, it must go to open loop after gear shift.
Could you please provide advice how to overcome trim stuck at 25 and FP_H drop? Thank you for your valuable time and help!
Li Wang
BMW F30 335xi PWG N55 1/4mile 11.111ET @ 126mph
BMS JB4 ISO / PTF Bootmod3 / Pure N55 stg2 Turbo / Fuel-it PI + stg2 LPFP/ Wagner EVO 2 Competition FMIC / E30 + Meth
In Shanghai
Default 07-07-2017, 11:22 AM
If fuel pressure is dropping you need more port injection or meth flow.
911Y4's Avatar
Car: 435
Default 07-07-2017, 06:11 PM
Hi Terry,
Thank you very much for your quick response. Here is a new log (same fuel E45, same boost and same port injection) (BMS PI controller)
I set all AFR bias to 70 instead of 50 for more fuel, you can see the trim goes to negative, but fuel pressure still drops after gear shift (4th to 5th) and car went to open loop and trim was stuck at 25 after gear shifted
Could you please help, thank you for your advice!
Li Wang
In Shanghai
Default 07-07-2017, 10:43 PM
Just got the JB4 app update, should we worry about the new settings at all? I'm using the FlexFuel wires and have WMI hooked up, but no PI as of yet.
michaelsoft michaelsoft is offline
Car: BMW F30 335i
Default 07-08-2017, 12:11 PM
Got JB4 app update also, I'm using Fuel-it Meth PI, any setting need to be change / enable under WMI ethanol setup?
Default 07-08-2017, 11:31 PM
Got some Map 3 logs today, things feel pretty good overall, but sometimes it seems to just cut/hang at high RPM right before shift. I also noticed with the most recent iOS app update that sometimes it seems to lose the connection and the logs go missing, so I don't have all the data I thought I did.
Default 07-09-2017, 10:02 PM
Oh, also, what's max boost target on map 5? 18psi still? Does it increase with the N20 TMAP sensor?
obriennathaniel's Avatar
obriennathaniel obriennathaniel is offline
Car: F30 335i
Default 07-14-2017, 01:49 PM
wow, I had no idea this was out lol. but wow I really don't want to lose my code clearing capabilities.
CG Precision VS-1 Exhaust\DR-1 | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | JB4/ACF Performance w/BM3 | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge|
Car: 2013 535i (N55 F10)
Default 07-14-2017, 02:03 PM
The N20 sensor doesn't give you more boost, but the stock 2.5 Bar sensor maxes out and 21 PSI and cannot read higher boost pressures. If you plan to boost more than 20 PSI you should upgrade the TMAP sensor.
2013 F10 535i N55 PWG, Pure Stage 2, Wagner FMIC, ER Charge pipe, ER **, BMS Intake, JB4, Fuel-It Stage 2 LPFP, Fuel-It Platinum PI Kit, BootMod3 Flash, Remus Exhaust, Custom In-let
1999 e36 M3 - Future Track Car
Default 07-14-2017, 02:05 PM
Yes, I know this. I'm asking if the target on map 5 increases when using the N20 TMAP sensor, since it is able to read more boost overall. Sorry if that wasn't clear enough for you.
Suckadeez's Avatar
Suckadeez Suckadeez is offline
Car: 2011 335xi
Default 07-14-2017, 02:54 PM
map 3 did for me. without changing the additive. with a 80 add I hit 23-24 psi. stock turbo
2011 335xi e92
deep sea blue metallic
Mods: ps2; cobb fmic; vrsf ⬇️pipe; phoenix racing cp; injen cai; pure inlet; fuel it stage 2 lpfp w/ sensor; jb4 w/mhd e85 bef; meth 90/10 do3 and do7 nozzles. n20 tmap. Alpina flash. Fuel it port injection e50
Car: F30 335i
Default 07-15-2017, 01:24 AM
So I sent my three logs to terry as Iím on my iphone and donít know how to post them on here lol but I do have a question about the FUD settings as mine donít match the details in the first post. Why are mine different options?
Default 07-15-2017, 06:18 PM
I thought max additive value was 75?
Car: F30 335i
Default 07-16-2017, 03:58 PM
So i flashed the newest ISO firmware and damn the car drives so much better. No more hesitation and the boost is always there. its a world of a difference.
attached some logs, i know there is room for improvement but im so rusty at adjusting my JB4 i dont know where to begin
Sicmadek Sicmadek is offline
Car: 2013 335i sportline
Default 07-17-2017, 10:22 AM
Just curious as to why you have dwp at 60 instead of default 80
Car: F30 335i
Default 07-17-2017, 11:26 AM
after 3 years of adjusting my jb4, from my own adjustments and from Terry and other tuners, that's just where it ended up lol. I have no idea when it was set to 60. I'm going to flash back to my stock tune and see if I get any improvement on these logs as my current BEF is still extremely unfinished by Ricardo, then Dzenno will start building me a BEF.
Default 07-17-2017, 12:13 PM
The DWP setting of 60 or 80 doesn't matter much especially on the N55.
Default 07-17-2017, 12:23 PM
Then whats the point of it on a f series? Default is 80 so what happens when i lower it 20 at a time? I just lose responsiveness?
Default 07-17-2017, 12:25 PM
It's just a setting that has to be defined. Since the N55 turbo makes ~3psi with no WGDC at all where you set it has no real significance.
Default 07-18-2017, 09:50 AM
Well i cant keep myself from trying new things so ill give it a try tonight. Who is still on the stock turbo?
Car: F30 335i
Default 07-18-2017, 09:54 AM
I think Dejan is going to try it, heís stage 1 though, not stock but close lol I flashed back to my stock map and itís WAY better than the previous logs I just posted lol I lost all confidence in Ricardo, what little I had left for him after he went ghost.
Default 07-18-2017, 09:57 AM
Must be the same guy dejan was telling me about
HeikkiV
