cebrailbakan's Avatar
Car: BMW E90 335XI
Default Questions on Vp racing race fuels - 07-18-2018, 06:53 AM
Could anyone who have enough clearance answer the question ?
which of the following ( ms100, ms103 , vp vintage ) or which are suitable fuels for my highly modified n54 335 xi ?
Specification sheets attached.
Full Bolt Ons, Forged Internals, Meth PI, JB4 PI contoller, Zage Turbos, TFT inlet system,xHP Stage 3 trans Flash.
Do more with less !
Default 07-18-2018, 07:45 AM
Ms109 is what I usually use if I don't have e85 available. Ms103 is prob the best bet if you can't get that.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 07-18-2018, 08:19 AM
Just make sure you don't use leaded, of course.
Also be aware of oxygenated vs non-oxygenated fuel, especially if you're switching from one to the other and are close to the limit on fuel delivery.
2009 535i Sport - 548whp
Software :
Car: BMW E90 335XI
Default 07-18-2018, 09:36 AM
Can I use it for daily drive ?
Do more with less !
Car: BMW E90 335XI
Could you please tell which of the fuels above I can use normally ?
Do more with less !
LessIsMore's Avatar
Inner Circle Member
Default 07-18-2018, 11:00 AM
MS103 would be my choice, from your list.
Software :
Car: BMW E90 335XI
Default 07-18-2018, 11:28 AM
But it is oxygenated ?
Do more with less !
Default 07-18-2018, 11:57 AM
I believe it is oxygenated. I don't know if I would use that gas for a daily, I can't afford it LOL.
Car: BMW E90 335XI
Default 07-18-2018, 11:59 AM
I can easily afford as I am the sole distributor of Turkey but it doesn’t solve any of my problem. LOL
Do more with less !
LessIsMore's Avatar
Inner Circle Member
Default 07-19-2018, 12:12 PM
Says it is right there in the info you provided.
The issue with the oxygenated is only that it is less dense, and would require more volume of fuel being delivered. Thus my comment that if you are near the limits of your fuel system, and you switch from non-oxygenated fuel to oxygenated, you could go over that line of not having enough fuel delivery without realizing it.
I don't think there is anything 'bad' about oxygenated, per se.
Seriously - why aren't YOU the one telling US all about fuels, then?
Software :
Car: BMW E90 335XI
Default 07-19-2018, 12:16 PM
Less is more , I wasn’t taught by Vp , everything is very new at being distributor, I purchased the fuels upon demands , I just want to learn the experiences of the folk in this forum. Thanks in advance
Do more with less !
LessIsMore's Avatar
Inner Circle Member
Default 07-19-2018, 12:43 PM
No worries, here to help, just giving you a hard time
As long as the race gas is unleaded, you can run it all the time if you want.
Software :
idratherbesurfing's Avatar
idratherbesurfing idratherbesurfing is offline
Car: 06 STI
Default 07-21-2018, 01:25 PM
Vp fuels ive ran in my 335 with no issues. All were adjusted accordingly and felt different.
Ms100
Ms109
C16
Q16
C85
Car: BMW E90 335XI
Default 07-21-2018, 01:31 PM
Q16 is leaded and not proper for our cars , how did you run with it ?
Do more with less !
Car: 06 STI
Default 07-21-2018, 05:02 PM
Rear 02 sensors coded out. Made a couple 750whp pulls zero issue.
And dont forget it smells like heaven
LessIsMore's Avatar
Inner Circle Member
Default 07-23-2018, 10:10 AM
Leaded gas won't immediately ruin anything - you could probably run many gallons of it before you start seeing issues. However, it is certain it WILL happen. And the exhaust becomes a lot more poisonous.
Software :
