(#101)
Car: F06 N55 640i Gran Coupe
Default 06-28-2018, 01:51 AM
F series instructions:
1- Remove FSB, only use PI controller
2- Yes, correct.
3- It should be Pin #3, you can just pull it out or cut wire/leave it.
4- PI white wire will go to Pin #16
5- Yes, correct.
6- Purple signal wire needs to be extended to OBD Molex.
Thanks Payam,
Just need to be very sure on item 6. How to pin into the obd Molex & into which slot?
2014/2009 M4/335 COUPE
AndyTuning Custom Map 6
SS ** n FULL Custom Exhaust
Custom BC forge 18/17 set up
Default 06-28-2018, 03:06 AM
Originally Posted by andym3100k
Thanks Payam,
Correction, yes the previous Pin 3 removed, Pin 16 & Purple wire are all still the same as previous.
But after logging I noticed Meth not spraying, can I try to use JB4ís orange wire to trigger the Relay instead of using PI Controllerís Yellow wire?
Default 06-28-2018, 09:46 AM
The FSB should be removed all together, shouldn't be in the equation.
cebrailbakan's Avatar
Car: BMW E90 335XI
Default 06-28-2018, 10:07 AM
Put the blue wire in its place , set meth scaling 60 , FSB should be in equation to take advantage of safety systems and monitoring the meth flow. White cable for PI and blue cable for meth don't control anything, they only monitor, that is why you can only run one or the other.As soon as we see that PI is working as it should, then you can disconnect the white wire and return to the blue wire to monitor meth.
Make sure for monitoring PI, meth scaling is set to 100, to monitor meth when the blue wire is installed, set meth scaling to 60. Keep up with the blue wire then set your meth psi to 4, meth safety to 3, meth trigger to 0, and all your fuel biases to 50 and post a log.
Full Bolt Ons, Forged Internals, Meth PI, JB4 PI contoller, Zage Turbos, TFT inlet system,xHP Stage 3 trans Flash.
Do more with less !
Default 06-28-2018, 03:45 PM
Yes, FSB was removed but is not working
Default 06-29-2018, 08:29 AM
Had confirmed with Terry, not all PI controller will have those Thick Yellow or Orange wires at least mine donít.
I have 2 Meth pumps, 1st pump goes to the PI Meth, 2nd pump went to the CP. Now by adding a Relay (JB4-FSB-Relay-Pump), they worked well for my setup (S55).
S55 F82 M4
Car: BMW E90 335XI
Default 07-16-2018, 09:17 AM
Which relay ? Where can we buy and how can we add to that setup without zero issues ? Could anyone please expand this we are so tired anymore !
Do more with less !
Default 07-16-2018, 09:19 AM
A universal 30 amp automotive relay is normally used.
Car: BMW E90 335XI
Default 07-16-2018, 09:28 AM
So , is it not risky if it triggers all the time ?
Do more with less !
Default 07-16-2018, 10:19 AM
It should only be triggered at a certain psi via hobbs.
Car: BMW E90 335XI
Default 07-16-2018, 03:41 PM
By saying hobbs do you refer to the one in the picture ?
Do more with less !
Car: BMW E90 335XI
Default 07-18-2018, 01:47 PM
Are those who are running 7th injector in the charge pipe need an additional meth pump , assuming per injectors need 40 psi to run and the meth pump capacity’s is just only 200 psi ?
Do more with less !
Car: BMW E90 335XI
Default 07-19-2018, 03:34 PM
do we need a single bigger pump or can I use 2 x 200psi pumps (one for the Port and one for the nozzle)?
If we do, am I going to have to upgrade the fuse?
Do more with less !
Default 07-20-2018, 12:23 PM
1 pump should flow enough.
Car: BMW E90 335XI
Default 07-20-2018, 12:40 PM
Incorrect. I tested it. The pressure for both is quite heavy. IAT dives up only for second then raises badly. FYI payam.
Do more with less !
Default 07-20-2018, 05:04 PM
Did you do the math? You can up the pressure to the pump. Each pump should be about 1.3 GPM
mattgu40 mattgu40 is offline
Default 07-21-2018, 12:46 AM
correct me if im wrong.
1.3GPM @0Psi.
0.10Gpm @200psi ??
Tuppidsay Tuppidsay is offline
Car: 2008 535i
Default 08-08-2018, 09:29 AM
My install is done. To activate the system I set fuel bias/enrichment values as needed and meth scaling to 99. And it just works? What maps will it be active? If i need to disable for any reason do i need to reset fuel bias to 0 or meth scaling to 0?
2008 BMW 535i SPORT - FBO - VTT GC LITES - JB4 - Custom BEF - BMS METH - PROMETH PI
Default 08-08-2018, 09:34 AM
Log it and evaluate on a conservative map like map2 to start.
The Fuel bias is what determines the PI flow so setting them all to 0 would disable it.
Default 08-08-2018, 10:18 AM
1.3GPM @0Psi.
0.10Gpm @200psi ??
Cap is @200psi which should never be set at. Usually 150 psi .6GPM from our data sheet
Car: 2008 535i
Default 08-08-2018, 07:32 PM
Looks pretty good so far for a preliminary map2 pull. Pump bef
Default 08-08-2018, 08:31 PM
I agree it does look good!
Car: 2008 535i
Default 08-08-2018, 11:03 PM
Just realized I'm not getting a signal on the meth pid... Hmm I'm not using a fsb and not seeing much of a dive in fuel trims. Maybe it's not so good?
Default 08-09-2018, 09:13 AM
No, you want to look at fuel enrichment. There is a signal so you know it's working.
Car: 2008 535i
Default 08-09-2018, 02:26 PM
Ok I must have miss read then. I was under the understanding that fuel enrichment was the signal from the jb4 to the pi controller and then the pi controller would send a signal back to the jb4 via the meth pid that it was activating. Hence the reason to set meth scaler to 99
