Getu1 Getu1 is offline
Car: 535i
Smile First n54 log with new Turbos and FBO - 01-13-2018, 04:18 PM
Hey everyone,
Itís winter here but Just took my e60 n54 out for a quick run to do some pulls on map 5. Long story short just installed Pure Stage 2 DD Turbos and FBO including ******* *********, inlets and outlets, 7Ē FMIC, turbosmart BOV, Jb4 with Rev3 (iPhone app) and MHD flasher app on an android device. (BEF options or custom tune)
Iím new to this whole logging stuff and wanted to see where I need to start. Attached are 2 short logs.
Sorry for the super newbie approach but could use some help to get my car locked in with what I have available right now until I can get a custom tune down the road. At a glance it looks like my evil psi is not hitting the target boost levels on map 5. What could this be and how can I make tweaks to fix? Anything is looking outta wack? How can I fix?
Thanks all and look forward to this journey of n54 boost
Haynpunch's Avatar
Car: 07 E90 335i
Default 01-13-2018, 08:46 PM
Im pretty new to this stuff too. With stock turbos I know to start you would need to set your JB4 settings to default http://www.n54tech.com/forums/showthread.php?t=10605
then let you can let map 5 adjust on its own. im not to sure with the set up you have also I think you gotta do a pull from 2k to atleast 6k RPM, pic a gear 3rd or 4th to get good data
07 E90 AT 335I 130k
JB4 G5 - E85 BEF
DCI
VRSF CP - TS RP BOV-Orange Spring
VRSF D-P's
Stage 2 Bucket
Stock FMIC - Backordered
Default 01-14-2018, 10:30 PM
As mentioned, you need to set your user adjustments to the defaults. Your current setup is incorrect and will cause a lot of issues.
Car: 535i
Default Yesterday, 05:20 AM
Thanks both, how do I set the user adjustments do default? When I go into the app and click user settings everything says 0 and there isn’t a button or options to hit default.
Can someone let me know how to do this? Once this is done do I then select map 5 again and do some logs? Thanks
Default Yesterday, 10:36 AM
You will have to enter them manually and save them while connected to the car.
Yes, once that is done, do a log on map 5.
Car: 535i
Default Yesterday, 10:46 AM
Ok sounds good. I’ll do a search and see if I can find the default settings numbers. I’ll post new logs once I get a chance. Thanks
Default Yesterday, 03:51 PM
This is the thread you should be monitoring for firmware updates and information.
Car: 535i
Default Yesterday, 04:18 PM
Thank steve, I literally just saved that link. I’m going to update my firmware as my jb4 is running IOS 7202. Thank you for the help, much appreciated and I’ll post back once I update jb4, input default user settings and then run some logs on Map 5. GREAT SUPPORT!!
Car: 535i
Default That was easy - Yesterday, 06:58 PM
Updated firmware and took 2 more quick logs.
How do these logs look? Anything need adjusting or an issue? Car pulls consistently pulls harder now with the suggested update. Seems that boost drops off at higher rpms which may be the 17psi limit but it feels good. Also feels like there is some lag and boost doesnít kick in until 3k rpm.
Thanks for the continued help and Iíll be sure to search through the forums.
135iam 135iam is offline
Default Yesterday, 07:18 PM
Those logs are not very good. You need to log from 2000-6500 rpm WOT in 3rd. Also turn on ign logging for cylinders 2-6
2010 E88 135i manual/sport package
KWV3's| M3 F&R control arms| WL subframe bushings| ARC 8's w/ 235/275 ExtremeContactSports| MFactory Flywheel w/ Spec Stage 2+| AR downp*pes | Magnaflow axleback| 7" VRSF IC| RB Next Gen +| RB inlets/outlets| RB PCV| ER Charge pipe| Tial BOV| BMS intake| JB4 with BEF
Car: 535i
Default Yesterday, 07:24 PM
Ok I’ll try again in a few days when I’m back from a work trip.
Thx
Default Today, 10:24 AM
User adjustment settings were not set to default...those will need to be updated before doing additional logs.
