N54tech.com | BMW N54 N55 135 335 535 Turbo Performance Forum
(#51)
ianthegreat's Avatar
ianthegreat ianthegreat is offline
the original
Default 04-27-2012, 11:01 AM
Originally Posted by robc1976
That looks great, map 2 for me and my PWM goes to max...looks like you are hitting target to. Add target, ign advance, throttle to the logs if you are running regular gas I think map 2 is better but with a E85 mix I think map 5 is king...I pulled on my buddy by almost 3 cars and he has the same mods and he had map 2 (regular gas) I had map 5 (E85 mix).
Edit: your not flooring it all the way.
Sorry, forgot to mention. I had just finished doing an intake valve cleaning and installed the ER CP. I was checking the pressure buildup to make sure everything was tight and thought I'd run a quick log. Was around 95% throttle. It's interesting, ever since I did the cleaning I've been throwing the 29F3 sensor code.
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Tuner: JB4 G5
Default 04-27-2012, 11:10 AM
Check your map sensor on the charge pipe ...I also have that charge pipe...awesome pipe!
JB4 G5 ISO+BMS flash,Walbro 455 LPFP, DO meth kit 4-AN SS lines, BMS OCC, RB turbos W/3.5 N20 sensor, RB valve, BMS DCI, 3" AR kittyless Dps, Strett 2 oil OC W/ SS lines, ER FMIC, ER CP W/HKS BOV, M3 control arms, M3 Strut Brace, M3 front sway-bar, Meyle HD tie-rods, HPA rear toe arms, Wavetrac LSD, DEFIV differential kit, BC Coil-overs, Power-Flex subframe bushings, stoptech slotted rotors, Rogue Tranny Mounts, Concept 1 CS-5.0 rims,
Copyright © 2007 - 2013, N54tech.com
