Wickedowesix's Avatar
Car: 540i G30
Default X98 vs 100% Meth WMI - 10-15-2017, 01:08 PM
So I have been reading that people are switching out 100% meth for X98 ethanol in the WMI tank. Anyone have any dyno comparison of the two? Or any other i information. Thanks!
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 10-15-2017, 03:52 PM
I can give you some scientific data.
Methanol takes way more energy to vaporize than ethanol
You can burn about twice as much meth for the same amount of air as ethanol so methanol makes more power.
Water takes way, way more energy to vaporize than methanol. So...
Roki187's Avatar
Roki187 Roki187 is offline
Car: 340xi
Default 10-15-2017, 04:58 PM
I was was able to crank out a 11.44@118.84 with pure1 E18/100% meth vp m1 *dual cm7s* with major closures.
I have since added x98 to the meth tank and it pulls much better already with no closures at the exact same setting.
Hard to get 1/4 mile data on the street as it spins all 4 in first and halfway through second gears. Hoping to hit the track soon, will report back but the x98/meth mix works very well thus far.
Car: 540i G30
Default 10-15-2017, 05:15 PM
Do you have 100% X98 in the meth tank?
Roki187's Avatar
Car: 340xi
Default 10-15-2017, 05:50 PM
Just a mix of ~80/20 for now. I’m adding x98 as I go.
80-meth
20-x98
Juan_BIGBOOST_TURBO's Avatar
Juan_BIGBOOST_TURBO Juan_BIGBOOST_TURBO is offline
Default 10-15-2017, 05:58 PM
With our stage 3 turbo the car makes 20 more hp on x98 than full methanol with a much nicer torque and power curve. No throttle closures at all.
BigBoost Instagram: @bigboost_turbo
webpage: bigboostusa.com
BigBoost's car: BMW M240i
Stage 3.2 turbo
Current B58 Horsepower record holder: ̶5̶3̶4̶, ̶5̶6̶3̶, ̶5̶7̶1̶. Currently: 613 WHP
Daily Driver: BMW M235i
BBT stage 3.3 turbo
protecon's Avatar
protecon protecon is offline
Car: 2010 X5M MCB
Default 10-15-2017, 06:36 PM
At what point do you have to start considering adding foam to your tank?
Car: 540i G30
Default 10-15-2017, 07:06 PM
Was everythung else equal? Boost, timing afr and trims
Default 10-15-2017, 08:09 PM
AfR was a little bit richer and trims were much lower. Same boost, same car, same day, same dyno. All settings were the same as well.
Stage 3.2 turbo
BBT stage 3.3 turbo
Mrpink Mrpink is offline
Car: M140i
Default 10-16-2017, 02:45 AM
So are we saying we should be spraying ethanol rather than methanol?
Car: 540i G30
Default 10-16-2017, 04:05 AM
What was the afr and trims reading before and after?
Default 10-16-2017, 11:32 AM
14.3 meth and 13.7 X98, trims: meth=maxed out, X98=36~32
Stage 3.2 turbo
BBT stage 3.3 turbo
I M inluv340 I M inluv340 is offline
Car: BMW 340i FBO WMI
Default 10-16-2017, 04:36 PM
Agree with everyone on X98 my logs look way better. Much more consistent almost no throttle closures and timing looks better. I wouldn’t ever switch back, car feels much better
harry$ harry$ is offline
Default 10-16-2017, 05:28 PM
What are peoples thoughts and experience with GEM fuels? the recipe is 37% Regular gas 21% Ethanol 42% Methanol.
https://gutts.nl/gem-fuel-best-practices/
http://www.azmeco.com/?mid=132
Car: 540i G30
Default 10-16-2017, 08:49 PM
I'm running 100% meth on e30 fuel without any throttle closures.
RMM RMM is offline
Car: 120i
Default 10-20-2017, 09:59 PM
Interesting I just tried 95% by vol rubbing alcohol form the pharmacy and the car is noticeably faster, but logs looks the same, if anything I am getting more throttle closure, then before but it is faster, so I do not think it is related to throttle, timing is similar as well, so something else is going on the engine just like it.
0-100km times dropped form 4.8-5.1 to 4.6-4.9, 3rd gear 40-120km pull dropped form about 6 seconds to about 5.6 seconds. Its like 10% more power with nothing visible in the logs weird.
Roki187's Avatar
Car: 340xi
Default 10-21-2017, 07:27 AM
Relative DA will have a huge effect on a boosted car especially.
And it changes min to min
BazBar's Avatar
BazBar BazBar is offline
Car: UK 140i-M Sport Auto
Default 10-24-2017, 02:28 AM
Can you post up a log, what % ethanol ?
RMM RMM is offline
Car: 120i
Default 12-06-2017, 10:50 PM
Does anyone know how to disable the target boost limit when using map 7?
In my car the TARGET is limited to DME_BT + 13.5 psi, which makes for unpredictable TARGET behavior, when using anything above a 40 adder as it is colder now my car can have a 5 PSI DME_BT, when this happens it results in a boost limit of only 18.5 PSI.
I really want to run 21-22 psi with consistent target setting, but cannot find any way to do it so far, especially as really need to be 1-2 psi below target to avoid throttle closures.
I know I can just run map 6 but I really like the protection in map 7 and I do not want to be limited to 18.5 psi on WMI.
Thanks,
dRDiesel dRDiesel is offline
Car: BMW
Default 04-10-2018, 03:06 PM
I'm in the market for a 340i M sport. It's a pretty interesting platform and i do see a lot of people suffering with fueling issues and I'm hoping water-meth works better, but it also seems like people are trying out different jets to get it down properly? I'm coming from a 400whp 2016 Volkswagen GTI so i would need the 340i to be at least 450WHP. Don't you guys think dual CM7 is a little too much? I was running a single CM5 nozzle on the GTI and that was more then enough for a 450+ whp setup... not sure if these two platforms are comparable as far which jet to use.
Bullitt1841's Avatar
Default 04-10-2018, 03:55 PM
Dual CM5's with E98 runs pretty well. Don't run any water on the B58, it doesn't like it. 100% meth works fine, too.
It's a little hard to dial in meth at tip in, as your AFR will be very rich for the first second or two. But hopefully things will improve with time (and hopefully flash tuning).
2017 F36 440i Gran Coupe | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
SOLD: 2007 E90 335i | PURE Stage 2 N54 Turbos | JB4 | FBO | 160k+ miles on the car, 120k+ miles on the JB4
Car: BMW
Default 04-10-2018, 07:54 PM
Wouldn’t it be more useful if we strapped the car on a dyno and fine tuned the meth on map 6 or 7 whatever the meth map is using AFR sensor on the tail pipe or secondary oxygen sensor location? I only have experience with a progressive controlled meth kit with a start/full spray option. Only reason I’m holding back on this platform is the choking, throttle closure, etc people have been experiencing and a piggy back never seems to fix any of those without proper flash tuning. I have a friend with a 340i and i personally experienced all these issues. On map 0 the car runs like a stock champ, on map 1 its quick and slightly has some hesitation and the choking is felt more on map 2 and others. We have even tried octane boosters and 100 octane blended fuel with 91.
edit: I wouldn't run straight water on the B58 as the air to water charge cooler seems to be work great, this platform is more sensitive octane wise so running 100% M1 would be a better option. I haven't read much on the X98, but has anyone tried a 60/40 type of mix or 50/50 so you get a little bit of octane boost + cooler intake temps for less knock and more timing?
