(#76)
Granite66 Granite66 is offline
Car: Bmw 135
Default 08-18-2017, 03:37 AM
Ok never mind. After reading your post again I have come to an understanding that the misfires were due to the boost pipe connection. Hope you come right with it asap the. 495 nonetheless is very impressive for vtt
keyap keyap is offline
Car: N55 135i
Default Yesterday, 04:50 AM
Pushed up to 24psi for a map 6 run and hit misfires.
Pretty sure its hardware and most likely the boost pipe connection between the turbo and intercooler.
Did you grab a log of the map 6 run(s)?
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
DD Map 7 at 20psi. Map 6 at 25psi for 'kill mode'
Stoolz Stoolz is offline
Car: 11 135i
Default Yesterday, 12:49 PM
Here's the first log when things went bad.
Default Yesterday, 04:22 PM
Frustrating to hear of misfires on the new flywheel when fuel pressure seems to be holding OK... Don't see how it could be boost leak related? Maybe if intake came loose?
Car: 11 135i
Default Yesterday, 05:33 PM
I was in the car logging beside my mechanic.
We ran a half dozen clean logs in map 7 then pushed up to map 6 24psi.
At about 4500 rpm we got a big misfire and his reaction was 'did we just blow a hose?"
We tried a few pulls in 6 before dropping back to 7 again, this time big misfire around 4500 each pull.
Car going on hoist today or tomorrow.
I have had issues with the inlet coming away on the intake side so I'll ask them to check that.
In the past my car would misfire due to boost leaks.
Default Yesterday, 05:34 PM
Running a BMS intake? If so did you remove the bracket when adding PI?
Car: 11 135i
Default Yesterday, 05:36 PM
Yeah BMS intake.
The guys DID leave the bracket on as it seemed a good fit.
They even made a point to show me.
Will pass the info on.
