RhynoBoiler's Avatar
RhynoBoiler RhynoBoiler is offline
Chi-Town Cruiser
Car: 2011 BMW 335is
Default Boost Target Reading 0 - 02-24-2018, 08:23 PM
Set Up:
- 2011 335is 6MT
- kitten-less dwonpipes, DCI, Intercooler, Charge pipe w BOV, JB4+INA0S PUMP
- Running 93 octane
- Map 2
I flashed the INA0S PUMP backend yesterday and the car ran incredibly well for over an hour of fun.
This morning before the warm up cycle got past 160, I gently accelerated up an incline and the car went into low boost mode, with the error that boost went over Target (code 30FE). I was maybe giving it 40% throttle at most.
When I ran the JB4 app afterward, boost was being tracked fine, but Target stayed at 0 regardless of throttle input. The car has not thrown a code again yet, but Target is still showing 0 even at full boost (~17.5 psi).
I have my jb4 set to the most recent default settings, and I noticed "Boost Safety" is set at 18. Is it possible I hit over 18PSI and the JB4 sent me into low boost mode to be safe? Maybe these problems are related, but not sure.
I've attached 2 logs for reference. Thank you!
All aboard the Lakeshore Drive Express!
Default 02-24-2018, 09:33 PM
At 40% throttle input 0psi may be the boost target, depending on your menu11 in dash setting. You could crank that up to 5000rpm for example.
On 30FE I'd want to see a log of it but perhaps menu12 set too high for the car.
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 02-24-2018, 10:02 PM
They may be separate issues, but even at full boost the JB4 app is reading a target of 0.
I also noticed in the logs, it reads my MPH from the 90 - 130mph range and I wasn't going anywhere near that fast.
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 02-26-2018, 02:05 PM
I gathered 2 more logs today (attached). Car hasn't thrown a code again yet but there seems to be some hesitation in the the power delivery at WOT.
Default 02-26-2018, 02:21 PM
Boost control looks OK but boost seems to high for the fuel quality. I'd drop down to map1 and continue to evaluate that.
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 02-26-2018, 02:34 PM
Interesting. Would Map 1 be a temporary fix to allow for better logging or would I need to permanently run this way?
I do have Swain Tech white lightening coated on the *****, could that be causing boost to raise higher than expected?
I'll grab some more logs with Map 1 later today.
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 02-26-2018, 03:49 PM
Ok, switched to Map 1 and ran some logs. The care feels a bit smoother already but I only did a few pulls so well see what happens long term.
The shorter log was at idle, not sure if its helpful or not.
I purchased a 3.5BAR TMAP from you last week to future proof the car as I mod more, do you think it would have an effect if I install it at this level of boost?
Thanks again!
Default 02-26-2018, 03:52 PM
Runs are short but map1 seems a better fit at least at the moment. There are no issues installing the 3.5bar although it probably won't help anything in your situation at this point.
Default 02-26-2018, 03:54 PM
Looks okay but I'd load the pump flash, that may help a bit with your timing.
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 02-26-2018, 07:38 PM
What recommendations (hardware or otherwise) would you have to be able to run map 2? I'm also curious if you think Map 5 would be a good fit?
I have plans to do the Fuel-it Stage 2 at some point but not sure if that will help this scenario or not.
Chi-Town Cruiser
Car: 2011 BMW 335is
I'm currently running the INA0S PUMP backend, is that what you're referring to?
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 02-27-2018, 09:15 PM
Hi Terry,
I took another log and tried to make this one longer with different throttle inputs. There are a few WOT pulls throughout.
I'm still hoping you could point me in a direction for what is needed to allow the car to run better at high boost.
Thank you again.
Default 02-27-2018, 09:19 PM
Not a log to go on with the log... Normally a log is 40-110mph full throttle (on a safe private track), or 4th gear 2k to redline, for example.
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 02-27-2018, 09:48 PM
Got it. I'll try to get a 4th gear log tomorrow. I appreciate your patience!
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 03-01-2018, 08:54 AM
I was able to get a longer log in 4th, not quite to redline but hopefully it's usable.
I put a bottle of octane booster into a full tank based on your suggestion that the fuel quality may not be ideal.
Default 03-01-2018, 11:47 AM
Pulling some timing up top, otherwise looks normal but I'd stick with map 1 given your fuel quality.
Chi-Town Cruiser
Car: 2011 BMW 335is
Default 03-01-2018, 03:50 PM
Thanks, Steve. Do you think its just a matter of poor 93 octane? I'd like to find a way to run map two if possible, even if that means using octane booster on every fill up.
Default 03-01-2018, 05:17 PM
Definitely could be poor fuel quality. You can try octane booster or if you have access to it, adding some E85.
Chi-Town Cruiser
Car: 2011 BMW 335is
Default A new development - 03-02-2018, 07:12 PM
Well the car was running great until the cool-side intercooler hose popped off last night. I'm trying to determine how/ why that happened.
I've heard a sudden loss of pressure like that can hurt the turbos due to over-spinning. I'm using a Wagner Tuning Evo 1 Performance (stepped) intercooler with the stock style flanges using C-clamps. Is it recommended to upgrade to a different intercooler flange when running the boost I'm at now?
Something seems off still when I get into boost levels above 6PSI. I took a few logs but did't want to push too hard.
Default 03-04-2018, 03:13 PM
Logs are too short and not WOT, you'll need to do a proper 3rd gear log for assistance.
