Docalex1 Docalex1 is offline
Car: 1M
Default S55 BM3 Racemap JB4 map 8 aquamist meth 50% - 02-24-2018, 10:01 AM
Hiflow ** , Akrapovic
Latest Log
Default 02-24-2018, 12:20 PM
1st gear boost limit is set to .9
Meth scaling is set to 100, it should be 60 unless you are running an ethanol sensor.
DB settings are a bit odd but log looks okay.
Car: 1M
Default 02-25-2018, 03:06 AM
Fixed the meth scaling and the boost limit in first gear.
The meth is spraying above 4000 RPM - is that influencing the DB self learning in the new Firmware ?
Default 02-25-2018, 03:14 PM
DB's don't adjust themselves...those are entered manually.
Car: 1M
Default 02-26-2018, 06:00 AM
JB4_M3_OBDII_1_8_2_T11:
1) Adjustments to map7 when equipped with a BEF (26psi peak absolute map)
2) Adjustments to map2 when equipped with a BEF (22psi peak absolute map)
3) Adjustments to map5 when equipped with a BEF (25psi peak absolute map, boost ramp up to redline)
4) Adjustments to JB4 fuel trim mapping
5) Added "metric" speedo setup under menu5, option 1. Shifted boost by gear adjustments each up 1.
6) Duty bias values are now used on all absolute maps regardless of setting. So be sure to default values all to 50 if you have them set to 0. We also suggest enabling FutureUseD bit5 which triggers the JB4 to adjust duty bias by RPM automatically on absolute target maps.
Default 02-26-2018, 10:12 AM
I honestly hadn't seen that.
