(#51)
Default 11-27-2015, 05:14 PM
Updated first post
PLF's Avatar
PLF PLF is offline
Default 11-27-2015, 06:04 PM
Did you remove an engine cover or it comes from factory like that ?
Default 11-27-2015, 06:05 PM
I threw it in the trunk before driving off the lot. We don't do engine covers around here.
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2017 X3 xDrive35i
Default 11-27-2015, 07:40 PM
That motor is interesting looking. I see they moved the airbox again, but I'm more interested in the new intake manifold and TB location. Its finally easy to swap the TB. Opens up port and polish opportunities. Where does that charge pipe go? Are both the inlet and outlet of the intercooler on the same side now?
Mike Levy
2017 X3 xDrive35i
Default 11-27-2015, 08:13 PM
It's an air/water intercooler built in to the intake manifold as far as I can tell!
sA x sKy sA x sKy is offline
Car: 2011 E92 335xi
Default 11-27-2015, 08:25 PM
Sweet, congrats T! Wish my garage looked like yours
AWE Non-Res Exhaust | AWE CF Intake | AWE ColdFront | ER ** | ER Chargepipes | JB4 Stage 3 | Custom SS Methanol | Swift Springs | TPG/DSS 1200hp Axles | Dodson Superstock DCT Clutch | PURE Stage 2 Hi-Flo
Default 11-27-2015, 09:58 PM
Thanks... Wish I had more spots. The 340i will be sleeping outside. Jon @ BMS has the baller ~5 car garage setup.
spikiii's Avatar
spikiii spikiii is offline
JB4 addict
Car: powered by JB4
Default 11-28-2015, 12:04 AM
WOOOOT congrats~!! you guys finally have it . Now the fun begins
Default 11-28-2015, 09:43 PM
Got the prototype B58 JB4 up and running!
Car: 2011 E92 335xi
Default 11-28-2015, 09:59 PM
Wasted no time whatsoever!
multydrew multydrew is offline
Car: bmw
Default 11-29-2015, 01:41 AM
any plans for f30 b48/b38?
i think they are more popular in europe
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 11-29-2015, 04:11 AM
Oh Sheeeet, wasted no time~!
Now to get it on the site ready for ordering
Peter @ Pure's Avatar
Car: F20 M135i
Default 11-29-2015, 06:24 AM
I guess next week some preliminary results?
F21 M140i - currently stock
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 11-29-2015, 10:09 AM
Yes, of course! We've already done B38/B48 tuning development for the new MINI which is carrying over to the B58 now. I hope to have one JB4 with CANbus working for all models, which detects the model itself, and adjusts accordingly.
Default 11-29-2015, 07:43 PM
Been doing some evaluating of the stock tuning and the overall capacity. It's too early to share my thoughts but I can share it's running around 14psi peak from the factory. Quite a bit more boost than the N55 runs stock all else being equal.
ShlemN55's Avatar
ShlemN55 ShlemN55 is offline
Car: F30 335i msport
Default 11-29-2015, 08:06 PM
Wow Meaning B58 turbo is probably quite Tiny running 14psi to make same what power as N55 on 8psi ..
1993 Dodge Caravan ( Bone Stock )
2016 Tanzanite Blue F80 M3 jb4 , awe non res, bmc filters.
Car: F20 M135i
Default 11-30-2015, 12:51 AM
Meaning probably not much room to get big numbers from stock turbo? Can it be worse than pwg n55 stock turbo?
peter@pureturbos.eu
pureturbos.eu
Default 11-30-2015, 05:03 AM
I believe the B58 puts out a little more power than the N55, but not justified with the 14psi. Its stated to have a smaller turbo, so I assume less efficient. Im sure Terry can get more power out of it, but I bet its even more biased towards lower RPM spool and poor top end numbers than the N54/N55.
What I am curious about is the limitations or advantages of that intake manifold. Air to water = awesome IMO, but it will not be easy to change the core and I dont like the idea of meth injection pre inter cooler. Though we know others have tried this before, it will limit nozzle size, etc. I guess we could upgrade the inter cooler pump or overdrive it with software, and increase the exchanger size in place of changing the actual manifold core.
Would be interesting if the A/W inter cooler is a improvement, I wonder if its interchangeable with the N%% manifold. I am sure thats WAY WAY down the line.
Default 11-30-2015, 09:35 AM
The air/water opens up some alternative options such as a larger reservoir, better heat-exchanger, etc, but would be a headache to replace. So I hope it flows OK. The S55 air/water IC flows very well for a factory part and BMW tends to oversize things like this. So we'll see.
I'm very curious to get the car on the dyno for its initial baseline testing. Maybe it will just blow us all away on power stock. Or maybe its a dud. I'm hoping for the former!
wgknestrick wgknestrick is offline
Car: 2011: 335Xi
Default 11-30-2015, 11:37 AM
I would be concerned about that "lack of cylinder liners" detail. I can't ever see a coating holding up over time as a cylinder liner.
Water to air IC does not make it easier to modify either. You can cold box it though for drag racing.
Like all things BMW these days, it's probably give/take.
Car: F20 M135i
Default 11-30-2015, 12:19 PM
When is dyno planned?
peter@pureturbos.eu
pureturbos.eu
Default 11-30-2015, 12:47 PM
Sometimes this week for sure. Busy with R&D at the moment. BMW has made some interesting changes to the tuning end.
Car: F20 M135i
Default 11-30-2015, 12:55 PM
Looking forward to your RnD and Dynotesting later this week
peter@pureturbos.eu
pureturbos.eu
Pure Turbos's Avatar
Default 11-30-2015, 01:20 PM
This is exciting! This motor looks like a beast on paper. Huge stroke, small bore, should be a torque monster. Can't wait to hear about the tuning details you discover!
Default 11-30-2015, 01:25 PM
Turbo looks easy to reach...
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Ash225
