(#1776)
CloudVIII's Avatar
CloudVIII CloudVIII is offline
Car: F10 550i X-drive
Default 04-18-2018, 09:16 AM
Originally Posted by DSCOFF
Hi Terry. Having real nightmare in flashing stage 0 in stock map operations in MHD. It says connected but after 30 min nothing .. and no indicator on progress of flash... throughout the time. It can read
My dme codes. Martial is aware and sent you an email to confirm if my jb4 ( posi
Tapped) needs to also be removed from the obd port ... not just map 0.
Coz now cannot start car .. it says ignition problem and contact bmw.. it wont flash bk to stock either and just says connected after I select the option. But again no progress indicator ...
Disconnected battery but still no go.
Quick answer is yes. Put the JB4 on map 0 then pull from the OBDII port... Then flash.
F80 AW M3 FBO/JB4 Stage 3/BMS Meth Kit/Pure Stage 2
DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default S55 crank hub spin issue - 04-24-2018, 12:04 AM
Hi. Just want to know if anyone has successfully taken steps to prevent this from occurring? Please list what is the fix and which method works.
2009 N54 335i coupe, 6AT PD trans, Stage 3 XHP, Built Motor, 9.6:1 Comp Ratio, Ported Head, Trebilia Custom Flash, JB4, Mhd flasher, Ngk 97506 0.018 gapped, PI Kit 100% E85, Jb4 PI integration, Stage 2 Pure Turbos 25.6psi, TFT inlets, Stage 3 Fuel-it Fpr, FBO, 422rwkw Mainline Dyno Aus
25.0 psi, JB4 S55 Bms E70 BEF tune, MHD F series flasher, M4 plugs gapped 0.020, stock everything else, 364.9rwkw Mainline Dyno Aus
VF-1J VF-1J is offline
Car: 2015 M3 F80
Default 04-24-2018, 12:11 AM
How much whp are you making? I'm on stock turbos with BEF and JB4, running e63 w/550 whp, and I'm not having this issue. However I can't run full E85. For some reason, my car can't seem to take anything over e70. At least not when in Map 6 or 7. I can't wait till we crack that code and allow us all to run full e85 at Max boost.
F80/S55
JB4
MHD
InJen Intakes
D***P****
NGK 2-steps cooler
E60
Stock Turbos
Stock Exhaust
CloudVIII's Avatar
Default 04-24-2018, 06:55 PM
There is no proven fix...but if I had to say one... Maximum PSI Crank Hub fix is as close to one as your gonna get.
I am using the VTT crank bolt capture and 30% over torqued crank bolt with loctite. No issues thus far.
DSCOFF's Avatar
Car: 335i coupe N54
Default 04-24-2018, 07:20 PM
Oh I thought the crank hub issue also occurs with stock cars let alone tuned ones .
I believe Terry has already a bef which allows 100% E85 already and makes 550-560whp with everything stock except air intake.
This will be my objective once I sort out my niggling wiring issues with the jb4. But Im already on 100% E85 in Map 2 currently.
DSCOFF's Avatar
Car: 335i coupe N54
Thumbs up 04-24-2018, 07:22 PM
Great to hear
Default 04-24-2018, 07:24 PM
Some cars can run 100% E85, others need to reduce the mix. We could lean the BEF out further for them but I just don't think it's as safe as lowering the E85 mix slightly in those situations.
narstune's Avatar
narstune narstune is offline
Car: '11 E90 335i
Default 04-24-2018, 09:32 PM
Similar situation here. I can run Map 1, 2, 5, 6 with full E85, but fuel trims tend to max out in Map 7.
My solution is different: run a mix of unleaded race gas with VP Racing MS109 (105 octane) or Sunoco GT260 Plus (104 octane) then Map 7 will work.
2017 M3 ZCP
CloudVIII's Avatar
Default 04-24-2018, 09:53 PM
What is your FOL set at when your maxed out?
narstune's Avatar
Car: '11 E90 335i
Default 04-24-2018, 10:20 PM
Tried both 60 and 70.
2017 M3 ZCP
CloudVIII's Avatar
Default 04-24-2018, 10:45 PM
You could try 72 to 73. I have heard ZCP as high as 75.
narstune's Avatar
Car: '11 E90 335i
Default 04-24-2018, 11:00 PM
I'm not sure if I want to lean things out further if Terry himself doesn't recommend it, but I'll keep those suggested values in mind.
2017 M3 ZCP
CloudVIII's Avatar
Default 04-25-2018, 07:19 AM
Fair enough ...just speaking from experience when I have ran 73 and it helped me.
jonsabia jonsabia is online now
Car: M4
Default 04-25-2018, 12:58 PM
so the higher you go on the FOL that leans out the fuel ?
2018 M4 CP, jb4, MHD BEF, intake, down pipe, e85, BMS Meth kit, Trebila tuned, NGK 2step colder plug
Default 04-25-2018, 07:00 PM
FOL is used to balance out fuel trims. Which can effect actual AFR in some situations if our of range. Generally on the S55 higher trims result in a richer AFR and misfires.
DSCOFF's Avatar
Car: 335i coupe N54
Default 04-26-2018, 05:27 AM
Oic ok. I did a log on Map 6 in the support section if you can have a look at it Tx
anthonyM4 anthonyM4 is offline
Car: BMW M4
Default 05-04-2018, 03:34 AM
A quick question, what should the default setting be on option 2 - boost gauge on fuel? Off or On?
Thanks in advance
Default 05-04-2018, 08:56 AM
Default is 2/1 boost on fuel under heavy throttle only.
Car: BMW M4
Default 05-04-2018, 08:59 AM
Thanks Terry
HR F10 HR F10 is offline
Car: 2011 550i M-Sport
Default 05-05-2018, 11:33 AM
I have a stock ZCP, can I use Map 2 with 93 gas but no exhaust mods?
550i M Sport - Alpine White - Vossen CV4 Graphite / H&R Sport springs / Active Autowerke Down ***** & Exhaust / BMS Stage 1
Default 05-05-2018, 01:30 PM
Map1 may wind up being a better fit but easy to evaluate map2 and see.
Phlonx's Avatar
Phlonx Phlonx is offline
Car: 08 135i Coupe AW/CR
Default 05-06-2018, 07:48 PM
Installed jb4, confirmed settings are all at default, updated to latest firmware.
Default 05-06-2018, 08:23 PM
You'd have to post a CSV log to the support area or email it in if you need tuning assistance.
Default 05-06-2018, 08:24 PM
Originally Posted by newm4
what will make more power vp ms109 race gas or 93 octane mix what E85 on the 2015 bmw m3 m4 !!!!!!!!
Depends on the E85 mix and tuning, generally about the same power potential.
Phlonx's Avatar
Default 05-09-2018, 10:14 AM
Got it all sorted with support, thanks Terry.
Whats the latest with the BEF situation? Is it live? Is there a thread on the details? Havent found much after searching. E85 station is like 5 miles away, kinda hard not to make the best of it u know?
