(#926)
Stoolz Stoolz is offline
Car: 11 135i
Default 11-23-2017, 12:24 PM
Originally Posted by MHD
We'll try to adapt the F series launch.
But F series don't have a launch problem, it's E series Dct that NEEDS it.
houtan houtan is offline
Default 11-23-2017, 12:51 PM
IMO. Dct launch control is fine. We just need boost by gear at minimum. Adjustable rpm would be nice.
Car: 11 135i
Default 11-24-2017, 12:43 PM
But we have boost by gear via jb4?
I know of nobody who can launch a dct other than sitting at the tree for 5 seconds after green trying to "catch" the dropping launch rpms.
Default 11-24-2017, 01:46 PM
On our 135i DCT I normally limit boost in 1st gear to 10psi and launch off that.
ganque ganque is offline
Car: 2013 135i M Sport
Default 11-24-2017, 06:40 PM
This guy was able to build boost on the regular DCT Launch Control on the N55 E Series cars.
https://www.instagram.com/p/BbsJYCug...re_evil_tuning
Is there any way we can get this as an option in MHD?
Also, what's the status on the LC RPM adjustment for DCT cars?
Car: 11 135i
Default 11-28-2017, 01:21 PM
I don't think I've ever seen any slips posted Terry?
What kind of 60s we're you able to get?
I think you ran vtt on 335 then 135 then swapped out the turbo for the PS2 on that car right.
What kind of et and mph could you get? I remember the 11.4 from the 335 being pretty much the fastest et for an N55 for a long while. (Til F series at least).
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 12-03-2017, 02:32 PM
The DME can cap the torque by gear and rpm. I'll add a flash option for that (of course it needs to be simpler than the 10x12 DME table).
Default 12-03-2017, 02:43 PM
Nice. Thanks. Will the torque by gear and RPM work in a commanded WGDC map?
yaboipanda14 yaboipanda14 is offline
Car: 2012 bmw 335xi n55 coupe
Default chargepipe help - 12-25-2017, 07:48 PM
so im running a jb4 backend and i noticed when i was running map 1 or map 5 and i would do a pull my car would auto kick me back to map 4 could it be ..because i have stock chargepipe?
Default 12-25-2017, 08:19 PM
Check the "last safety" on the JB4 user adjustment page to see why. Over boost, lean run, etc. Then based on that address the issue.
Default maybe a dumb question - 12-27-2017, 06:12 PM
so im running 93 fuel but i flashed with a backend flash for stock tune should i switch to pump flash?
Car: 2011 N55 135DCT
Default 01-02-2018, 01:05 PM
Hi Terry
Do u still have the Single turbo PI flash for n55 e series
2011 135 n55 DCT RHD, MAMBA GTX3576R single turbo kit by CCD South-Africa,FBO,Fuel IT TBI and Stage2 Lpfp,BMS Jb4 and FSB,Devels Own meth kit. 3.5 inch single exhaust.
Default 01-02-2018, 01:08 PM
Also with the hi load for DCT to not slipp
Default 01-16-2018, 07:56 PM
We're just getting started. The JB4 offers a ton of tuning flexibility that is going to come in really handy especially so now that we can make flash change directly to compliment it. Running both when properly configured gives you tons of tuning options and the best of both worlds.
TDDaryl's Avatar
TDDaryl TDDaryl is offline
Car: 2008 335xi
Default Yesterday, 08:30 PM
What BEF would benefit most if I was switching from E40 to VP 101 full time?
2012 E82 FBO JB4 (Daily)
2008 335x 6466 ST (being rebuilt and upgraded)
Default Yesterday, 09:36 PM
Use the normal PUMP one.
TDDaryl's Avatar
Car: 2008 335xi
Default Yesterday, 10:08 PM
Thanks. I appreciate the quick response.
