AJoosten AJoosten is offline
Default Disable DTC completely through bin file - 02-10-2018, 07:51 PM
Is there a way to completely disable DTC through the BEF bin files? I am looking at the JB4 backend flash files and see the DTC tables but I don't have the knowledge to know what these tables actually do. Can anyone shed some light on how these tables work and how to completely disable them?
My goal is to always have the car in the "hold down the button for 5 sec" mode.
09 135i N54| OEM Turbos|OEM Plugs|OEM Coils|DTC Disable on Startup Harness | JB4 G5| Map7| E85 BEF| 50% E85| MFactory LSD| Stage 2 LPFP| Active Autowerks 7" FMIC| VRSF CP| HKS SSQ BOV| Agency Downs & Midpipes| JE Piston Heads| SPEC STG 3 Sprung 6 puck disc|ACT Pressure Plate| SPEC Single Mass Aluminum Flywheel| COBB Sport Spring & Sway Bars| Koni STR.T Shocks| BMS Cowl Filter| BMS Catch Can| BMS Clutch Valve| BMS Oil Cooler Valve| APEX EC-7| ....https://bmw135iblog.wordpress.com/
N54QC N54QC is offline
Car: 07 BMW 335i
Default 02-10-2018, 09:11 PM
There was already a request to do it per the JB4. Terry said if there was enough interest, he would think about adding the feature. As far as tunerpro goes, I'm not familiar enough with it either.
Default 02-11-2018, 09:33 PM
After a little google turns out that DTC means Diagnostic Trouble Code table instead of dynamic traction control table.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 02-16-2018, 08:17 PM
That would required disabling DTC (dynamic traction control) *and* ASC (active stability control), I think.
Seems like it would be doable, given that JB4 has an option to disable DTC upon start. (doesn't seem to work on my E60 though).
2009 535i Sport
Software: JB4 G5 | MHD | Trebila Tune | XHP Stage 3
Hardware: GC Lites | Inlets | Outlet | 3" D-P's | 7" FMIC | S2 LPFP | TBI | DCI | ER CP | Forge DV's | 3.5 TMAP | RB PCV | Koni FSD
dyezak dyezak is offline
Default 02-23-2018, 08:03 AM
Short answer is "yes". Longer answer is this is coming in the future.
suspenceful's Avatar
suspenceful suspenceful is online now
Car: 2008 BSM 135i
Default 02-23-2018, 09:08 AM
I remember reading a while ago that Terry didn't want to add this. Too much liability on BMS by having the car start up with absolutely zero traction/stability assistance. It's only a button press away.
2008 BMW 135i 6MT - Doc Race Single Turbo 6266
749whp/643wtq @ 29psi, weighs 3260lbs
YouTube build: youtube.com/jakespence135
Instagram updates: instagram.com/jakespence
N54 t-shirts, etc: bimmerstreet.com
icewall icewall is offline
Car: BMW 135i
Default 02-24-2018, 05:32 PM
yeah this is what i want. if we could leave stability control but completely disable the e-diff setting that would be great!
Default I did it! - 05-14-2018, 03:18 PM
I came up with a harness that does the 5 sec hold automatically on ignition of the car. No more button holding for me. Still leaves the button operable if you want to turn it back on.
http://www.n54tech.com/forums/showthread.php?t=53146
