(#1276)
JBoe JBoe is offline
Car: M240i
Default 06-17-2018, 08:18 PM
Hello Payam and/or Terry. I posted my map 1 logs here: http://www.n54tech.com/forums/showthread.php?t=53725
Probably best to use third pull. If you could, please check them out and let me know what you think.
tZe tZe is offline
Car: F32 440i
Default 06-18-2018, 08:29 PM
I have a weird bug with v9 on F32 440 B58 -- the green indicator on the shifter is not working. When the car starts, the P light is on but once I shift out of P, the green indicator light goes out and stays off. Can someone with the v9 have a look and see if this occurs on yours?
No other issues otherwise. Great product. Have emailed Terry but just wanted to see if anyone else has this issue
Default 06-18-2018, 09:05 PM
Don't see anything in the JB4 code that could be related to that...Might be normal stock behavior. Let's see if anyone else reports any issue.
tZe tZe is offline
Car: F32 440i
Default 06-18-2018, 09:10 PM
I am quite sure it wasn't there prior to the JB4 install so it shouldn't be stock behavior. Small issue - as you said, let's see of anyone else reports an issue.
Could the install have caused this or a loose connection?
Thanks for the fast reply!
tZe tZe is offline
Car: F32 440i
Default 06-20-2018, 04:48 AM
Just to close the loop.
The gear shifter LED is spoilt and needs to be replaced. Nothing to do with the JB4.
Terry - quick question - putting aside the warranty concerns, is there any chance that the JB4 firmware can be corrupted by a reprogram of the ecu systems in the car?
Bullitt1841's Avatar
Default 06-20-2018, 06:57 AM
Take the JB4 out before going to the dealer. Not worth the hassle from the dealer.
tZe tZe is offline
Car: F32 440i
Default 06-20-2018, 08:17 AM
Thanks for the tip. I am well aware of the hassles etc etc and the debate over dealer vists/warranty.
But putting that aside, I am interested to know whether it is possible to corrupt the JB4 firmware if the ecu modules in the car are reflashed while the JB4 is attached but on Map 0 and OBD plug out. I would think it is not possible for any corruption to occur but just wanted the expert's (Terry's) input on this.
Default 06-20-2018, 10:33 AM
Terry can chime in, but I don't think it's possible on the B58 JB4. Only on the N54 JB4 since it connected directly inline with the DME cabling.
BMW After BMW
Car: BMW M240i
Default 06-20-2018, 09:10 PM
I works and I believe we are using it on Map 5. The current FUD setting bit 2 on the latest firmware will have the IAT spoof on all maps so you can test map 1 and see how it does if you don't have the octane/modifications to test map 5 off the bat.
Hah, you know what? All my runs with the spoof bit on were WITHOUT 6cyl timing set to 1. I missed that because it was in the v8 instructions but not in your v9 instructions. Do we still need to set 6cyl to 1?
2017 F23/M240i Convertible (B58) / 6MT / FF Wires / EWG Wires / BMS Air Intake / Stock Exhaust / 93 Octane + 2.5 gallons E85
Antec800 Antec800 is offline
Car: 340ix
Default 06-24-2018, 04:44 AM
Is the new v9 supposed to make more power then v8 and does this apply to map 5, or just 6,7
Default 06-24-2018, 09:27 AM
No performance is more or less the same, we improved the logging performance and channels, and fixed minor bugs, in v9.
Car: M240i
Default 06-24-2018, 10:14 AM
Terry... can you look at my Map 1 posts and provide some input/confirmation. Looks like I may just have an octane issue, but even Map 0 is giving me issues. Thank you for the support.
Default 06-24-2018, 10:15 AM
Sure will check it out now.
BMW After BMW
Car: BMW M240i
Default 06-25-2018, 07:29 AM
Quick bump on this one - does the IAT spoof in v9 work without 6cyl timing set to 1? Since it's a logging param I thought it didn't matter but please do chime in. Thanks...
Car: M240i
Default 06-25-2018, 10:00 PM
Terry/Payam,
I posted, in this thread #1232, about an error when I select "F-Series All" in my settings. In my Map 1 post, it's being questioned as to why I don't have that selected in my logs. Does this matter? I'm using the firmware "BMW_B48_B58_OBDII_9_T4.hex" from the first post and was led to believe that it doesn't matter and to proceed. Please let me know if this is in error and assist to correct, if needed.
Default 06-26-2018, 09:41 AM
Install the windows JB4 interface again as a bug was fixed a few weeks ago.
Car: M240i
Default 06-26-2018, 10:38 PM
Will do... thanks.
Edit: Re-Installed and all is working well. I've posted my new logs in the support thread I started. Thanks, once again, for the outstanding support.
Asuna's Avatar
Asuna Asuna is offline
Car: M240i
Default Help me for JB4's setting - 06-28-2018, 08:46 PM
Hi, Terry.
This is M240i. Use 93 octane, 99.5% meth for WMI system.I want to use Map 7 to get the best power.
I find some setting about N55, but I think is not correct for B58.
Could you tell me the meaning of 'Future Use A' 'Meth Safety Mode(0-3)' and 'Meth Trigger Mode(0-3)'?
I find at the bottom of User Adjustment Settings, there are '1-Boost Over Safety.....5-Fuel Trim Variance', how can I set it?
Thanks a lot!
My setting as pictures, please tell me the mistakes.
Car: 2017 BMW 340i Xdrive
Default Latest log in 3rd B58 - 07-02-2018, 02:27 AM
Installed FF and EWG
Intake
93 octane
Default 07-02-2018, 08:03 AM
Intake
93 octane
FUA to 10 and re log
Car: M240i
Default 07-03-2018, 12:31 AM
Just curious... what will FUA to 10 do?
Default 07-03-2018, 09:01 AM
FutureUseA: Negative offset to dutycycle via EWG connector to correct
for over boost conditions when PWM is low
Basically should help your throttle closures.
mcrrocky mcrrocky is offline
Car: M140i xDrive
Default 07-08-2018, 07:22 AM
Hello Terry,
I have Problems with my JB4 Box.
I flashed the Version "BMW_B48_B58_OBDII_9_T4.hex"
Now I have some Problems..
First I Start the App and this error message occurs a few time
If the App is connected, I get this message
The function "Display" does not show any problems and even the maps are working. (1,2,3,5)
Now the main problem is, I have a lot of error messages in the error memory.
Like on the image:
All these error messages cannot be deleted and due to the fact that I cannot delete the error "180001 ******* ******** detected" my engine lamp is glowing any time.
After this I flashed on the Version "BMW_B48_B58_OBDII_8.hex" but all these failures still exist.
In the past I didnīt had any problems except the message "180001 ******* ******** detected" but error message could be delete anytime (and the engine lamp turned off).
Hope you can help me. Regards Marco
Default 07-08-2018, 07:53 AM
Is your car running fine? Where is your jb4 box located? Check if you got water on it.
Car: 340ix
Default 07-08-2018, 02:58 PM
Updated firmware to latest v9 t4 how do I enable afr indicator, do I do it through bc control?
Copyright Đ 2007 - 2017, N54tech.com
