(#26)
M-terkait's Avatar
M-terkait M-terkait is offline
M-Terkait
Car: F30 335i
Default 02-25-2018, 08:45 AM
Originally Posted by terryd5150
Unless this car has a 4500 rpm stall converter, the only chance it has against a PS2 is on an airstrip (or an even longer distance straight-line event).
0-60, 1/4 mile, Auto-X, and stoplight-to-stoplight, a PS2 would walk away from this car.
A Stage 3 bottom mount wouldn't have to worry with this car, even on an airstrip.
Well yes, it doesn't spool that well, but not sure who race from 0, I spin from a 60 roll lol, it's not that bad. also the gearing is very good you are never behind 5000 rpm.
I use 275/35/18 R888R. 1st gear and 2nd is pretty useless. even with PS2
N55 - Doc race 6266.
Peter @ Pure's Avatar
Car: F20 M135i
Default 02-25-2018, 01:06 PM
Mo what does it do 100-200?
F21 M140i - currently stock
F80 M3 - 100-200: 4.9, 60-130: 5.6
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
ceedawg ceedawg is offline
Car: 2015 f30 335i Msport Xdrive
Default 02-25-2018, 02:34 PM
I will give you everything else other than the 1/4 mile and mile!
2015 335i Xdrive Msport stock for now
1995 Eagle talon TSi AWD 612awhp e85
1998 AMG c43 to 55 5.5L conversion FBO Kleemann Superchip custom SW 307whp 329wtq
2004 G35 coupe aero package Brembo brakes stock
Midnitetuning's Avatar
Midnitetuning Midnitetuning is offline
Car: 07 e90 335i
Default 02-26-2018, 08:49 AM
The gearing on this transmission is different, in the dyno it looks lagi, but its pretty quick on the street, every time you shift it wont go under 5k so power is there on every gear and 1st gear is very short, it really moves, not to bash because we have PS2 here too but no way it would get near where this car moves
135idct 135idct is offline
Default 02-26-2018, 03:13 PM
it's not the gearing problem, the problem with the (turbo transient response)
when it at 5k rpm then go WOT, im sure it takes longer time to spool than the twin scroll.
Default 02-26-2018, 04:36 PM
I will give you everything else other than the 1/4 mile NOPE and the mile NOPE! The pure turbo will get mopped especially in the MPH department at the end of the run 1/4 mile and mile especially with an X drive launch!
135ilove 135ilove is offline
Default 02-27-2018, 12:03 AM
Do you know what the timing was for these pulls? 30 psi on a 6266 in a n54 is well in the 700s.
2013 DCT Jet Black 135i
-JB4 Stage 2 ISO/w Flex Fuel Wires-Fuel it Stage 3 Bucketless LPFP-PDU Port Injection-Big Boost 6564 Bottom Mount Turbo Kit-Big Boost Chargepipe-Active Autowerke-BOV-Injen SP Intake with Blox Velocity Stack and Turbo Guard Filter-VRSF 7.5 in Stepped Race Intercooler--BMS OCC/OCV/CF-N20 TMAP-N20 Plugs-Motul 300v 5W-40-Archoil 9100-Motul Mocool-Custom 3.5 inch Straight Pipe Exhaust-Stoptech Rotors/Fluid-PFC Track Pads-VMR 710-Toyo R888r-M4 Flywheel- SSP R Clutches
terryd5150's Avatar
terryd5150 terryd5150 is offline
Car: BMW 335xi
Default 03-02-2018, 08:18 PM
Post time slips.
terryd5150's Avatar
Car: BMW 335xi
Default 03-02-2018, 08:20 PM
Originally Posted by cnm135i
Dont agree. How much time do you spend under 4500rpm in a 0-60? In 1st and 2nd gear car will spind the rear tires with hardly any boost at all (on 8AT for sure).
I think it will be a bigger nuisance in daily driving having to whip the car/shifting down 3 gears to get going. I sometimes have this feeling even with the Pure Stg2.
You seem to be playing both sides of the fence.
You mention not spending much time under 4500, but then mention having to downshift 3 gears to get the car moving....
terryd5150's Avatar
Car: BMW 335xi
Default 03-02-2018, 08:22 PM
No.
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 03-03-2018, 12:28 AM
-16' X4 M40i Tweaked CTS Turbo FMIC | Custom CTS Turbo D0wnP1pe | BM3 E30
- 17 F80 ZCP | BM3 E30 | CTS Turbo D0wnP1pe/CP/HeatExchanger & Mid-pipe
$ECA $XRP $XLM $TRX $ADA
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 03-03-2018, 04:07 AM
Originally Posted by Frikiton
I'm waiting on Dragy to enable sats in middle east so i can record some data, I'm not good at using phone and driving at all. might buy GoPro to record.
SeanWRT SeanWRT is offline
Car: m2
Default 03-03-2018, 10:40 AM
In daily driving downshift into higher rev range doesnt mean you have instant power. Turbo still need time to spool up and thus power comes on even later. Smaller/twin scroll/ball bearing/lightweight wheel turbo will always be faster getting going, whatever rev range it's at.
That being said, it's stupid to focus too much on drivability when you do a top mount kit. Only thing it does for you is drag. Harkes is right, doing 0-60, 1/4mile, you have launch control, offline you already have boost, very different than on dyno or daily driving. In such cases, power will be there a lot earlier rev range.
