(#126)
Default 12-10-2013, 02:51 PM
Originally Posted by iuhutch
Interesting thought by Jet...
Both sensors are "spoofed", although the MAF is not technically part of the wide open throttle load model. It's used primarily for partial throttle and idle tuning. The N54 had a 1.25 bar MAP sensor with higher vacuum resolution which served the same purpose. The N55 went to a 2.25 bar MAP sensor so has to use the MAF to fill in that vacuum resolution.
(#127)
Default 12-10-2013, 04:51 PM
I've been going through this thing on and off for the last few days and I think I just make a break through. The way the DV is connected is allowing it to crack open. It needs boost pressure to hold it shut and then vacuum to pull it open when letting off the gas. But right now it's connected to a vacuum only source triggered off a solenoid. I'll come up with a way to correct this and redyno. I'm cautiously optimistic this will allow more boost and better results.
(#128)
Rob@RBTurbo's Avatar
Stalker
Car: 335I
Default 12-10-2013, 04:53 PM
That definitely sounds promising.
(#129)
boostedMPLS's Avatar
boostedMPLS boostedMPLS is offline
Car: E92 335xi M
Default 12-10-2013, 04:55 PM
Wow, nice job figuring that out! Interested to see what happens when she's up on the dyno. Even if it makes more boost; based on the design of the unit itself, is it possible to make a lot more power with ONLY boost?
(#130)
eyim1988 eyim1988 is offline
Car: 2011 e92 335i
Default 12-10-2013, 05:01 PM
wooow great news . hopefully.
(#131)
paradoxical3 paradoxical3 is offline
Car: BMW x1 35i xDrive
Default 12-10-2013, 05:12 PM
Thanks for looking into this still.
Too bad Tony doesn't understand that if your goal was truly to trash his product, you wouldn't even mention something like this.
(#132)
Car: E92 335xi M
Default 12-10-2013, 05:16 PM
+1!
(#133)
j23a45m's Avatar
j23a45m j23a45m is offline
Car: 2011 E90 335i
Default 12-10-2013, 05:17 PM
great find Terry, best of luck with that.
thank you for keeping our N55 hopes up
2011 BSM 335i E90 MTECH 6MT BMS Intake Vishnu c@t less ** Cyba Scoops LUX V4 H8 6000K Headlight/Fog light Morimoto Euro headlight switch ACS roof wing 35% tint Black Grilles Misc coding JB4 Stage 2 AA charge pipe Vrsf 7" FMIC M3 cluster
(#134)
BMDUB1 BMDUB1 is offline
BMDUB1
Car: 2011 335i N55
Default 12-10-2013, 05:18 PM
Sounds interesting
(#135)
Default 12-10-2013, 05:39 PM
Huzzah! Progress!
(#136)
Default 12-10-2013, 05:40 PM
Oh ****!
(#137)
Car: 2011 e92 335i
Default 12-10-2013, 05:44 PM
how the car feeel?
(#138)
iuhutch's Avatar
iuhutch iuhutch is offline
Car: 2011 e92 335xi
Default 12-10-2013, 05:45 PM
You are the man Terry! Thank you for not giving up on us despite all the turmoil. That log looks 10x better...how did she feel on the street? Is more than 20psi expected from this setup?
(#139)
Default 12-10-2013, 05:50 PM
Feels much better down low now. I'm really optimistic again for this thing. Will try to get back to the dyno tomorrow with it.
(#140)
Car: 2011 e92 335i
Default 12-10-2013, 05:54 PM
I have a good feeling
(#141)
Stalker
Car: 335I
Default 12-10-2013, 06:10 PM
Sexy. Now some real results to follow. Sweet!
(#142)
BMDUB1
Car: 2011 335i N55
Default 12-10-2013, 06:16 PM
Some how I knew this would get done
(#143)
Curare86 Curare86 is offline
Default 12-10-2013, 09:04 PM
love your work terry!!! thank you for sticking with this despite everything
(#144)
deemarr 335i deemarr 335i is offline
Car: 2011 E90 335i
Default 12-10-2013, 09:22 PM
This is awesome, thanks for not giving up terry.
(#145)
blackshan blackshan is offline
Car: 335i coupe
Default 12-10-2013, 09:30 PM
I am hoping for good results for my n55 friends! That log looks much better than the previous one I saw! Good luck Terry!
jb4 G5 fbo w/ mmp inlets and 3.5 sensor
(#146)
malrayes's Avatar
malrayes malrayes is offline
Car: 2012 BMW 640i F13
Default 12-10-2013, 09:58 PM
And thats why gentlemen, I trust this guys products (terry) on my car!
2012 BMW 640i Coupe F13 | Dr. Euro Down Pipe | BMS intake | M Performance Exhausts | JB4 Stage 2
(#147)
wreckz's Avatar
wreckz wreckz is offline
Car: n54 TOOPL3SS
Default 12-10-2013, 10:21 PM
well terry I guess that's checkmate
good job terry
cant wait for the dyno results
(#148)
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 12-11-2013, 12:50 AM
so it look like it peaks at 20 with that spring, are you putting the 25lb one in too? and test that too? i hope we get close to 500 like maybe 480 on 20lbs e85 mixtures. I got one of the preorders and would love to come out and have you tweak it once you get it up and going
<-- Click on pic for the build thread 1m bodywork,helixIC,ONE EIGHTY head lights, JB4,Seibon GTR hood , i carbon trunk,meth, BMS intake,black lines,CKS coil overs, Sparta Evolution 2 piece rotors , PURE Stage 2 Turbo, BBS FIR's coming
(#149)
Default 12-11-2013, 01:26 AM
The boost holds so much better and spools so linear and fast. Just up the boost and I can see this making lots of hp with e85 if fueling isn't limited by then.
Is the n55 fuel pump like the n54?
(#150)
trebila's Avatar
trebila trebila is offline
Default 12-11-2013, 01:53 AM
Great job Terry, you fixed this hardware issue.
can't wait to see dyno results, even if I'm a N54 guy, the n55 is the future.
Closed Thread
