cnm135i cnm135i is offline
Car: m135i
Lightbulb Electronic oil tester - 09-30-2017, 01:42 AM
Anyone tried this one?
https://www.amazon.com/OTO300-Motor-...53W75Q9QQSCQZS
M135i, PWG, Pure Stg2, WMI, bootmod3 + JB4, Quaife LSD
100-200kph: 7.0sec (93 and meth)
www.youtube.com/user/npharkes
rcpro88 rcpro88 is offline
Car: 535i
Default 10-03-2017, 01:30 PM
I honestly wouldn't recommend it. Most will use a range like 1-5, 1 being bad, 5 being best. There are expensive testers out there, they will work well but cost $700+ so unless you plan to check you oil condition every month, I'd send an oil sample off to a testing lab and have them tell you all the info they discovered about your sample.
Why are you wanting to do an oil test? I believe some people on one of these bmw/n54 forums has found that doing oil changes at 5,500 miles (with quality 0W-40/5W-30 synthetic oil) shows no noticeable difference in engine life degradation when compared to changing oil at 3,000 miles.
VRSF Inlets, Chargepipe, **'s, FMIC
HKS BOV, BMS DCI, BMS Meth Kit
JB4 w/MHD-BMS E85 Backend Flash w/Nexus 7
Custom Map 6 21.5 psi (E70 mix)
Walbro 450 LPFP - 4 Bar TMAP Sensor - Muff Delete
SAT Transmission Flash/retrofit (Thanks to Wedge!)
AD Engineering Oil thermostat - Rob Beck PCV Valve
Gloss Black BMW M359 M3 Competition Wheels
Continental Extreme Contact DWS06 Tires
Installed all the parts myself.
Car: m135i
Default 10-24-2017, 02:12 AM
I actually tested it Let me make it clear that it will not replace my regular 5000miles changes - more just for fun/interest if it actually has some merrit.
https://youtu.be/fvrySHQpqhg
...to be continued
