(#4601)
JazRedGT JazRedGT is offline
Car: 2007 335i E-92 6AT
Default 06-18-2018, 12:18 PM
How accurate is that new 0-60 feature under logs?
2007 AW 335i E-92 6AT MMP Stage 3 @ 25psi / JB4 G5 ISO / XHP STG3 / VRSF D-Ps / MMP INLETS&OUTLETS / WEDGE MHD E50 BACKEND / CW EXHAUST / CPe CP / GReddy RS BOV / BMS METH KIT / WAGNER IC / PR STAGE3 LPFP 10.92 @ 132 1.72 60ft 6.96 @ 103 1.55 60ft
Default 06-18-2018, 12:45 PM
Reason why i ask.
S3nder S3nder is offline
Car: 135i e82
Default 06-18-2018, 12:50 PM
On app it measure 0-60 mph and on drag race it measure 60 foot ?
Default 06-18-2018, 12:53 PM
Yes 0-60MPH on app. Just wondering how accurate it is.
Car: 135i e82
Default 06-18-2018, 12:56 PM
0-60mph on eu is 0-100kmh ? If So then your 1.675 sec is Deem fast :D faster than F1 car
Default 06-18-2018, 01:02 PM
Blueberry96's Avatar
Blueberry96 Blueberry96 is offline
Car: Kia Stinger Gt1
Default 06-18-2018, 01:39 PM
With the JB4 phone app... do I need the OBDii cord as well? someone said I need it for my specific car (kia stinger) but I dont understand why
lilg1993 lilg1993 is offline
Car: 2007 E93 335i
Default 06-25-2018, 10:52 AM
does anybody know what does checking the "disable gps access" box do?
Bullitt1841's Avatar
Default 06-25-2018, 12:01 PM
It disables GPS access from the app to your phone's GPS data. Therefore you won't be able to see "GPS Speed" or anything else related to it.
What else would you like it to do?
Car: 2007 E93 335i
Default 06-25-2018, 01:47 PM
oi, ok that makes sense. I wasn't sure if it had anything to do with disabling location services.
thanks for the info
blown07's Avatar
blown07 blown07 is online now
Car: 335xi, 335i
Default 06-25-2018, 03:51 PM
Any way to go back to the previous Rev. Rev 3.6 is a connection nightmare
'07 335i LCI trunk,FBO,Meth,MHD, LSD, 12.1@118, Now with GCLites.
'07 335xi LCI trunk,FBO,Meth,MHD, 11.87@118.65, Now with VTT stage 1 Billet.
mike310z mike310z is offline
Car: e61 Xdrive 535
Default 06-29-2018, 01:59 PM
Something has gone wrong, I have the Pixel2 and now it asked me to log in - do not like that too much, tools should just work, no internet needed but fine, I registered and it all looks fine.
Now that I am registered and logged in and despite removing and reinstalling the app, unplugging and replugging the USB etc I get told to check my location settings to allow jb4 which appear to be just fine.
What am I missing ? Anyone else run into this ?
2010 e61 BMS intake, BMS Meth, ER FMIC, New, injectors, plugs and coil packs. BMS race back end flash. Sport flash AT gearbox and paddle shifter conversion
jibbajoe jibbajoe is offline
Car: mk7 gti
Default 06-29-2018, 02:39 PM
I'm having the same issue. Since the new update i can no longer connect via my OTG cable. its like the app refuses to look for the OTG cable and it keeps defaulting to bluetooth connect. I can't turn bluetooth off because it says its necessary to scan.
super frustrated as the temp is skyrocketing this weekend and i need to make changes...
Dmac @ BMS/DMD's Avatar
Car: 2008 135i
Default 06-29-2018, 07:23 PM
Originally Posted by as3.0cl
this is with the Beta app version, i am pretty sure because i got the message on the engine type being removed phone is an S8 no 9, mistype.
Interface version on App Read only is A239
Also i can leave the app open and it will not shut off if it is not connected. once connected is where i get the app crashes
Disable developer mode and it should be fixed.
Originally Posted by razo
Device: iPhone X
OS: Example 11.4
Engine type: B58
App build: 2.3.2
Kit Revision: Rev 3
JB4 Firmware Version: Not sure brand new just was shipped from Burger yesterday
Problem experienced: I can not get the app to connect to the unit. I can get error that says go to the settings page and select your kit revision, but when I go the settings tab there is nothing there that allows that choice. I just purchased the app from the appstore today and it looks like it was updated yesterday. At this point I can not activate any maps on my g30 540i.
This is resolved in the latest update available in the App Store.
Try emailing Donnie for the fastest support. He doesn't always check the forums.
support@jb4connectkit.com
As long as your speed output matches your speedo pretty well it should be within a few tenths of a second. There seems to be some discrepancies with some engine types regarding the speed param that I'm looking into.
Reason why i ask.
See if your MPH gauge matches your speedo fairly well.
You need that cord to get some of the other JB4 parameters (rpm, AFR, etc.).
You mean the new kits or the new update? I have reports of connection issues being resolved with the latest update.
Are you using OTG or a Connect Kit?
This likely isn't an app issue, but we can test it. Email me and I can send you the previous version of the app and you can let me know if it connects better.
Car: 2008 E93
Default 06-29-2018, 08:56 PM
Reason why i ask.
Highly inaccurate. After a 3rd gear pull I let off and MPH on logs show 160mph +
Default 07-02-2018, 03:43 AM
Yeah mine is off by about 32mph. At 60mph app reads 92mph.
Car: e61 Xdrive 535
Default 07-03-2018, 11:05 AM
I am on a thread and tried using a directly loaded previous version but it says I can't be authenticated, I will let you know but you may want to ping Donnie so he has more data points to work off when localising the probelm
Default 07-03-2018, 12:17 PM
Short video on how to attach the JB4 Mobile module:
DamnDatsun's Avatar
DamnDatsun DamnDatsun is offline
Car: 2010 135i msport
Default 07-03-2018, 12:29 PM
Is there a way to set a marker to see all selected parameters at a certain point on the graph? Sort of like on datazap.
Default 07-04-2018, 09:06 AM
Not sure if Donnie has that in the app but it's in the JB4 windows interface if viewing logs on your desktop.
TideMD's Avatar
TideMD TideMD is offline
Car: 2016 M4
Default 07-05-2018, 09:09 PM
The iOS app has a similar feature. Just tap the graph at whichever point you want to check and it will list the variables for that point in the log.
2016 F82 M4 // Sakhir Orange // Black extended leather // Opti-Coat Pro
JB4 (stage 3) // MHD + BMS BEF (RACE, rev12) // BMC drop-in, carbon filter delete // Injen CPs // AR Design catt'd down Ps // Active Autowerke midpipe
LCI rear light retrofit // AutoTecknic front splitters // Mode Carbon High Kick rear spoiler // Status Gruppe rear diffuser // BMS ceramic black billett exhaust tips // Macht Schnell spacers - 15mm(f), 12mm(r)
DamnDatsun's Avatar
Default 07-06-2018, 09:28 AM
So it's just an iOS feature it appears. Hopefully they can port that to the Android version soon 🤞
Mrpink Mrpink is offline
Car: M140i
Default 07-09-2018, 06:55 AM
Viewing more than 12 parameters would be very much welcome
GSORS400 GSORS400 is offline
Car: Q50 Red Sport
Exclamation 07-11-2018, 06:13 PM
I updated the firmware on my JB4 on my Q50 using the JB4_Q50_OBDII_3_T1.hex file. When I check the FW version on the BT app, it is listed as 50/3//5. I am assuming this is the FW version on the JB4. The update went fine, and I know which upgrade file was used because I just completed it, but I might miss a FW upgrade in the future. So to keep track, does anyone know how, or if it is possible, to decode/decipher the firmware version listed in the JB4 app to determine which FW file was used?
Default 07-11-2018, 07:10 PM
You are on v3 for the 50/ series JB4 which happens to be for the q50.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
blown07
