ammar.alqisi ammar.alqisi is offline
Car: E92
Default PURE N54 STAGE2 TURBOS - 05-25-2018, 03:40 AM
We bought a PURE N54 STAGE 2 TURBOS, the problem is a huge drop boost after 5000 rpm, using JB4, no boost leak, any suggestion ?
Default 05-25-2018, 09:46 AM
Post a log in the support section.
Car: E92
Default 05-30-2018, 05:40 AM
The logs attached, something wrong on high rpm .
we changed everything like is blow of valve, injectors , air filter , boost solenoids , etc
Steve @ PURE's Avatar
Steve @ PURE Steve @ PURE is offline
Car: F80M3
Default 05-30-2018, 09:44 AM
What other mods do you have ? also what BEF are you running?
I can see there is over boosting on map 6 then drops, but on map 4 holding the boost with FF 148. Have you pressure test the system to check for boost leak ?
Pure Turbos | Bootmod3 | 2MGT3 WideBody | Aristo Wheels | G1000 APRPerformance wing | Autopower Rollbar | Status Gruppe Coilovers | RK-Tunes Intakes and ChargePipes | GTHAUS Meisterschaft turbo back | DinMann CF parts | Gaphix Seats Belts, RECARO CS Sportster | JB4 | CSF Top and front coolers | Full MPerformance interior |
Car: E92
Default 05-30-2018, 10:11 AM
the boost leak pressure tested, no leak .
some runs under over boost, in any boost the dropping happen on high rpm .
Car: F80M3
Default 05-30-2018, 10:23 AM
yeah i can see that. At what psi did you pressure test it ? What other mods/BEF do you have? are you running 3.5 tmap ?
Car: E92
Default 05-30-2018, 10:39 AM
We did the test on high pressure,
Mods :
Pure Turbo Stage 2 + 3.5 MAP Sensor
afe air filter
intercooler
charge pipe
blow of valves
JB4
Meth kit
Is it possible the problem from the turbos ?
Car: E92
Default 05-30-2018, 05:51 PM
If the car doesnt have a ********, the boost will drop on high rpm ?
Dave @ Fuel-it!'s Avatar
Default 05-30-2018, 09:05 PM
Mods :
afe air filter
intercooler
charge pipe
blow of valves
JB4
Meth kit
What is "high pressure" can you be more specific?
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
Car: E92
Default 06-01-2018, 05:04 AM
I mean we pressured it on high pressure for boost leak test .
I feal something open on high rpm and out the all pressure .
Default 06-01-2018, 09:22 AM
What BOV/DV are you running on your Chargepipe?
Car: E92
Default 06-01-2018, 11:53 AM
Am using turbosmart blow valves
Default 06-02-2018, 10:37 AM
I'd say you still have a leak of some sort. Have you checked your intake inlet to make sure it's fully on the turbo?
