(#751)
135idct 135idct is offline
Default 08-02-2018, 05:56 PM
Just posted a new set of JB4 BEF maps.
1) Addressed false alarm under boost fault code in various map versions
2) Minor changes we've made along the way during development
3) Incremented the version of maps within the same family to avoid confusion
any plans for BEF for bigger turbo n55 like pure stg2 or bigger
Default 08-02-2018, 08:45 PM
Right now those are just custom tuned as needed starting with the existing BEF map as a template. Normally, not many changes are needed, other than maybe taking out a degree or two of timing up top.
neejay neejay is offline
Car: 2011 535i M-Sport
Default 08-06-2018, 08:32 PM
Terry, thanks for the "Recent changes" and referencing the date in the download URL text. I'll update tomorrow and maybe pull some logs.
2011 535i M-Sport - BEF via JB4/MHD, VRSF Chargepipe, BMS Intake, Megan Supremo Exhaust
spammer spammer is offline
Car: 435i
Default 08-07-2018, 01:05 PM
Originally Posted by Phataxe
@Spammer to run anymore e85 then you are now you would need a LPFP and a PI setup.
Is there anyway to get more fuel without going WMI or PI? Could just replacing the LPFP or HPFP be enough? Sticking with stock turbos for now until they die which will be a few years hopefully.
Performance: 2014 435i : F33 (convertible) : 8AT : BMS Intake : VSRF Charge Pipe : JB4 Stage 2 : FF Wires : EWG Wires : 30% E85 + 93 Octane
Bling: CF Lip, Rear Diffuser, Mirror covers | Burgers 18MM spacers back, 12MM front | Burgers chrome tips.
F335 F335 is offline
Car: F30 335i
Default 08-07-2018, 04:57 PM
can I use bm3 to load the bef for jb4
Default 08-07-2018, 06:07 PM
When using MHD to load the BEF it ports over the changes in our file to match the software version in your car automatically. I don't believe BM3 does that, plus it's a lot more expensive, so I'd sell the BM3 if you have it and use MHD to load them.
Phataxe's Avatar
Phataxe Phataxe is offline
Car: 2014 435I
Default 08-07-2018, 06:15 PM
Changing the LPFP might get you a little bit more E85 thru the HPFP but not by much at all.. PI or meth would be your best bet. The problem is the HPFP can't Pump the e85 fast enough even if the LPFP is giving it fuel faster then it can use it
'14 435I RWD MHD/JB4 "JB4_F_EWG_E85_PI_10" BEF | Rev9 FMIC | VRSF CP | BMS Intake | HP Down pipe | Borla ATAK Exhaust | Stage 2 LPFP | BMP PI BMS PI controller | EWG Harness Upgrade | e85 | NGK 5992 Plugs "0.020"
Fmonteiro444's Avatar
Car: 09 E92 SG
Default 08-08-2018, 10:06 AM
I wasn't able to run more than E30 on my stock turbo 2014.
14 F30 335xi AT- SpeedTech Stage 3 w/ BW-8374, JB4 w/MHD Flash, E85, AFE Intake, VRSF 6" Race FMIC, VRSF 4" pipe, VRSF CP, Fuel-it Stage 2 LPFP and PI
09 e92 335xi AT - FBO, RB's, Flash only
11.7 @ 125mph
11.6 @ 116mph (misfire)
chentw chentw is offline
Car: BMWX4 35i
Default 08-10-2018, 05:31 PM
Terry, can I do a backend flash my x4 35i? MHD will not let me flash EWG_PUMP or EWG_RACE. It will only let me flash PWG3 files.
dror135's Avatar
dror135 dror135 is offline
Car: m1235 2013 f20 n55
Default 08-11-2018, 07:55 AM
hi terry
If I upgrade Mhd to STG 2 software
Can still use JB ( PI and maps )
thx
m135 2013 at-8 PWG STG2 PureTurbo **-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
Default 08-11-2018, 09:49 AM
Why would you buy a MHD map when you can use/modify our BEF map designed specifically to work with the JB4 for free? To answer your question though you can run any map you want. How you set the JB4 depends on the details of the map and what you're trying to do.
WakeOfDeath WakeOfDeath is offline
Car: X6M & M2
Default 08-11-2018, 10:58 PM
Yes you can but you'll see with BM3 u don't need this
LMAO, you know damn right is the opposite!
BM3 does software match, MHD does not!!!!!
mhd forces all cars to run on the same rom version!!!!!
thats also why it takes ****ing 30 minutes to do first flash!!!!!
I've had both and can't believe Terry is giving misinformation again to gain himself another dollar.
Lets see.. Bm3 $595 + $20 Enet to OBD2 cable same one used for coding etc, works on iPhone/Android/Mac/Windows and can be sold or transferred to your next car one time.
MHD cannot be sold or transferred = Already more expensive!
jb4 799 + mhd license = $1000 + jb4 mobile app $30 + old dkcan cable you use which is like another $50+ c'mon!
Caveat Emptor!
18' M3 CP SO DCT - Mods: BM3 E30, Pending: CTS Turbo AWIC/CP/D.P. & MP
15' X6M DN - EnzoTuned @EnzoRacing Flash
17' M2 - FBO CTS Turbo FMIC/CP/D.P. + BM3 E30
WaqasRiyami's Avatar
WaqasRiyami WaqasRiyami is offline
Car: Bmw 535i - 2011
Default 08-12-2018, 02:30 AM
Caveat Emptor!
Haha why are you comparing MHD BEF with BM3 flash only ??
MHD only & BM3 only = MHD Cheaper ! And if you go the BEF + BM3 then it will be more expensive
As we are JB4 users BM3 & MHD are only tune *BEF* flashers to us.. so we dont care about both MHD or BM3 tunes or OTS .. we only use them to flash our BEF's
Considering the above the cheapest flasher right now is MHD..
Don't be Biased to a company more than other just find what suites you the best and go for it
2011 F10 535i N55 PWG AT | JB4 ISO - Bluetooth.Rv3 | N20 3.5bar TMAP Sensor | TREBILA BEF Performance Tune | Pure Stage 2 Turbo | GFB DV+ | Fuel-It Stage 2 LPFP | BMS 100% Meth-Dual CM7 Injection | 93 Octane Fuel | BMS Intake | ER 4" CLess D/Pipe | ER 3" Charge-Pipe | Wagner-Tuning Competition Intercooler | https://i.imgur.com/iR4wm3I.jpg |
dror135's Avatar
Default 08-12-2018, 05:26 AM
i know
just asking
