(#501)
JayRee JayRee is offline
Car: 2009 BMW 535i
Default Map 6 Log and Settings - 08-01-2018, 07:28 PM
Hopefully one of you SME's can help me out...I've been running map 6 recently and everything feels great, just wanted someone to take a look at one my logs and my Map 6 settings. Thanks.
2013 X5M
Modifications: K&N Drop-In Filters | JB4 | Exhaust | xPH Trans Flash | HCP Stage II ECU Flash Tune
Richard H's Avatar
Richard H Richard H is offline
Default 08-03-2018, 12:38 AM
Is that a map 2 log?
Car: 2009 BMW 535i
Default 08-03-2018, 09:50 AM
Yes it is. Sorry about that I attached the wrong log. This is the correct one...
2013 X5M
Richard H's Avatar
Default 08-03-2018, 10:24 AM
That looks great.
Trims are in check also.
Need to sort my trims out
m5james's Avatar
m5james m5james is offline
Default 08-03-2018, 03:17 PM
Raise your FOL to 90, Richard...that helped me. I'm also in talks with a company about a stage 2 LPFP. N54's need a stage 2 at our power levels and/or to better run E85 mixes so I figure best follow in their footsteps.
'08 BMW 535xiT - MHD 1+, BMS DCI, RB/Mishimoto, VRSF 7"
Richard H's Avatar
Default 08-09-2018, 11:24 AM
So I flashed the truck back to stock
Worried about the target being so low.
Also AFR still leans out and trims max at low boost
Log attached
m5james's Avatar
Default 08-09-2018, 11:36 AM
Originally Posted by m5james
Is there a wastegate rattle fix? Mine went from fine one day to REALLY bad :/ I read something likely N54 related since it didn't work but I adjusted Future Use D from 0 up to 99...still rattles. I read something else about steering wheel controls (not controllable via the app) in settings 10, 11 & 12 but they didn't explain how/why, let alone if it's even available on our firmware.
Bump for anyone who might know...
