Nikita147 Nikita147 is offline
Car: bmw 340 MT
Angry JB4 + Security Kit = Check Engine - 03-02-2018, 09:47 PM
Hi
I installed JB4 as per instruction, but I have security pack that listen to the radio channel and activate OBD-II socket when it is authorized with additional radio security key.
So OBD-II is activated usually ~10 seconds before I press "Start engine" and deactivated when I lock the car with car key.
JB4 with this config works fine about 2-3 days, but on the 3rd day JB4 activate Check engine light with "108005 No Description Found" error.
I think it happens because JB4 is should be always online and count OBD-II connection errors and when it has more than 5 error it activate CE.
Is there any option to update JB4 software in order to manage this configuration?
thanks.
Nikita
Default 03-03-2018, 09:57 AM
What firmware version are you running exactly?
Update it to the latest and see if that helps.
Car: bmw 340 MT
Default 03-06-2018, 12:00 PM
I have Firmware version 58/8//5. Is is the latest one?
Looks like it is version 8.
In forum I found two firmwares: BMW_B48_B58_OBDII_8 and BMW_B48_B58_OBDII_8_T12. What is the difference between them?
Sorry, I tried to search it but didn't found.
Default 03-06-2018, 12:03 PM
There are various subversions posted.
Car: bmw 340 MT
Default 03-09-2018, 12:48 AM
I updated to the latest version BMW_B48_B58_OBDII_8.
Still the same issue: after 5-6 trips I see CE light on the panel with the same error "108005 No Description Found".
Car: bmw 340 MT
Default 03-22-2018, 01:50 AM
I updated to BMW_B48_B58_OBDII_9_T4.hex.
Unfortunately have the same issue - I have CE after 5-8 trips. Any other options to manage it?
Default 03-22-2018, 10:17 AM
You can not have anything else in the OBDII port and need the JB4 OBDII cable installed.
Car: bmw 340 MT
Default 04-04-2018, 12:54 AM
I dont have anything else in OBD port except JB4 . The only difference with stock is that OBD port is disconnected (signal or power pin) when car is locked and connected back when I unlock the car and security RF-token is in the close area.
I would assume that this error "108005 No Description Found" is produced by JB4 and it is because JB4 sense that it was just connected to the car.
