(#401)
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 03-12-2018, 06:12 PM
Originally Posted by Yoandry
Thats my option so far but Im trying to get more information as I can before pulling the trigger.
Like, whats the best way to disable PI if I pump just 93.
If you’re using JB4 with PI controller is so easy. Just set all Fuel Bias to 0.
Or you can install an actual switch of the ground wire of the PI controller and route it inside the car.
2011 E92 N55 AT | FBO | JB4 + MHD | Pure Stg 2 | Alpina B3 TCU Flash | Fuel-It Stg 3 LPFP + PI Platinum Kit + BMS PI Controller | COBB Exhaust | E85 |
Coming Soon: ABR N55 Built Motor | Big Boost 3.4 Turbo Kit | 6HP19 Built Trans
Yoandry Yoandry is offline
Car: 13 f30 335i
Default 03-12-2018, 06:23 PM
Yeah I have jb4 + BT and will get the bms controller for PI
F30 PWG PS2 + WMI + MHD Bef/JB4 + VRSF FBO + N20TMAP. MPPK, MPE, MP-Susp, MP-Brakes, 437M, MP-Lip, MP-Diffuser, MP-Spoiler, MP-Rocker Panel, MP-Sills, MP-Pedals, MP-Grille, MP-Mats, IND Reflector.
Default 03-12-2018, 08:01 PM
Agreed, just set all your fuel biases to zero, that is the easiest way to turn off PI now. There has been a lot of progression on the control side with the JB4 since it's inception.
Car: 13 f30 335i
Default 03-13-2018, 05:40 AM
Hi Steve,
Duty bias on ISO 10 for PWG is auto adjusting. How then?
Default 03-13-2018, 03:04 PM
Duty Bias has nothing to do with Fuel Bias.
Car: 13 f30 335i
Default 03-13-2018, 03:19 PM
Oh ok my bad lol.
orteeze orteeze is offline
Car: 08' 335i
Default 03-20-2018, 08:24 AM
Anyone know what gauge wire the 12v and RMP signal wiring is?
Need to buy some of those bullet wire taps.
E90 LCI M Sport
keyap keyap is offline
Car: N55 135i
Default 03-22-2018, 07:29 AM
Hay Steve, any development on the PI LPFP sensor?
Default 03-22-2018, 10:02 AM
We've had those for quite a while.
You can email us at info@fuel-it.com
Car: N55 135i
Default 03-22-2018, 10:16 AM
