(#2501)
kilerek997 kilerek997 is offline
Default 03-16-2018, 08:51 AM
Hey,
I have bought Harness A, and my n55 is Harness B. My case is ****ty, because I bought it when I was in USA last year and now I cannot change it because:
- I bought used JB4
- They dont have any parts like this in Europe
Thats why I would be very grateful for any kind of help because I spent a lot of money for my JB4 and it is not working because of the harness...
At first I thought that just connectors are different, but wires are still the same so I cut the connector rims and then it could be perfectly plugged. After I plugged whole harness according to the manual it didn't work and i had check engine light on the dashboard.
My question is, does the harness have any more difference than the connectors (different wiring etc) ? If yes then is it possible to do something that it will work or I just lost so much money?
Thank you for any kind of help!
Default 03-16-2018, 08:54 AM
Just the connectors and wiring... Just sell it used to an A customer and buy a correct B model for your vehicle.
Default 03-16-2018, 09:08 AM
But the problem is that nobody has JB4 in my country so I would have to ship it to USA and pay for the shipping back which would be extremely expensive. Can you explain me what is the difference in the wiring and can I or some experienced electrician change the wiring to make it work ?
alexis485's Avatar
alexis485 alexis485 is offline
Car: 2011 BMW E92
Default 03-21-2018, 07:25 AM
Terry,
Any plans on displaying the transmission oil temp in the JB4. I'm getting my AT built and I'll be pushing it near its limit.
2011 E92 N55 AT | FBO | JB4 + MHD | Pure Stg 2 | Alpina B3 TCU Flash | Fuel-It Stg 3 LPFP + PI Platinum Kit + BMS PI Controller | COBB Exhaust | E85 |
Coming Soon: ABR N55 Built Motor | Big Boost 3.4 Turbo Kit | 6HP19 Built Trans
Default 03-21-2018, 08:52 AM
Certainly something we can work on adding.
Car: guess...
Default 03-22-2018, 11:11 AM
Originally Posted by Kevin Wei
Hi Terry, Currently running ISO 5_11 on my 2011 BMW 335i and I found menu 11 won't hold the volume that I input. I tried to set it to 5 but every time I across menu 11 from menu 10 or from menu 12, the setting will drop and after few times that will drop to 0. For sure there is a bug on menu 11 setting.
Anyone having the some problem as I do regarding to menu 11 or just me?
Recently, I too have been having this same symptom. I have a 2012 335i. Was this ever solved? I've seen some questioning whether menu 11 was for fuel open loop(FOL) adjustment OR for pedal input refinement. I think FOL adjustment was an earlier version or for a different car entirely. The current wheel control guide says it IS for pedal input.
One other gremlin I've found is my Open Loop value always stays at zero. I thought it was a self learning parameter. If not, what was the default setting?
Default 03-22-2018, 11:21 AM
On previous firmware could be, make sure you run the latest firmware as we always fix little bugs and problems along with the performance updates as we go.
Car: guess...
Default 03-22-2018, 11:46 AM
Sorry, I should have said what SW/FW I'm running. JB4/G5 N55_ISO_5_16(5/16//3), Interface A217. I believe these are the latest ones. I was having this issue previously with 5_13 as well. Are there any JB4 settings that would have a reactionary effect on menu 11? Could a value somewhere else be prompting/forcing pedal value to fall?
cesarortiz23's Avatar
cesarortiz23 cesarortiz23 is offline
Car: e90 335i sedan
Default 04-10-2018, 04:00 PM
hey you guys so im on firmware ISO_5_14
if i update my firmware to the newest one (16) would i get a check engine light because on my f30 when i updated my firmware there wasn't a option to hide the code for ***** ** while track use.. i had to keep clearing it but i mean is still a sketchy light to see while your in a track........
so i sold my jb4 on my f30.
is it the same on e series ?
i want to update it but then i don't want to be driving at the track with a service engine soon light on..
hi rpm hi rpm is offline
Car: 2013 335i Xdrive Coupe
Default 04-10-2018, 06:27 PM
I believe so.
Car: e90 335i sedan
Default 04-10-2018, 08:43 PM
Originally Posted by hi rpm
I believe so.
hmmm ok yeah i found a thread about this...
this is crazy..
umm i guess ill just stay on my firmware now and see how long it lasts
i can do that right
Default 04-10-2018, 10:06 PM
i can do that right
If it runs, it will probably keep running.
