neowolf neowolf is offline
Car: 335I 2007
Exclamation Help! Jb4 new - 05-21-2017, 10:50 AM
I bought a new JB4 like a month ago. In the beginning I get a random safe-mode errors. I download the motor (n54) e92 repair all high pressure pump , water pump,thermostat, oxygen sensors, injectors, turbos, seals, etc... like $5,000. If i use the car without the jb4 the car work fine and great. When i put the jb5 I start to get errors inclusive if the jb4 is on map 0 erase the codes automatic. I flash the latest firmware and i cant resolve the problem. Every 5 min i get the safe mode message and jb4 automatic clean it, and in some minutes i get the same error and get safe mode drive.
Any one can help me!!
please
NorCalN55 NorCalN55 is offline
Car: '11 335xi M Sport
Default 05-21-2017, 11:30 AM
please
You need to attach a log in .CSV format. This log contains information about your jb4 configuration and is needed to adress your problem.
Default 05-21-2017, 11:40 AM
2F0C is an air intake temp fault.. Log might shed more light on it. Does JB4 have anti-lag kit installed?
jsandor91's Avatar
jsandor91 jsandor91 is offline
Car: E90 LCI 335i
Default 12-28-2017, 07:45 AM
sorry to bump a old thread but i'm currently running my jb4 with anti lag installed i'm intermittently getting a 2F0C code. with the half engine light. I have not had a chance to re flash my car with a backend flash so currently running without. Is this likely my issue or am i looking at a fault tmap ?
Default 12-28-2017, 10:53 PM
The BEF is required for anti-lag.
Hyab00sta Hyab00sta is offline
Car: 09 335xi
Default 03-22-2018, 07:47 AM
I just installed my jb4 with anti lag chip but not turned on in settings. Is it safe to say without a BEF the 2F0C will keep coming up sporadically?
Default 03-22-2018, 10:19 AM
I don't recall the code that it will generate but yes, you need the BEF installed.
