(#726)
Newguy123's Avatar
Car: 12' 135i
Default 05-08-2017, 11:48 AM
Originally Posted by lazer
Why my speed limitee still there with pump flash?
Yeah mine is still there too. I know MHD does remove it on our cars as I watched houtans car on the dyno running flash only via MHD pull past 155 and auto shift into 7th gear haha. Hopefully soon they get it all dialed in
12' DCT 135i
#PURETURBOS
#FUELIT
KevinC39 KevinC39 is offline
Car: 11 335i 6MT RWD
Default 05-08-2017, 12:04 PM
PS. This week I'm working on migrating over the latest N54 flex fuel developments including the BETA virtual flex fuel sensor, PI scaling on ethanol content, and various physical sensor input options.
Hmm, I'm interested to hear more about this. I don't follow the N54 side of things very much but it looks like it's time for me to go do some snooping around over there.
Edit: After reading up, it sounds pretty good to me. I've already got the ethanol sensor installed and ran to the jb4 so I'm ready to go.
2011 E90 335i RWD 6 Speed
FBO JB4 MHD
tho tho is offline
Car: 2011 335i Convertible
Default 05-11-2017, 04:43 PM
Can I drive 5-10 miles with Ethanol content > 40 on the pump flash? I have to add E85 at my house and plan to drive about 5 miles to the gas station to fill up the rest of the tank. I'm currently running about E30 in my tank now and I want to add 7 Gal of E85. I can load the E85 flash if needed, but would rather not if I don't have to.
I just want to make sure that I don't stall out halfway there and then have to try to flash on the side of the road.
EDIT: I'm answering myself. Yes, it was no problem. I figured the chances of failure was low, so I risked it. Made it to the gas station A-OK.
2011 335i - JB4 ISO, MHD PUMP BEF, DP, CP, 5" stepped FMIC, BMS Meth Injection CM10, BMS Intake, Pure Stage 2, Pure Inlet, Flex Fuel wires, Fuel It Stage 2, DV+, N20 TMAP, Ethanol mix
orteeze orteeze is offline
Car: 08' 335i
Default 05-16-2017, 07:43 AM
Any update? I asked this question before, will I still have to use an ethanol analyzer before connecting to my JB4 so the JB4 Mobile App Gauges reads out ethanol content?
E90 LCI M Sport
Default 05-16-2017, 08:07 AM
I have a version ready for testing. You need the latest windows interface or BETA JB4 Mobile interface.
With a virtual flex fuel sensor no hard wired ethanol sensor is required.
Car: 08' 335i
Default 05-16-2017, 08:21 AM
If you need a beta tester let me know.
E90 LCI M Sport
Default 05-16-2017, 08:28 AM
Email me!
Default 05-16-2017, 09:15 AM
I can help as well if needed. Just need to figure out where to get the beta app. I also already have the sensor and jb4 analyzer so it might be interesting to see how close they match up.
FBO JB4 MHD
Benise Benise is offline
Default 05-16-2017, 05:27 PM
Virtual flex fuel sensor? Is that a way of using the JB4 to calculate ethanol content?
Default 05-16-2017, 05:32 PM
That's exactly it. Should give your ethanol content without the physical sensor like I have.
FBO JB4 MHD
Default 05-16-2017, 06:14 PM
So how do you get in on helping test that? Also does that mean the JB4 would be able to make adjustments due to ethanol content? Or simply just be able to give you an ethanol content reading?
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 05-17-2017, 01:01 PM
Email me!
Email Terry for information on Beta testing
Here is the thread if you want to following along with the N54 development.
http://www.n54tech.com/forums/showthread.php?t=46407
2011 E92 335i Auto 12.0 @ 125MPH
JB4 ISO | Cobb BMS Pump BEF | XHP Stage 3 | ER Chargepipe | VRSF 7in Intercooler | BMS Methanol | Performance Line DP | Pure Inlet | Pure Stage 2 | Go Fast Bits DV+ | Diff Lockdown Bracket |
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 05-17-2017, 01:45 PM
I'm down to test it I you need more people
<-- Click on pic for the build thread 1m bodywork,helixIC,ONE EIGHTY head lights, JB4,Seibon GTR hood , i carbon trunk,meth, BMS intake,black lines,CKS coil overs, Sparta Evolution 2 piece rotors , PURE Stage 2 Turbo, BBS FIR's coming
Diox Diox is offline
Car: 2011 E90 FBO+JB4
Default 05-18-2017, 05:09 AM
Hey, I am about to install my pure stage 2 on my e90
Which BEF should I be using? Still pump? I plan on mixing up to E30/35
I don't have a fuel it stage 2 yet, no PI or meth planned
Newguy123's Avatar
Car: 12' 135i
Default 05-18-2017, 06:52 AM
Yeah just run the pump BEF for now
12' DCT 135i
#PURETURBOS
#FUELIT
Car: 2011 e92 335i
Default 05-18-2017, 08:12 AM
Yeah pump flash then log. Running a completely stock fuel system with E and no other supplemental fueling you will hit the limit pretty quick.
Newguy123's Avatar
Car: 12' 135i
Default 05-18-2017, 08:20 AM
I did some testing recently since my misfires are gone. I decided to turn off my port meth injection and see just how much boost I could run on E40. To my surprise I still haven't found the limit, I've been running 19 psi to read line with no issues on the stock fuel system & PS2.... Then my water pump decided to take a **** ha ha but when I get my car back I will slowly keep turning it up until I find a limit. Just sharing my findings :-)
12' DCT 135i
#PURETURBOS
#FUELIT
Car: 2011 e92 335i
Default 05-18-2017, 09:06 AM
Good to know. I know Ken hit the limit in his 135i at 17 psi targeting like 11.8 AFR. Since that is a little richer than most JB4 setups I would have assumed about 19psi to be the limit.
Running E30 and meth I have had a couple of crashes at 25psi around 5,000 RPM. Other than that I have found this to be the best setup when not running any kind of port or throttle body injection.
tho tho is offline
Default 05-18-2017, 09:33 PM
What is your Meth/water ratio? We have very similar setups, in fact I have several of your logs saved to use as a starting point once my setup got closer to yours.
When you say "crashes at 25psi" you mean timing crashes? Or fuel pump issues? Do you have examples of this? I'd like to get a better idea of what to look for. I'm currently trying to get a decent 21psi run, but my goal is to try and run 22-23 on a regular basis. I'm just not sure if it's possible with my mods.
fisc0h fisc0h is offline
Car: 335i xdrve/m-sport
Default 05-19-2017, 08:20 PM
Not sure where to post this, but I flashed the 5.15 ISO N55 firmware today, with 2gal of ~e40 in the tank. Initial readings on the JB4 mobile app showed ~E40.
I then filled up with ~E45. Readings then showed ~E43-E45. After doing some map 5 and runs, The reading elevated to E50. I let the car sit for awhile and started it up and the reading was up to E65. After driving some more and some map 7 runs, it now reads E60.
Is this normal behavior? I have the e85 BEF and have the default offset settings set.
2011 335i x-drive MSport: MHD E85_BEF + JB4 ISO 5.15 / Pure Stage 2 / Stage 2 LPFP (bucketless) / N20 TMAP / BMS Intake / ER CP / VRSF DP / VRSF 7" FMIC
extreme-eg extreme-eg is offline
Car: Toyota 86
Default Yesterday, 11:57 PM
Just to clarify, do the boost targets remain the same when running a BEF as they are on JB only ?
Map 1 - 12.5 psi
Map 2 - 14 psi
Map 6 - 16 psi
I've loaded the PUMP BEF via MHD and am seeing 19 psi peak on the Autotune map. Just trying to figure out if the boost targets are different when running in 4/2 BEF mode.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Iflickr.als, N55x1
