(#876)
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 09-29-2017, 04:27 AM
Originally Posted by hi rpm
Anyone planning to have traveling repairmen go from town to town doing bench flashes? Or a database of shops that can do it? I contacted two local tuners, of which one responded, and said they can't do it. The direct and indirect costs for some of us to send out DMEs are outlandish.
we are building a list of unlockers, email us.
Thanks. I ordered a JB4 and I'm going to wait and see if it works well by itself for my applications.
I watched three DME removal videos and they were in three different locations ("N55" obviously F-series, 2x "E90"), so I don't even know where mine is. E92N with N55. If the JB4 doesn't cut it I'll probably like, do more posts about that.
Under the throttle body. Not very complicated to remove.
ganque ganque is offline
Car: 2013 135i M Sport
Default 09-29-2017, 11:34 AM
Hey Martial, I sent you an e-mail with a confirmed unlocker in Mexico with 2 locations.
elco69's Avatar
elco69 elco69 is offline
Car: X1
Default 09-30-2017, 04:59 PM
Would I need or benefit from Flex Fuel wires when running the MHD Back End flash and about 40% e85 mix?
2014 X1 ///M Sport, N55, JB4, BMS Intake, VRSF Down Pipe, BMW PE, VRSF Charge Pipe, VRSF 5" Stepped FMIC
Default 09-30-2017, 05:15 PM
Good to have the fuel pressure connector on there so the JB4 can compensate for fuel trims based on ethanol mixture if it ever needs to.
Fiekie135i Fiekie135i is offline
Car: bmw 135i coupe n55
Default 10-03-2017, 05:35 PM
Can someone please help me.
I had my dme bench flashed and unlocked with the mhd patch. I flashed the 9E60B pump file back end flash. It was looking great until it failed at 90% with error "failed to write section: 7F 36 80", every time I try to do the "retty a failed map flash it fails at different percentages with the same error. If i attempt a long write out fails immediately saying could not clear memory. I read that if I flash back to stock it will remove the unlock patch. I am unable to start my car I've disconnected battery. Switched device off and on again. No luck. please help
SherwyWP SherwyWP is offline
Car: Bmw 135i n55
Default 10-03-2017, 10:14 PM
Shafeek,did you have a battery charger on??if not,thats your issue!
2011 135i n55.VTT stage 2 DBB turbo.Jb4 iso,flex fuel,MHD backend flash,NX water meth with fsb CM10 50:50.Bmw Peformance axle back.Bms ***** **.Wagner stepped cooler.Bms chargepipe.Rennzport hotside chargepipe.stage 2 buckeless lpfp.Bms oil cooler lid with sport cooler valve.Bms intake.Rennzport intake scoops.NGK 5992 plugs.jb connect v3
Default 10-03-2017, 10:25 PM
Yes I had battery charger on.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 10-04-2017, 06:12 AM
Make sure ignition is fully on (insert key, press the start button without touching the brakes until the dashboard displays the actual fuel level), otherwise the DME will go into sleep mode and will not start long flashes as you experiment.
If that stills fails, it's often due to a bad KDcan cable. See page 5 of the user manual for recommended cables per country
http://www.twisted-visionz.com/mhdguide
Default 10-04-2017, 11:51 PM
Awesome, thank you! a different/better KDcan cable worked first time for me. Thanks MHD
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default MHd update 1.23 - 10-10-2017, 08:32 AM
- Small user interface improvements
- Eco coolant set to normal coolant for sport / track modes.
- Added Monitor on app start up option.
- Autolog pedal threshold increased from 50 to 70%.
- Logging is stopped/resumed when the app goes to the background/foreground.
- For DME swaps, VIN is checked against the CAS module so licenses remain valid.
- Modified the N20 sensor setting to match the F80 OEM settings.
ac2 ac2 is offline
Default 10-11-2017, 09:45 AM
Originally Posted by Stoolz
Hopefully Terry can remove that little gremlin next release.
You can disable the error code 321F by modify the bin yourself.
Europe car does not have Leak diagnosis pump. You can check it by enter your vin at realoem under FUEL > VENTILATION.
Tyson413 Tyson413 is offline
Car: 2012 BMW 135i
Default Hi everyone. - 10-12-2017, 10:48 AM
I’m new to this but I need some help.
I have 2012 135i 6MT, jb4 map2,charge pipe,BMS intake,muffler delete,93 octane. I’m not planning to do any other mods but I heard about MHD BEF for jb4. Can someone tell me please if I should do this? Will
I get more power? Maybe some other benefits?
Thanks.
Toome's Avatar
Toome Toome is offline
Car: 2012 BMW E92 335i M-Sport
Default 10-12-2017, 11:21 AM
Thanks.
I would check your build date to make sure you have a DME that is directly flashable. If not you will need a DME unlock, which can be kind of a pain. I did the entire process myself, but it is not an easy task.
This is directly from MHD:
http://www.realoem.com/bmw/enUS/select and enter the last 7 digits of your VIN in serial number. Click Browse parts the ENGINE ELECTRICAL SYSTEM and check both CONTROL UNITS > MEVD1726 section. If the it says "No parts found matching your car." you have a MEVD172 which is directly flashable.
Whether you need the unlock or not, I would highly recommend getting MHD. It will allow you to explore several tuning options (JB4 only, JB4 + BEF, flash only). Adding the BEF won’t add any power but will greatly improve smoothness (The throttle with the JB4 feels like an on/off switch compared a much more linear feel with a BEF or flash only). MHD will also allow you to add exhaust burbles, cold start noise reduction, surpress a CEL for c a t l e s s - d o w n p i p e (s), etc.
12’ E92 335i 6AT - Alpine White M-Sports Package
Mods - | JB4 ISO | BMS Pump BEF | BMS Intake | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7” FMIC | Alpina Flash | Euro Headlight Switch | Avant Garde M359 | Michelin PSS
Car: 2012 BMW 135i
Default 10-12-2017, 12:19 PM
I just checked and it says parts not found under MEVD1726 so I guess I can flash it with no problems. So you telling me if I add MHD BEF to jb4 i’ll have option to some how hide CEL light if I install **?
Toome's Avatar
Default 10-12-2017, 12:57 PM
Correct, but that is just one of many benefits. The more linear throttle IMO makes the car much more enjoyable to drive. Definitely worth the $200. Not to mention N55 MHD is still in its early stages, so it’ll have many more updates to come.
Car: 2012 BMW 135i
Default 10-12-2017, 02:04 PM
Thank you so much for your help. Last question do you know anything about no lift shift for n55. Will it work with this flash?
Toome's Avatar
Default 10-12-2017, 03:26 PM
I do not believe there is a NLS option out right now for the N55. Only N54.
Car: 2012 BMW 135i
Default 10-12-2017, 03:49 PM
As I understand you have ****** es *********, you have no light on your dash board right?
I am curious about state inspection if i’ll be able to pass it?
Toome's Avatar
Default 10-12-2017, 04:35 PM
Correct I do not have a SES light on my dashboard, however you will not pass state inspection because OBD2 catalyst efficiency will show "not ready". Only way to pass emissions legitimately is to put the OEM/Catted d o w n p i p e back on.
Car: 2012 BMW 135i
Default 10-12-2017, 04:38 PM
Thank you for all info.������
Car: 2012 BMW 135i
Default 10-13-2017, 12:11 PM
Hey there. I probably will install MHD BEF flash next week. Can you please tell me which file do I need to download? My car is 6/11 production year? And if you know tell me please what I should check in the boxes when I will be installing it? For example if I have C A T L E S S D O W N P I P E should I check the box?
Toome's Avatar
Default 10-13-2017, 01:09 PM
I would start with the 98G0B Pump flash. The 9E60B files are for late E-series (does not apply to you).
If you have a c a t l e s s - d o w n p i p e then do NOT check the box for OEM/Catted d o w n p i p e before flashing.
Car: 2012 BMW 135i
Default 10-13-2017, 01:26 PM
Sorry for stupid question but where do I find this 98GOB file?
Toome's Avatar
Default 10-13-2017, 01:46 PM
Bottom of the first post titled: 8/17/17 JB4 MHD N55 Map Release
Car: 2012 BMW 135i
Default 10-13-2017, 01:56 PM
Thank you so much.
