naoaki's Avatar
naoaki naoaki is offline
Default About auto clear - 10-11-2017, 05:14 AM
Hello. I updated from firmware 32.6 to 32.9 T 2. Auto clear was canceled after updating. I'd like to reconfigure, but what number should I choose in the dash menu? Thanks in advance for all the responses in advance.
BMW 2007 E90 335i
JB4 G5 IOS MHD race flash MMP High flow aluminum intake MMP Hot side inlet Down pipe Outside intercooler Twin oil cooler cp-e charge pipe BMS meth kit turbo lab stage 1 turbo CSF radiator fuel-it stage 1 pump
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 10-11-2017, 10:06 AM
Do you mean revert back to the 32.6 firmware?
2009 535i Sport - 548whp
Software :
naoaki's Avatar
Default 10-11-2017, 01:44 PM
Updated to 32.9. Then auto clear is no longer usable. Is there no auto clear at firmware 32.9?
BMW 2007 E90 335i
Mr. T Mr. T is offline
Default 10-11-2017, 01:46 PM
Believe auto-clear was removed with the latest updates so JB4 could be compliant with some regulations.
LessIsMore's Avatar
Inner Circle Member
Default 10-11-2017, 02:13 PM
Naoaki,
read the E-series jb4 thread that is sticky'ed in this very forum.
Read close. There are notes beneath each recent firmware version that tells you what was changed.
Mr.T is correct - BMS has removed the auto-clear function fromJB4 entirely. You can still delete codes when they appear through app, interface, or steering wheel controls - but no longer a way to have it happen automatically.
And Terry/BMS have removed the prior 32.6 versions that had auto-clear ... so unless you can find someone with 32.6 hex file to send to you, you may not have a choice.
I also believe that you may run into issues using 32.6 firmware with the newer phone app version. Those who are still using 32.6 or older version of firmware, can choose to either not upgrade their firmware and phone app ever again to retain auto-clear, or move to Canada/Europe where passive delete/auto-clear is not disabled.
Software :
naoaki's Avatar
Default 10-11-2017, 04:07 PM
Originally Posted by LessIsMore
Naoaki,
thank you for your answer. 32.9 The firmware seems to have no auto clear indeed. I feel a little inconvenient. I have 32.6 data and I am wondering whether I should return. If you return it will auto-clear but it will be troubled because you can not use the new function.
BMW 2007 E90 335i
Default 10-12-2017, 07:18 AM
I might still have the 32.6 hex files. If you want them I can check to see if I have them saved and send them if I do.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 10-12-2017, 07:38 AM
No Autoclear. Interesting. I did not know this and I loaded the 32.9 flash last night.
AWSAWS's Avatar
Default 10-12-2017, 07:39 AM
So 1/3 takes no action anymore?
Default 10-12-2017, 07:41 AM
http://www.n54tech.com/forums/showthread.php?t=47748
naoaki's Avatar
Default 10-12-2017, 04:22 PM
Auto clear is definitely deleted in 32.9. However, it seems that it is possible to operate auto clear using the interface in areas other than the United States. Since I am an area other than the United States, I was able to set it by the interface.
BMW 2007 E90 335i
Default 10-13-2017, 05:48 AM
Majority of the market has a backend flash now since mhd joined forces with jb4. That being said autoclear was able to clear *** codes but with a backend flash, those codes no longer appear anyway making the autoclear not needed
2007 e90 335i
Hexon turbos
Trebila Custom tuning
LessIsMore's Avatar
Inner Circle Member
Default 10-13-2017, 08:10 AM
From what Terry has said recently since this was implemented and people started to voice their displeasure, I believe MHD (and potentially other BEF companies) is going to have to take the same action of disabling auto-clear due to US federal regs/agencies.
Software :
Car: All of 'em
Default 10-13-2017, 08:54 AM
Burger Motorsports and MHD are not the same company, and they do not make the decision to remove *** codes from the software. Some OTS and custom tunes have *** codes removed, but those are intended strictly for off road race vehicles, and are not a product of Burger Motorsports in any way.
It is illegal to bandaid any emissions issue through tuning or piggybacks on road cars. Period. End of story. Burger Motorsports does not in any way bypass emissions. If I am not mistaken, they are now only developing builds on catted cars, now. The JB4 has the capability of clearing fault codes. If you want to use that capability to clear out fault codes while you make the decision to violate emissions law (and actually enjoy your car), that is 100% on you. Burger can't do it for you, that's all.
MHD gives you the ability to modify anything in the back end. You make the decision to remove the *** codes, as the tuner.
Can you get in trouble for doing this? Yes, but it seems unlikely.
Can Burger Motorsports (and tuners like myself) get in trouble for doing this? Absolutely. We can be shut down. Especially in states like Texas (where I am) and California (where BMS is).
Default 10-13-2017, 09:02 AM
Correct. Of course laws have to be followed. Those who chose to break them is on them 100%.
2007 e90 335i
Hexon turbos
