Mid_Night_F20 Mid_Night_F20 is offline
Car: Bmw 125i F20
Default BMW N20 motor - stalling/hesitating @ idle - 09-30-2017, 12:50 AM
Hi guys,
Running the N20 motor and after installing a full turboback ******* exhaust the car is sometimes stalling & often hesitating at idle while stationary with Drive gear selected and foot on the brake. In neutral all runs smooth.
The idle seems to be a bit too low also - 650-700 rpm.
Has anybody experienced this? Any solution?
Appreciate any advice !
Aekdbrich Aekdbrich is offline
Car: 2014 328xi F30
Default 05-02-2018, 08:55 PM
Originally Posted by Mid_Night_F20
Hi guys,
Did you figure this out? Having the same issue now
Car: Bmw 125i F20
Default 05-02-2018, 09:25 PM
Nah mate, but I'm hearing its to do with no back pressure due to a ******* exhaust.
Few options I'm still considering are to:
Add a highflow *** to your system/ get a catted ** to provide some back pressure for the turbo
or
Get the new BM3 tune which allows you to adjust your idle speed, maybe the tune itself might offer more idle stability itself? I'm just not sure yet if I wanna switch from JB4 to BM3, need some dyno results before I make a decision.
For now just ride with your aircon on, its raises the idle a bit
let me know how you go
Car: 2014 328xi F30
Default 05-02-2018, 09:40 PM
or
My issue may be a little different. I am currently running BM3, but am having issues when the car is at a stop under load. It'll idle low, around 600 and then misfire, placing me into limp mode. I've replaced coils and plugs. I suspect it to be an injector or the Vanos Solenoids. It's time for me to head to the mechanic and hopefully we get it figured. It's been driving me nuts.
Car: Bmw 125i F20
Default 05-02-2018, 10:00 PM
I see, what happens when you flash it back to stock tune?
Could be different issue to mine I guess, all I know is that mine has started after the full exhaust was fitted, could be O2 sensor related which a flash tune should fix on mine?
sorry can't offer too much help..
