(#976)
Default 03-30-2018, 03:08 PM
Yes it actually used to be there and I removed it, to avoid confusion. Had a customer keep leaning his car out thinking it was fine since EGT said it was.
The boost gauge where it comes in useful is if you see it going to 100% you know boost is right against the boost safety you've entered, or if it never goes up you know right away there is a blown off chargepipe or some other issue going on. Like any gauge it's just there to do a quick check if you need.
V8MUNRO V8MUNRO is offline
Car: F10 M5
Default 03-30-2018, 03:11 PM
Lol yea thats not a good situation with the egr. I did wonder how it worked as i didnt know it was a percentage of target and thought it was actual psi/bar. Now i know that itll be more handy for sure.
F10 M5 SAKHIR ORANGE
Sossa215 Sossa215 is offline
Car: F10 M5
Default Drivetrain Malfunction - 04-01-2018, 09:14 PM
So anytime that I hit the throttle from 60 I get these four real fast pops out of the exhaust and then I get drivetrain malfunction and then the car goes into limp mode. If I just turn the car off and on it then clears it and the car starts riding like normal again. I’ve read the code and it’s a misfire on five, but I changed the spark plugs two weeks ago.
Could someone please help me with this?
Car: F10 M5
Default 04-02-2018, 12:39 AM
Sossa your best bet of help is creating a post in the bms support, help me section and if possible include a log whilstthe car is doing it as it may show.
Default 04-02-2018, 09:43 AM
First step will be to read the fault codes on the settings page.
Car: F10 M5
Default 3rd Gear Pulls - 05-27-2018, 01:16 PM
I finally managed to do two 3rd gear pulls, let me know what you think.
Default 05-27-2018, 09:29 PM
Just the CSV files, no need for photos.
Car: F10 M5
Default 05-28-2018, 02:36 AM
Sorry
sabujan sabujan is offline
Car: 335i f30 2012
Smile 05-29-2018, 02:30 AM
nice to see some activity..my JB4 setting and log - i am still running with 1st Firmware 7/15//5.. . happy ..good work..
Moderator
Default 05-29-2018, 01:25 PM
Update your firmware and follow the guide here
www.n54tech.com/forums/showthread.php?t=31292
Car: 335i f30 2012
Default 05-30-2018, 01:03 AM
thanks ... i had issues ...so went back to 7/15//5..
Moderator
Default 05-30-2018, 09:48 AM
What issues did you have? Did you upload the correct firmware for your board?
Car: 335i f30 2012
Default 06-07-2018, 05:35 AM
various minor error codes - and with 7/15//5 no issues - its a beast with good low end torque for town driving....... any logging after installing JB4_S63TU_V1_1_7_T8.hex ?
thank you
m5james's Avatar
m5james m5james is offline
Default 06-07-2018, 08:42 PM
Random question but why does my 6-cyl injector timing changes itself from 0 to 8 on it's own? Does it matter? It seems setting it back to 0 feels better but maybe it's just placebo.
'08 BMW 535xiT - MHD 1+, BMS DCI, RB/Mishimoto, VRSF 7"
Car: 335i f30 2012
Default 06-09-2018, 04:17 AM
JB4_S63TU_V1_1_7_T8 initial log
Default 06-09-2018, 08:43 AM
Looks pretty normal to me here for map2.
Car: F10 M5
Default 06-10-2018, 03:55 PM
Didnt think this was worthy of a new post but was wondering if the jb4 shows afr or calculated afr from lamba? I been reading recently on how different fuels have different stoichiometric values but lamba values stay similar. as the saying goes a little knowledge can be dangerous and i find myself in that position alot lol
Default 06-10-2018, 06:19 PM
AFR shown in logs is actual AFR regardless of fuel used. There is no conversion to be done for E85 mixtures.
Car: 335i f30 2012
Default code 180101 - 06-15-2018, 12:33 PM
Hello Terry
after loading firmware JB4_S63TU_V1_1_7_T8.hex – there has been error code -180101 - I have been experiencing this every time I load V1_1_7 firmware and now gone back to M5_OBDII_1_5 .. absolutely no issues ….
http://www.n54tech.com/forums/showthread.php?t=47748
in above link, some discussions has been noticed about country USA etc .. my VIN is of US – car is manufactured in USA then imported to UAE by dealer…is there any way you can modify V1_1_17 T8 to avoid Error code 180101? - and send it direct to me ...I live outside US and we do not have strict emissions control issues like in US .
Log with JB4_S63TU_V1_1_7_T8.hex its already there in my earlier post
CAR- BMW X5m 2015 F85
** 89 mm
100 CEL sport Cats
Dinan air intake – filter
JB4 with BCM
Thank you in advance
Default 06-15-2018, 12:58 PM
Originally Posted by m5james
Can you move them to an S63 thread and answer the question there?
I'll delete them here, you can ask in the S63 thread. Although as you know it's not a platform we actively support. I don't recall what we tied to those fields so I'd have to check myself.
Default 06-15-2018, 01:00 PM
Hello Terry
** 89 mm
100 CEL sport Cats
JB4 with BCM
0x180101 Catalyst 2: Efficiency below limit value
Code is from modifying emissions equipment. If outside USA, passive delete on WMI page can be used. Or ignore fault it won't harm anything.
