(#2301)
Tuned2chaos Tuned2chaos is offline
Car: 2017 Infiniti Q60 3.0 Premium AWD
Default 02-12-2018, 12:46 AM
How many minutes for install? Is it a DIY install?
mattds mattds is offline
Car: q60
Default 02-12-2018, 08:59 AM
Originally Posted by Ando @ BMS
We got the heat exchanger up on the website.
Red Sport guys sorry, got to wait a littler longer.
Applications
• 2016+ Q50 Silver Sport
• 2016+ Q60 Silver Sport
• 2018+ Q50 3.0t Lux
Does not fit Red Sport
*made in USA
http://www.burgertuning.com/infiniti...exchanger.html
Hey Ando, what is the difference with the Red sports? Is it the oil cooler?
thanks!
Default 02-12-2018, 09:04 AM
The same cooler fits the red sport but it also requires an extra bracket we haven't finished yet.
Installation is relatively straight forward and simple.
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 02-12-2018, 09:09 AM
Install is pretty easy and straight forward.
What takes time is the removal and install of the front bumper.
twister68's Avatar
twister68 twister68 is offline
Car: 2017 Q60 RS
Default 02-12-2018, 09:28 AM
Is this additional cooling required for boost up to +5 or is it for running higher boost with fuel additives please?
Default 02-12-2018, 09:42 AM
Not required at all. Just another modification we offer. It's most useful for those running a lot of boost doing longer runs or back to back runs.
twister68's Avatar
Car: 2017 Q60 RS
Default 02-12-2018, 09:49 AM
Thanks Terry
boostfeen boostfeen is offline
Car: Q50 RS400
Default 02-12-2018, 10:41 AM
Applications
How much longer, what's the current ETA?
Ando @ BMS's Avatar
Car: bmw 335i
Default 02-12-2018, 11:39 AM
Don't have ETA, but we are working on it.
Car: Q50 RS400
Default 02-12-2018, 12:43 PM
Thanks. Do you have any pics of the heat exchanger installed?
Ando @ BMS's Avatar
Car: bmw 335i
Default 02-12-2018, 03:33 PM
Here is a picture of the prototype on the car.
Only difference is the end tanks are slightly smaller on the released version on the right.
QFitty's Avatar
QFitty QFitty is offline
Car: 2016 Q50 Red Sport
Default 02-12-2018, 04:59 PM
Are you going to modify the front grill to allow for more air flow or are you going to keep it hidden behind the grill?
2016 Q50 Red Sport
BMS JB4 Map 1
Infiniti Sport Mufflers
Default 02-12-2018, 06:19 PM
We don't suggest any additional modification if you plan to revert the car back to stock some day. But obviously with any DIY there is room for improvement should you decide to open things up further.
VirusbetaX VirusbetaX is offline
Car: Infiniti Q50 SilverSport 3.0T
Default 02-13-2018, 06:42 AM
The intakes will not cause warranty issues will they? i have a leased vehicle.
Also i have a Q50 premium non sport AWD 3.0T i didn't see this model listed on the purchase page (ignore my avatar i was confused about models when i signed up)? is it compatible?
Ando @ BMS's Avatar
Car: bmw 335i
Default 02-13-2018, 09:35 AM
Any aftermarket part/tune has the potential to void your warranty if seen during warranty work.
It's Silver Sport with Premium non sport AWD package. Both will work on your car.
QMEGA's Avatar
QMEGA QMEGA is offline
Car: Infiniti Q50 Red Sport
Default 02-13-2018, 10:46 PM
Intake will be here in 2 days but I have a question. Do the filters have a velocity stack?
2016 Infiniti Q50 RS
JB4 / Sport Muffler
Default 02-13-2018, 10:49 PM
Yes
Q50rs400mc Q50rs400mc is offline
Car: Q50
Default 02-14-2018, 08:31 AM
I just order my intake
jrobohm's Avatar
jrobohm jrobohm is offline
Default 02-14-2018, 04:22 PM
Ok - let’s start by saying that the BMS CAI is not quite as easy an install as the directions appear. As with the JB4, take your time and do some recon first (e.g. the air box “clip” is not anything you need to force but you will probably feel like you want to - I’m sure mechanics know the trick but honestly I just spent time trying various things until the metal loop on the back came loose - more detailed instructions here would be nice.) This also goes for the passenger side shiny metal air box bracket that you will have to remove to free up the hole for the BMS CAI “short” MAF housing bracket - not mentioned in the instructions but fairly obvious it had to be removed. I used the plastic zip bags the BMS materials came in to store the OEM bolts and bracket.
All that said, I was done in under 2hrs. No engine codes - no problems (fingers crossed) - one test run done. The turbo high pitch spooling sound is only noticeable when you get on it - otherwise the car sounds like stock - hit the gas and it sounds like a turbine spooling up (go figure... )
All in all so far so good and it appears to be another well designed BMS product -Kudos to Terry and the BMS team!!
Some install photos below:
QFitty's Avatar
Default 02-14-2018, 07:31 PM
After you took some runs with them did you check them to see if they were warm to the touch since they are more exposed to then engine heat?
2016 Q50 Red Sport
BMS JB4 Map 1
jrobohm's Avatar
Default 02-14-2018, 08:06 PM
No - but I will do so at the first chance I get. Took it on a run to/from the store and did not even know the CAI was installed (normal pedal driving - that’s a good thing in my book.) However as noted before - get on the gas and the sound of the car is accentuated with a distinct turbine spinning up sound - nice addition to the otherwise stock car sound.
Moderator
Default 02-14-2018, 08:35 PM
Thank you for the review, glad you're enjoying the intakes! I really do agree on how much of a difference the intakes do sound while WOT.
Default 02-14-2018, 09:00 PM
You'll find almost no IAT difference when monitoring your JB4 logs before and after. When time permits I'll do some fun back to back testing for you skeptics to hammer the point home.
Car: q60
Default 02-14-2018, 10:01 PM
I don't see how open air filters will heat up any more than the stock set up..it's possible the after market ones might heat up slightly faster...but after a short drive both intakes are gonna be hot.
And the aftermarket intakes have a lot less restriction.
Ando @ BMS's Avatar
Car: bmw 335i
Default 02-15-2018, 09:20 AM
Nice review.
On the install - Since we have installed the same thing over and over again during R&D I think we just forgot it could be a little challenging for first time installers.
