(#251)
RayBan81's Avatar
RayBan81 RayBan81 is offline
Car: 335i E91
Default 04-19-2017, 03:00 AM
Originally Posted by pits200
As much as I'd love fast shift speed. Is there a way to reduce tq post shift till the next gear enables. Would rather allow for more power a little slower than slippage and excessive wear.
Not sure what you mean, but as the TQ reduction requests are adjusted you already should see improvements on high TQ shifts. For the majority of the cars/transmissions the Stage 3 V1.0 works fine. Some have encountered 4->5 issues. Those might want to try V1.1., where shift timings have been adjusted to take care of that.
Originally Posted by Rushan
Sorry if this been asked before but I'm trying to understand the license, if I purchase the xhp I will be able only to flash my own tcu flash and alpina flash.... etc.
If I want to try stage 1 , 2 and 3 I have additionally to purchase each stage separate?
If I want to flash back to stock I need the flasher license
So flasher license + each stage license
You need the flash license. Thats the first thing and the base for everything else. Without the license you are only allowed to backup your TCU and read/delete fault codes. The flash license enables you to flash your own custom tunes (based on your backup file) and flash OTS Stages from the xHP Store. The Stages are grouped in 1,2,3 and are Map packs, where multiple versions will appear over time. You have to look at the Stages more like feature packs. Obviously most of the people go for Stage 3, so the update focus is on Stage 3.
In general: The manual from our website answers the most questions. www.xhpflashtool.com/resources/xhp_manual.pdf
Originally Posted by torn08
So is jb4 set to map 0 enough to flash tcu
Works for the majority, yes. But some guys still had to remove JB4.
Originally Posted by N54QC
Hey Clemens, just a suggestion but it might be good idea to update this thread with the flash procedure and general answers to questions like some of the other stickies. Would help a lot of people out since there is a lack of information out there currently and would cut down on so many general questions in this thread.
If Terry allows me to create a sticky, happy to do it.
Originally Posted by BoostedSedan
Love the product gonna get stage 2 sometime soon for my 08 335i, just 2 questions can I flash back to stock for free without the General Flasher License and second, keeping my JB4 fully on with MHD BEF flashed on won't effect the TCU flash right? or any other things I have coded onto the car not transmission related?
Think I answered this in one sweep right above. The TCU flash won't affect anything else on your car, besides the TCU. So you won't loose any coding or similar on other units.
xHP Flashtool: The worlds first Android-based TCU Flashtuning tool!
More Infos on Youtube -> http://bit.ly/2hfYJT8
xHP on Facebook: https://www.facebook.com/xhpflashtool/
torn08 torn08 is offline
Car: 08 e93 335i
Default 04-19-2017, 05:29 AM
Jb4 on map 0 worked fine for me, thanks!
08 e93 335i - JB4 w/Trebila tune, alpina trans flash, bms dci, vrsf cp, tial bov, vrsf **, vrsf 7 fmic, bms occ, fuel it stage 2, N20 TMAP, vtt inlets, st coilovers
Running E50ish
BMW135xi's Avatar
BMW135xi BMW135xi is offline
Car: BMW 135I
Default 04-19-2017, 07:46 AM
I can't backup the TCU . It gets connected , but it will not backup TCU?
msport335 msport335 is offline
Car: E90 LCI
Default 04-19-2017, 08:03 AM
please take a look at this 3-4 shift log
running wedge 94 octane tune FBO+ timing corrections are most likely due to the winter gas still.
this is on XHP STAGE 3 v1.1 ....... the shift felt quick but seemed to have hung up as the torque came back on which delayed the shift.
is there anything that can be done to correct this?
if there wasn't a shift delay at 4839rpm, this would have been a quick, firm and clean shift into 4th.
Ken has been notified of the Torque limit active 1 which came on midway through 3rd gear.
http://www.***********/u/msport335/lo...og=0&data=3-22
Default 04-19-2017, 08:24 AM
I'm assuming you have a Alpina flash? If so it wasn't done right and will need to be coded properly using ncs expert
2007 e90 335i
Hexon turbos
Trebila Custom tuning
BMW135xi's Avatar
Car: BMW 135I
Default 04-19-2017, 09:41 AM
Yes . I have Alpina flash.
RayBan81's Avatar
Car: 335i E91
Default 04-19-2017, 10:33 AM
As mojo already suggested, you're likely getting a "Coding missing. Please recode your TCU properly before continuing." message.
The solution is exactly what the app says:
http://www.e90post.com/forums/showpo...&postcount=478
BMW135xi's Avatar
Car: BMW 135I
Default 04-19-2017, 10:40 AM
Will do thanks.
RayBan81's Avatar
Car: 335i E91
Default 04-20-2017, 11:07 AM
Map update for all N54/N55 Stage 2/3 customers.
D mode shifts are now way smoother and faster at the same time, compared to the first versions.
To get the new versions, just hit Re-Download in the Misc. Menu and xHP will download it to your device. Then visit the xHP Shop once, so that the new version descriptions get synced.
We also changed the Version Codes. The first digit now marks different versions of maps, the second digit marks revisions of the same map.
RickiBobbii RickiBobbii is offline
Car: 2009 335xi
Default 04-20-2017, 03:35 PM
Subd
"If you ain't first, you're last!"
xQx xQx is offline
Car: 2008 BMW 135i E88 N54 6AT
Default 04-20-2017, 06:15 PM
Maximum996's Avatar
Car: 08 535xi
Default 04-20-2017, 07:15 PM
I noticed on my fault i have coding missing also .
I have a 5 series and just like many others, i have the sport trans flashed, so i assume my guy that flashed me did not do that extra step in winkfp...problem is i may not be able to track that person down, as i assume this may happen to others...question is, would it be possible to have an option of additional coding available through xhp for the 3ers that have that fault for the alpina flash and the 5ers that have the sport flash? Or even maybe have the stock flash available kind of like mhd has?
08 535Xi - jb4 iso w/mhd flash, Bms dci, AR ********* **, er cp with forge dv, second *** delete, muffler delete, xhp trans flash, ets fmic, bms oil tstat bypass.
BMW135xi's Avatar
Car: BMW 135I
Default 04-20-2017, 07:29 PM
I have the same problem .I have an Alpina Flash coding is missing , I do
not have any idea where is the guy that flash my TCU with the Alpina Flash.
RayBan81's Avatar
Car: 335i E91
Default 04-21-2017, 01:57 AM
We would have to implement the whole NCS stuff in xHP to be able to code a unit from scratch. Thats out of our scope. xHP can only restore a previously saved coding, but not determine which coding is the right one for a given car.
Here's a rather straightforward manual how to code your car:
- Copy the file attached in your C:\NCSEXPER\PFL folder
- Start NCS
- Load Profile  Expertmode FSW PSW Manipulate ohne MAN
- Hit F2 (Chassis), Select E89 (or E60 etc.)
- Hit F1 VIN/ZCS/FA
- Hit F3 ZCS/FA f. ECU, select CAS
- Hit F6 (Back)
- Hit F4 (Process ECU), select EGS
- Hit F3 (Execute Job)
- Done
Please make sure that the text matches the functions on your F-keys in NCS!
if the text appears at another F-Key, use this one!
Here's a link to the nececessary tools: https://mega.nz/#!kAASwa7I!AJLVnnEBw...2BsZofE-TBYGmk
For all those, who don't want to do it by themselfes, but payed someone to flash Alpina/SAT on to their car: Call them and tell them to properly code your EGS. That means, tell them to finish their Job.
File Type: zip 05_Expertmode-FSW-PSW-Manipulate_ohne_MAN.zip (776 Bytes, 44 views)
mfish123 mfish123 is offline
Car: 2009 BMW 335i xDrive E90 Sedan Auto Trans
Default 04-21-2017, 03:55 AM
I previously purchased the stage 2 map. Just clicked re- download and app said it synced successfully however I still only have version 1_0 available. Any suggestions?
2009 335i AT xdrive E90 Sedan
Xhp Stage 2
BQ Tuning Custom 93 Octane Tune
FBO + Inlets
RayBan81's Avatar
Car: 335i E91
Default 04-21-2017, 04:17 AM
you also have to visit the xHP Shop once. I corrected that in my post above.
Default 04-21-2017, 08:04 AM
Thanks. That worked! Definitely much faster d mode shifts. Still pretty smooth and mproves with adaptation.
Would love the higher stage 3 d mode shift points incorporated into stage 2. I also would personally like more "eagerness" to downshift from 6th to 5th. I know custom maps are coming soon.
Xhp Stage 2
FBO + Inlets
steve.kodra steve.kodra is offline
IXLR8
Car: 335xi
Default 04-21-2017, 08:18 AM
I totally agree with this.
Default 04-21-2017, 10:05 AM
I'll send out a petition for everyone to sign. LOL!
Xhp Stage 2
FBO + Inlets
Default 04-22-2017, 07:41 AM
Not complaining here. We definitely now have something better than we've ever had before. But rather trying to help out for my benefit and everyone elses. Here examples of what I'm talking about in the higher gears:
60% + throttle in 6th gear but no downshift: http://www.***********/u/mfish123/not...data=2-5-15-23
There is small window to get a downshift to either 5th or 4th. If I try to give it more than 60% throttle often I'll often over shoot and unintentionally downshift to 4th when I really wanted 5th gear. And then I back off the pedal get back up to 5th for an instant and then back up to 6th: http://www.***********/u/mfish123/dow...data=2-5-15-23
Xhp Stage 2
FBO + Inlets
IXLR8
Car: 335xi
Default 04-22-2017, 08:16 AM
I experience the same issue.
RayBan81's Avatar
Car: 335i E91
Default 04-22-2017, 02:22 PM
Gotcha. I'd like to keep it like it is in the XE mode, but I will test changing the E Map for quicker downshifts in that speed area.
The E Map is the one used, when the rate of change at the pedal rises over a certain threshold. So if you step in slowly, the trans stays in XE map, if you move your feet quickly, it will jump to the E map. Currently E and XE are set to the same values in that speed range. Only below 60 mph they differ.
Car: 2007 BMW E90 335i
Default 04-24-2017, 07:41 PM
How difficult would it be to allow the user to select the aggressiveness for each individual mode. For example, I like a really mellow stock-like D mode (stage 1), but a kickass M-mode (stage 3).
It would be nice to take this to the next level and have user options much like MHD so we can better adjust the maps to meet our specific needs.
2007 E90 335i Pre-LCI
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 04-24-2017, 07:51 PM
I was thinking the same. I'm sure many more cool things will come with time. In a perfect world, I'd love to see map packs as a single purchase then be able to choose with a slider or check box one of maybe 3 options for shift speed/firmness and 3 options for shift points for both D and S modes.
MEGALE MEGALE is offline
Car: 535ix
Default 04-25-2017, 09:15 AM
I have a 2010 535xi with a 6AT. Will this work on my car?
