B_M2 B_M2 is offline
Car: BMW M2
Default Tuning BMW M2 pure stage 2 , FBO , PI - 04-14-2017, 12:09 PM
Hi guys ,
I have a BMW M2 F87 DCT . It has :
JB4 with Bluetooth
EWG harness
BMS intake
Pure stage 2 turbos
Inlet *****
DV+
ER down pipe
ER charger pipe
ER race intercooler
ER Tic
Fuel it stage 2 LPFP fuel pump (new built)
Fuel it port injection (Platinum kit) with BMS controller & 750cc injectors
N20 Tmap sensor
My plan is tune it first on Pump gas (93 octane) then I will mix it with ethanol .
Just did a Map 6 tune (attached CSV file)
Meth scale 100
N20 map sensor = 1
PID Gain 6
Boost safety 24
AFR 10 across the board
And boost settings
1500: 14
2000: 15
2500: 16
3000: 17
3500: 18
4000: 19
4500: 19
5000: 19
5500: 19
6000: 19
6500: 19
7000: 18
The car is running good but I it only gained 70 whp from the base line . Please help me to reach the maximum of pump gas then we will move to tune it with ethanol.
Attached the map 6 logs
Please tuners and experts help me
Peter @ Pure's Avatar
Car: F20 M135i
Default 04-14-2017, 12:13 PM
Originally Posted by B_M2
Hi guys ,
JB4 with Bluetooth
EWG harness
BMS intake
Pure stage 2 turbos
Inlet *****
DV+
ER *********
ER charger pipe
ER race intercooler
ER Tic
N20 Tmap sensor
Meth scale 100
N20 map sensor = 1
PID Gain 6
Boost safety 24
And boost settings
1500: 14
2000: 15
2500: 16
3000: 17
3500: 18
4000: 19
4500: 19
5000: 19
5500: 19
6000: 19
6500: 19
7000: 18
The car stock has 380bhp? 450 bhp on 93 pump seems maxing out pump gas numbers. You'll need more octane now. At least that's my experience on PS2 with pump gas on N55.
You need octane to get timing up. Adding more boost will cause timing to drop.
F80 M3 - 100-200: 4.9, 60-130: 5.6
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Car: BMW M2
Default 04-14-2017, 12:25 PM
Yes I know but the difference between map 1 and map 6 was only 12 whp .
My car stock bas line Dyno was : 354 whp
Map 1 : 411 whp
Map 6 : 423 whp
That seems low with all mods .
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 04-14-2017, 12:39 PM
I assume you are from kuwait from the IAT numbers starting from 100, I'd have wait for stage3 turbo, M2 already comes with a good turbo almost stage one power from factory.
420whp on 18psi is nice imagine with some ethanol 23-24psi its a beast and you gonna need some rubber
N55 - Doc race 6266.
Abear Abear is offline
Default 04-14-2017, 12:45 PM
Was gonna say exactly terkait is saying. Those are pretty good numbers for 18-19psi and just pump. On E60 you will see probably another 30-50whp at the same boost level. Pump gas is just not very conducive of high horsepower on these cars.
Car: BMW M2
Default 04-19-2017, 02:10 AM
Guys ,
During tuning with Terry my car went to boost 0 . It looks it is a mechanical problem. I went to the garage and checked all the parts are ok . Couldn't find the problem.
The car shows 0 boost at all with no Boost leak , no codes and nothing shows at all . I have checked with boost leak test , wires , everything and it seems perfect . The car is not building boost at all .
If anyone knows the problem please advice me ?
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 04-19-2017, 02:33 PM
Did you change firmware? what map are you running?
try map 0 and see.
Default 04-19-2017, 02:34 PM
Did you check the electronic wastegate? It may be stuck open. I had mine replaced under warranty. I kept throwing codes for it though. You dont have any codes?
Default 04-19-2017, 02:37 PM
try map 0 and see.
Thats a good point too. For a while I had been using an older version of the JB4 mobile app as I have a dedicated phone I leave in my car for the JB4. It doesnt have cell service anymore, so the only time I update it is when I charge it, and thats if I turn it on while charging. Anyway, the older version kept causing problems, random map switches, and my map 6 settings would get altered on their own. Happened twice before I updated the app and everything is normal.
Default 04-19-2017, 09:50 PM
Are you running a flash? Surprised the AFR's are as low as they are.
Car: F20 M135i
Default 04-19-2017, 10:53 PM
Map 1 : 411 whp
Map 6 : 423 whp
That's because map1 runs additive boost (eg 4 psi) over dme_bt (stock boost). On M2 stock boost is 15 psi. So add 4 psi to that and you are at 19 psi on map1.
peter@pureturbos.eu
pureturbos.eu
Car: BMW M2
Default 04-21-2017, 03:37 AM
try map 0 and see.
Yes and still no luck . 0 boost
Car: BMW M2
Default 04-21-2017, 03:38 AM
Yes we have checked it . No luck .
No codes . No boost leak
The car is running good until I was tuning it
Car: BMW M2
Default 04-21-2017, 03:39 AM
I'm doing a logs with terry . No only JB4
Car: BMW M2
Default 04-21-2017, 03:41 AM
Actually, I was logging with terry to custom map 6 and updating the firmwire but now the car is running 0 boost all the time . He was adjusting the Canbus . The car is seems weak . But now it's not hitting boost .
I have checked all ***** , no codes and nothing is helping me
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 04-21-2017, 03:52 AM
Yes we have checked it. No luck.
No codes. No boost leak
The car is running until I was tuning it
What do you mean by tuning it?
I don't think you can disable Electronic wastegate actuator from Jb4.
You sure you are not running map 8 which is NA map ( no boost )? which used to be for old cars not sure if it's even available for new F-series.
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 04-21-2017, 03:53 AM
Ok you might wanna try reupload the firmware if it happened after that. it may missed a block or something.
Car: BMW M2
Default 04-22-2017, 11:37 AM
Guys ,
Today I have removed the EWG and JB4 also same problem.
Checked the boost leak
Check everything
Still the car is zero boost
Any advice
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 04-22-2017, 12:14 PM
Idk our cars throw codes for small things, no boost and no codes is weird.
might wanna visit the dealer for a software update maybe?
135idct 135idct is offline
Default 04-23-2017, 12:47 PM
try to flash it with bootmod maybe they will fix the problem
Default 04-25-2017, 04:04 AM
Guys ,
Check everything
Any advice
if no codes and no leaks, remove the turbo and check the shaft and compresor wheel
M-terkait's Avatar
M-Terkait
Car: F30 335i
Default 04-25-2017, 05:28 AM
if the turbo is faulty it would produce some boost at least.
there is something blocking the codes from appearing.
even with BEF flash and jb4 we still get a code from low pressure at lower RPMs.
I really wanna take a look at it.
Car: BMW M2
Default 04-27-2017, 03:45 AM
Hi guys ,
I have checked everything . At the end we opened the Pure stage 2 and it's broken
We didn't even push more than 19 psi and we are still tuning it and its broken now . How is this happend ?!?
Please explain me
Default 04-27-2017, 10:21 AM
Hi guys ,
Please explain me
Not sure, but it can happen, turbos arent invulnerable, although that would be nice.
My first one died as well, Pure warrantied it, although now that youve opened it, it may be hard to get it warrantied. Hopefully Pure will come through though. Sorry you had to go through this.
Car: BMW M2
Default 04-27-2017, 11:17 AM
I have talked to them . Come on 1 week with only dataloging and now Boom . Really I'm so disappointed. Never had like this problem before . The car has 4K miles (stock) with Pure only 100 or 200 miles and everything in the turbo is broken . I will upload the pictures later on .
