(#76)
High Flier's Avatar
High Flier High Flier is offline
Car: 340iX 6MT MPPSK
Default 05-23-2018, 04:28 AM
Bummer, thank for sharing. I'm going to check my wires just to make sure nothing is in contact with hot engine parts.
BMW After BMW
Car: BMW M240i
Default 05-25-2018, 06:00 AM
I asked support about where to route the EWG harness on a B58, since I clearly didn't have enough common sense. They suggested going around or on top of the air intake box or the coolant area and to stay away from the manifold (there's my point about common sense).
So I spliced my EWG wires back together with butt splices and put some heat-shrink tubing around it and routed it the way they suggested, and so far, no codes. I'll switch to Map 6 with @Bullitt's settings and start logging and hopefully will feel the difference.
2017 F23/M240i Convertible (B58) / 6MT / BMS Air Intake / Stock Exhaust / 93 Octane
Bullitt1841's Avatar
Default 05-25-2018, 10:12 AM
I used to be a stickler about having idiot proof instructions with everything I purchased. Then I decided I should stop being an idiot and use common sense.
#IUsedToBeEntitled
2017 F36 440i Gran Coupe | MPPSK | Track Handling Package | JB4 | BMS Meth Kit (Dual CM5) | BMS Intake | BMW 513M Wheels | Dinan Shockware
SOLD: 2007 E90 335i | PURE Stage 2 N54 Turbos | JB4 | FBO | 160k+ miles on the car, 120k+ miles on the JB4
Erikb Erikb is offline
Default 05-25-2018, 12:04 PM
Any idea about the whp with this map?
pskdude pskdude is offline
Car: m40i
Default 05-25-2018, 12:16 PM
is there any guide to install this on the b58 G01 - w MPPK
Default 05-25-2018, 01:00 PM
Should be good for around 370 - 390 ish.
http://www.n54tech.com/forums/showpo...&postcount=124
Default 05-25-2018, 01:27 PM
Thanks, waiting for my ff ewg cables to arrive.
Was hoping for 400whp, but 390 would be close enough
Default 05-25-2018, 01:42 PM
Peak number doesn't mean a whole lot. Different dyno's read different numbers.
Area under the curve and times/trap speeds are what matters.
18bmwb58 18bmwb58 is offline
Car: 2018 bmw 340i m sport
Default Today, 06:28 PM
Any links to firmware 9 download ? I got ********* mid muffler and res delete bms intake jb4 with ff and ewg wires what should i set everything to on map 6?
BMW After BMW
Car: BMW M240i
Default Today, 06:54 PM
Finally able to do a long log. Map 6 with EWG wires, with at least one long pull to ~6000 in 3rd and almost the same in 4th.
I'm only getting a max of 17.0 psi briefly but it's close throughout the pulls. The power is definitely nice and long and sustained. Compared to Map 2, this feels better and the power is there for longer periods before tailing off.
I'm going to try a couple more logs over the next few days, but this is very promising so far for the M240i - there's quite a bit of headroom in that tune and this setup seems to be pushing in the right direction. Adding the FF wires should help too I think.
EDIT: Another short log added.
