(#826)
fisc0h fisc0h is offline
Car: 335i xdrve/m-sport
Default 07-19-2017, 06:41 PM
The THR template has a less sensitive throttle mapping in it.
Is there a pump THR version?
2011 335i x-drive MSport: MHD E85_BEF + JB4 ISO 5.15 / Pure Stage 2 / Stage 2 LPFP (bucketless) / N20 TMAP / BMS Intake / ER CP / VRSF ** / VRSF 7" FMIC
Default 07-19-2017, 07:20 PM
No but we can make one if you want. I'll probably rename THR to "stock throttle" to more clearly distinguish them.
Default 07-19-2017, 07:51 PM
If it his better compatibility with xHP, then I think that would be very beneficial. Thanks Terry!
sd306 sd306 is offline
Car: 2011 e92 N55 335i Coupe M-Sport
Default 07-19-2017, 10:27 PM
If a lager number of people report issues with the xHP and MHD back end flash map then we'll continue working on changes. So far only one car reported issues and throttle changes reported to have corrected it.
Terry, I am having the same issue with the JB4 BEF and xHP. (timing pulls for torque limit issues). Alpina works fine.
Above MHD stated when flashing MT nothing changes, but when flashing AT things do change. What tables change (i'd like to leave those as stock so the transmission can see actual torque values)? I am going to make a custom MHD BEF for JB4 to work with xHP that acts as a MHD map with MT option selected. In a previous post you stated to change the torque eff divisor to match the stock map in the BEF. However, I have the 2-23-17 version of the BEF for E85_PI and that table matches the table in the stock bin in the 2-23-17 version.
Also I noticed:
The latest BEF E85_PI torque eff divisor table has different values then the latest stock torque eff divisor table.
Default 07-23-2017, 07:35 AM
So with this, you choose the flash MHD custom map option (with MT checkbox selected), and then flash the JB4 BEF?
Also I noticed:
carlospineda93 carlospineda93 is offline
Car: 2011 BMW 335i
Default 07-27-2017, 07:18 PM
I'm also having trouble with the JB4 mhd backend flash working with XHP. Just not smooth as it was with just the MHD and xHP. Sometimes when going into 3rd gear it get jerky. Take out the jb4 and problem solved. Would be nice if I could run Jb4 mhd and xhp together �� I'm I the only one having Xhp and jb4 backend flash problems?
Alpha Twins's Avatar
Alpha Twins Alpha Twins is offline
Car: E92-335i-N55-2011
Default 07-28-2017, 03:14 AM
Also having problem here with the last software update, (jb4 & mhd)
Car is feeling jerky in the first 3 gears when flooring it,
Also the watertemp is not working on the mobile app
E92 335i 2011 N55 | JB4 G5 ISO | M Performance Exhaust | BMS ** | Wagner evo 2 comp Intercooler | BMS catchcan | BMS Chargepipe | MHD FLASH
GOGRN GOGRN is offline
Car: 2011 E90 335xi Msport
Default 07-30-2017, 01:51 PM
is there an E85 PI map that is a little less aggressive with fueling?
My problem with the cobb maps is to run straight E85 and a TBI the trims go waay rich when it kicks in. this is with the fuel-it PI maps.
This certainly sounds easier to tune as modifying my cobb maps always seems to brick the car.
Default 07-30-2017, 02:06 PM
Toss Cobb, load MHD, and evaluate our existing BEF maps.
Default 07-30-2017, 02:34 PM
Yeah thats my plan. the thing has been nothing but a pain.
Default 08-02-2017, 08:49 AM
I ave N55 pump BEF (latest version) flashed and c4tless DwnPipe. I'm still getting 3106 codes and SES light. Anyone else have this issue? I did not check the OEM/Catted DwnPipe box when I flashed
Default 08-02-2017, 09:04 AM
Default maps do not disable it. You'd have to modify them in tuner pro manually or contact MHD for help on that if living outside the USA or using for competition race use only.
Default 08-02-2017, 10:04 AM
Thanks for the quick response Terry!
Any update on the "stock throttle" option for the non-E85 BEFs?
ganque ganque is offline
Car: 2013 135i M Sport
Default 08-09-2017, 07:20 PM
Any updates on the BEF for the new MEVD1726 BT Unlocked vehicles?
DanM's Avatar
DanM DanM is offline
Car: 2012 135i N55 DCT
Default 08-09-2017, 07:25 PM
+1
2012 135i N55 DCT Cabonschwarz Metallic
--- JB4 w/ BMS BEF / Pure Stage 2 / Pure Inlet Pipe / DV+ / TBI / Wagner D-P / Wagner FMIC / BMS Intake / Cobb CP / Stage 2 LPFP / 19" VMR V703's / Eibach Pro / Blackline LCI's / RIEGER ---
