Default VW Stage1 Firmware & Updates - 11-02-2015, 09:49 AM
*** WARNING *** The firmware and map guide below applies to the Stage1 system only. NOT the JB4 system. Uploading Stage1 firmware to the JB4 will likely require you to mail the JB4 control board back in to be reflashed. Don't upload Stage1 firmware to your JB4 system.
This thread is for VW Stage1 Firmware Updates and Map Notes
The same BMS DATA to USB cable is used for all of our tunes and strongly suggested for free software updates and new features as we post them. The Stage1 tune uses the JB4 interface.
Interface: Latest Interface Download. When updating your interface you may need to first go to "add remove programs" and "remove" your previous interface.
If you need directions on how to connect a laptop to your Stage1 to update firmware or how to datalog Click here.
Map List:
Map 0: Stock bypass. Stage1 fully disabled
Map 1: 4.8psi over stock, adjustable by changing "boost safety" setting on user adjustment tab.
Map 3: Progressive methanol mapping
Map 6: Custom tuning map entered on user adjustment tab.
Firmware: v4
1) Changed processor speed from 8mhz to 64mhz and increased the sampling rate of the analog I/O 4x. This seemed to have improved the idle stability in some models.
PLF's Avatar
PLF PLF is offline
Default 11-02-2015, 10:03 AM
Any possibility this could be available for the Tiguan ?
Default 11-02-2015, 11:57 AM
Relative to which motor. We are planning to develop more units relative to the demand we get.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
PLF's Avatar
PLF PLF is offline
Default 11-02-2015, 12:29 PM
If I am not mistaking, all 2009-2015 Tiguans in North America use the Gen 2 EA888
I own a 2013.
Default 11-02-2015, 12:49 PM
I own a 2013.
Will look into it, its the 200hp version.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
PLF's Avatar
PLF PLF is offline
Default 11-02-2015, 12:59 PM
This would be a big plus for ppl in my situation that still have a lot of warranty left VS a flash tune
glina126 glina126 is offline
Car: 2015 GTI MKVII
Default 11-02-2015, 08:32 PM
This is awesome that the firmware have its place now!! :D
Question though, what made you run the IC at 8mhz instead of 64 from the get go? Power is not an issue - I always push for the max rating of the chip, though 64 is probably not the max the chip can handle. I should open up the box to see what part it is :p i guess timing was easier on a slower clock? I really wish to mess around with the code. Could I sign an Nda? :p
Default 11-02-2015, 08:46 PM
I always run them as at the minimum speed to meet the sampling rates required. In this case we raised analog sampling from 200hz to 800hz which justified speeding up the processor.
Universal_Remonster Universal_Remonster is offline
Car: MK7 GTI
Default 11-12-2015, 04:53 PM
Is this firmware newer than the stage1_64_2.hex file?
Default 11-12-2015, 05:10 PM
Probably same.
Default 11-12-2015, 05:57 PM
Load the firmware rather then we know everyone is on the same page.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
golf7r golf7r is offline
Car: Golf 7R
Default 11-16-2015, 02:22 AM
I assume this firmware can be applied to either the R or GTI boxes?
Default 11-16-2015, 06:19 AM
Yes it is for both.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Car: MK7 GTI
Default 11-17-2015, 09:15 AM
Probably same.
Sure doesn't feel the same. Can you check to make sure they're 100% identical?
Default 11-17-2015, 09:56 AM
None of the firmware will have any tuning differences. It's all back end stuff. If you need tuning help you'd email logs to George.
But what we always tell customers who claim an previous firmware ran better for them is, run whatever you want.
Default 11-17-2015, 10:08 AM
I have run them both back to back and identical boost profile on both. What difference do you see or feel?
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Car: MK7 GTI
Default 11-17-2015, 10:46 AM
Not taking about boost profiles. The other firmware has a much smoother idle for me. Not sure why. That's why I asked about the differences between the two.
Default 11-17-2015, 11:02 AM
If you log it we can verify what speed the processor is running at from the CSV file.
Car: MK7 GTI
Default 11-17-2015, 02:07 PM
I've attached the hex file that yields the smoothest idle for me.
Default 11-17-2015, 03:05 PM
It's the same as the firmware in the first post. 64mhz.
Car: MK7 GTI
Default 11-17-2015, 03:09 PM
Yes, I knew that the sampling was the same given the file name. Wondering if there are any differences that could explain the smoother idle. I'm only able to use Map 1 with the firmware because Map 6 is disabled but it's worth it for the smoothness.
Default 11-17-2015, 06:49 PM
The files are identical, so must be a red herring.
Car: MK7 GTI
Default 11-18-2015, 06:22 AM
That's odd because Map 6 doesn't work in the file that I uploaded but works fine in the one posted here.
From George: "There is logging capability on it but we haven't opened map 6 yet on it."
Default 11-18-2015, 06:36 AM
Map 6 may work but its untested on the hex file you got. Let hear from Terry.
2015 VW Golf 1.4TSI
2017 Audi 8V RS3
Car: MK7 GTI
Default 11-18-2015, 06:40 AM
I didn't even try it on my file. I just ran Map 1 and was running Map 6 on the new file posted here. Can't imagine there would be any idle differences between the maps on a given firmware.
