(#1251)
Seaz Seaz is offline
Car: 2009 335xi coupe
Default 05-25-2018, 02:19 PM
The log looks okay and everything is where it should be.I don't know if I would turn it up anymore with the octane you have. I would add EWG wires and Methanol or Race gas if you'd want to turn it up anymore.
Several guys on another forum are talking about the jb4 on the x3. For the most part it's positive but we identified a problem
http://x3.xbimmers.com/forums/showth...1446435&page=8
the car bogs on shifts but ws definitely feels
the power increase. Sounds like what was happening in the N54s, back in the day, with the JB4 and Terry had to add a"bog fix" solution in the firmware that could be scaled up and down to alleviate the slow sludgy shifts when the boost is dumped
18bmwb58 18bmwb58 is offline
Car: 2018 bmw 340i m sport
Default 05-27-2018, 03:29 PM
What firmware do i need to download for b58 ewg and ff wires ? And where can i download it? Also which map can i use for e85 and do i have to adjust anything manually for ewg throttle closures ? If so which map and what settings are the best ?
BMW After BMW
Car: BMW M240i
Default 05-27-2018, 05:17 PM
The latest firmware is on p. 1 of this thread! There’s only one set of published firmware for B58. In terms of EWG and FF settings, the experience of others is your best bet, so hunt around the B58 section, this one is a good thread - http://www.n54tech.com/forums/showthread.php?t=47581
2017 F23/M240i Convertible (B58) / 6MT / FP Wires / EWG Wires / BMS Air Intake / Stock Exhaust / 93 Octane + 2 gallons E85
JBoe JBoe is offline
Car: M240i
Default 05-28-2018, 01:43 AM
Is there a list with details of the "FutureUseD Bit4" options? Some are self explanitory and some aren't. Either way, it would be great to know their details and default settings.
Default 05-28-2018, 04:46 AM
All i see is firmware 8 and when u scroll down tyeres two 9s im confused
Car: M240i
Default 05-28-2018, 08:35 AM
Above the version downloads, in the first post, there are details covering what each firmware version addresses. Inside the details to V9 you'll see reference to the "T" updates. Each update builds upon the last and either offers more options or a fix for a bug found in that version. For the very latest, you'll want V9T12. It's still relatively new and may have a few bugs still. It looks like the most stable/used version to date is V8. You'd have to read through the entire thread to get all that info. I'm still on V8 and will upgrade when I have time. If you're using map 1 or 2, either will be fine for you. Most updates offer more for those using the later map options that are more customizable. Hope this helps, but for full knowledge you'll have to read the entire thread.
Multiple versions are there to offer a way back should you find an issue or prefer one version over the other. The latest versions are tested by both BMS and the more knowledgeable users on this site. All still offer the same high level of safety, but the higher maps are still able to cause issues if you aren't experienced enough to be in/using them. You really must read the stickies available and never hesitate to post logs in the support forum or ask for help before making changes. There's a ton of support on these forums and a lot of situations/issues you may have are already in the posts. Best advice... read all you can as it will help immensely.
Default 05-28-2018, 09:31 AM
As a general rule run the latest version unless there is some problem you want to blame on the firmware, then you can try rolling back if you need.
Default 05-28-2018, 04:53 PM
Ok got the latest update installed my ewg and ff wires put in 2 gallons of e85 here is my log let me know what you think guys
Car: M240i
Default 05-29-2018, 09:12 PM
Any info on this? Would be a great add to tuning/settings sticky in the support thread area.
BMW After BMW
Car: BMW M240i
Default 05-31-2018, 07:57 PM
Working on a new firmware tweak for the B58 and could use some help testing it out. Right now it's only active on maps 6 and 7. It changes how the JB4 spoofs the IAT signal to alter boost target, timing, and AFR targets.
To test it out load the T12 firmware in the first post, set FutureUseD bit#2 to 1 or on, set 6cyl timing to 1 (e.g. make IAT as high as possible), and evaluate/record a log or two for us to check out.
I know this is old but what was the outcome of this testing? Did it work out? Is the tweak still available in firmware 9, and do you need more logs if so?
Default 05-31-2018, 08:37 PM
I works and I believe we are using it on Map 5. The current FUD setting bit 2 on the latest firmware will have the IAT spoof on all maps so you can test map 1 and see how it does if you don't have the octane/modifications to test map 5 off the bat.
Car: M240i
Default 06-07-2018, 10:15 PM
If I take the default settings, from the first post's pic, and put them into Map 6 with all boost settings at 3, wouldn't it be the same as running Map 1? I only ask as I'd like a good base point to start from on a tuneable map. It appears to work this way if you use Map 6 as an additive map. Likewise, if I used the same settings at 4psi, I'd be copying Map 2. Please let me know.
carguy19 carguy19 is offline
Car: 335 cpe
Default 06-08-2018, 06:38 AM
What is the IAT spoof?
BMW After BMW
Car: BMW M240i
Default 06-12-2018, 04:38 PM
Here's a decent run I took with the spoof on. Car felt good, but do trims look a little worse than my previous logs, although maybe timing is better? I don't know, I'm still not a log-reading expert. I still have the spoof on for now... this was Map 6 with custom settings you'll see in the CSV.
Default 06-12-2018, 05:39 PM
IAT spool with send a lower IAT to the DME so it requests more timing. More timing if octane is good means more power
Default 06-12-2018, 05:40 PM
Yea it looks like trims max out for a bit in the lower RPM range and come back down. The log looks good though, timing nice and steady. A big off target boost but that's an easy fix.
BMW After BMW
Car: BMW M240i
Default 06-13-2018, 07:20 AM
Is the "fix" to lower the target boost in the map 6 settings, or did you have something else in mind? I went ahead and did that anyway (knocked boost target down from 17.0 to 16.0) and left the IAT spoof on (see log) but if you have any other suggestions, please lmk.
Default 06-13-2018, 10:42 AM
No the fix just helps raise timing, a couple more runs and you will be closer to target. Looks good to me though, probably the most you can get from this until you add methanol and a big turbo :D
BMW After BMW
Car: BMW M240i
Default 06-13-2018, 12:00 PM
Hahaha, I am still holding out hope that the DME cracks are real and we can eventually get past the fueling limits to allow more E85.
JorgeIII JorgeIII is offline
Car: BMW F30 LCI 320i 2017
Default 06-13-2018, 03:41 PM
I had some difficulty getting consistent smooth pools with the Jb4 on a B48 320i (any map).
I found one of the causes and an easy workaround so I'm sharing my experience here.
In short:
Basically Engine DME boost map changes with driving mode (sport/comfort) and the same JB4 map won't work well in both driving modes. A work around is to deactivate in the Idrive menu from the car the changes de DME make to the engine in sport drive mode so the engine always runs like in comfort mode independently of other driving modes changes and a consistent jb4 map is easy to achieve.
The cause:
Engine boost by rpm changes with driving mode (sport/comfort/eco). In a wot pool in sport mode my 20i gets a flat 7.5 to 8 psi boost from low to max rpm. But doing the same in comfort mode I get a flat 4.5-5 psi boost with a 7.5-8 psi peak at 4500-5000 rpm. That is almost a 100% boost increase from 4000 to 4.5 psi)to 4500 (8 psi) rpm that the jb4 seems to have trouble compensating for (overshooting and over correcting= oscillations= not a nice ride).
So you can work on a fine tuned map 6 on sport mode, using duty bias to adjust de FF curve by rpm to mach PWM, using just the amount of PID gain to allow small corrections without oscillations, etc, and the car runs smooth and fast (huge HP difference from original 8 psi to flat 16 psi in the 20i). But the moment you switch to comfort mode or you restart the car and forget to switch back to sport and accelerate the engines DME gives a completely different boost / rpm curve and the jb4 goes crazy trying to adjust with the known unpleasant result.
Maybe this engine needs two maps, one for sports and one for comfort mode.
Work around:
1) Make a custom map 6 for comfort mode (or just keep with maps 1, 2 or 3.
2)In cars idrive menu go to Sport mode configuration and deactivate changes made to the engine but leave activated the other options (suspension, gears, driving wheel stiffness and gas pedal sensitivity)
Currently I found a limitation. Its “easy” to make a map 6 for sport mode (we start with a relative flat DME’s BOOST curve) but its difficult in comfort mode. Max Boost / RPM changes so abruptly between 4500 and 5000 rpm that current available duty bias range at the JB4 (I’ m using from 0 to 100 values) is not enough to cover the needed FF/rpm curve and using PID gain above a value of 10 trying to compensate might bring oscillations.
It would be great to have a custom map or even firmware for the B48 20i and if not possible at least to have a wider duty bias range (for de 20i 0 to 170-180 would be enough, maybe allow negative values).
Hope it helps, Jorge.
Default 06-13-2018, 05:13 PM
In short:
The cause:
Work around:
If you have logs to post showing this that would be best for us to evaluate.
314da 314da is offline
Car: BMW F31 320ix LCI
Default 06-14-2018, 01:23 AM
In short:
The cause:
Work around:
I have discovered sport and comfort modes from the same problem. It would be nice to get product development for x20i engines. eg 320i dynamometer developmen
Car: M240i
Default 06-15-2018, 07:55 AM
How do I activate the AFR showing in cruise control area? I can't use the BC due to my gauge cluster and didn't see it as part of FUD bits. Please advise on where in the software I can enable. Thanks.
ArthurZZZ ArthurZZZ is offline
Car: F30 320i Xdrive LCI B48
Default 06-16-2018, 12:56 PM
In short:
Hi Jorge,
On B48 320i, If I run map2, do you mean that it's better not to switch to sport engine mode to avoid JB misadaptation or malfunction?
Default 06-16-2018, 12:59 PM
Hi guys,
recently installed JB4 on my fully stock 320i B48. Passionate to understand all the settings it has in phone app. Any glossary available in one place? Thank you!
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
Dj_quik
